查看: 2232|回復: 2
單片機+rc522關于寫密碼寫不進去,困擾了幾天,幫我看一下例程
ID:742308 發(fā)表于 2020-5-4 13:59 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#define ReadWriteArea 0x01
extern unsigned char UID[4];
extern int g_SPI_Fd;
unsigned char SetKey_read[16];
unsigned char DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
unsigned char ResetKey[6] = {0xAB, 0xCD, 0xEF, 0xFF, 0xFF, 0xFF};
unsigned char SetKey_write[16] = {0xAB, 0xCD, 0xEF, 0xFF, 0xFF, 0xFF,
        0xFF, 0x07, 0x80, 0x69,
unsigned char Default_write[16] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
主程序中寫卡部分代碼
void my_register(void)
                int i,j;
                HandleConfigMenu('A');//讀卡
                my_status = PcdSelect(UID);
                PcdHalt(); //我是這里設置的休眠,不知道會不會對讀寫有影響
                printf("Select:%x\n", my_status);
                if(MI_OK != my_status) continue;
                my_status = PcdAuthState(PICC_AUTHENT1A , ReadWriteArea, ResetKey, UID);//尋卡
                if(MI_OK == my_status)
                        printf("The card has been registered!!!\n");
                        usleep(500000);
                        break;
                        printf("Check\n");
                        my_status = PcdWrite(ReadWriteArea, SetKey_write);
                        printf("PcdWrite: %x\n", my_status);
                        printf("WRITE ...\n");
                                my_status = MI_ERR;
                                printf("Registering...\n");
                                buzzer_control(DEVICE_BUZZER,BUZZERON);
                                usleep(500000);
                                buzzer_control(DEVICE_BUZZER,BUZZEROFF);
                                printf("!!!!!!!!\n");
                                printf("\n");
                                printf("The card register successfully!\n");
                                printf("\n");
                                break;
下面貼出來PcdWrite、PcdAuthState相關代碼,有懂的朋友幫我看一下是不是哪里參數設置錯了
char PcdWrite(unsigned char addr,unsigned char *pData)
        char status;
        unsigned int  unLen;
        unsigned char i,ucComMF522Buf[MAXRLEN];
        ucComMF522Buf[0] = PICC_WRITE;
        ucComMF522Buf[1] = addr;
        CalulateCRC(ucComMF522Buf,2,&ucComMF522Buf[2]);
        status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,4,ucComMF522Buf,&unLen);
        if ((status != MI_OK) || (unLen != 4) || ((ucComMF522Buf[0] & 0x0F) != 0x0A)) //根據終端打印信息,是這里出錯
        {   printf("1.\n");
                status = MI_ERR;   }
        if (status == MI_OK)
                for (i=0; i<16; i++)
                {    ucComMF522Buf[ i] = *(pData+i);   }
                CalulateCRC(ucComMF522Buf,16,&ucComMF522Buf[16]);
                status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,18,ucComMF522Buf,&unLen);
                {   printf("2.\n");
                        status = MI_ERR;   }
        return status;
char PcdAuthState(unsigned char auth_mode,unsigned char addr,unsigned char *pKey,unsigned char *pSnr)
        char status;
        unsigned int  unLen;
        ucComMF522Buf[0] = auth_mode;
        for (i=0; i<6; i++)
        {    ucComMF522Buf[i+2] = *(pKey+i);   }
        for (i=0; i<6; i++)
        {    ucComMF522Buf[i+8] = *(pSnr+i);   }
        status = PcdComMF522(PCD_AUTHENT,ucComMF522Buf,12,ucComMF522Buf,&unLen);
        if ((status != MI_OK) || (!(ReadRawRC(Status2Reg) & 0x08)))
        {   status = MI_ERR;   }
        return status;
void Auto_Reader(void)
        int i = 0;
                if(PcdRequest(0x26,UID) == MI_OK)
                        if(PcdAnticoll(UID) == MI_OK)
                                printf("\n");
                                printf("\n");
                                printf("\n");
                                printf("ID:\t");
                                for(i=0; i<4; i++)
                                        printf("%x", UID[ i]);
                                printf("\n");
                                printf("\n");
                                printf("\n");
                        break;
                        printf(".");
                usleep(300000);
ID:742308 發(fā)表于 2020-5-4 14:00 | 只看該作者
我在第二頁po出了其他相關代碼~有大佬能幫看一下,看了很多歷程后沒轍了
ID:727287 發(fā)表于 2020-5-12 01:03 來自手機 | 只看該作者
莫小豪 發(fā)表于 2020-5-4 14:00
if ((status != MI_OK) || (unLen != 4) || ((ucComMF522Buf[0] & 0x0F) != 0x0A)) //那就重點檢查這里
將判斷拆開
if (status != MI_OK)
      printf("RC522與卡通信失敗");
if (unLen != 4)
      printf("返回數據長度出錯");
if ((ucComMF522Buf[0] & 0x0F) != 0x0A)
      printf("塊第一字節(jié)不為0A");
Powered by 單片機教程網
