#include "main.h"
#include "HX711.h"
#include "uart.h"
#include "LCD1602.h"
unsigned long HX711_Buffer = 0;
unsigned long Weight_Maopi = 0;
long Weight_Shiwu = 0;
unsigned char flag = 0;
bit Flag_ERROR = 0;
sbit speak= P1^7;
//校準參數(shù)
//因為不同的傳感器特性曲線不是很一致,因此,每一個傳感器需要矯正這里這個參數(shù)才能使測量值很準確。
//當發(fā)現(xiàn)測試出來的重量偏大時,增加該數(shù)值。
//如果測試出來的重量偏小時,減小改數(shù)值。
//該值可以為小數(shù)
#define GapValue 400
//主函數(shù)
Uart_Init();
Send_Word("Welcome to use!\n");
Send_Word("Made by Beetle Electronic Technology!\n");
Init_LCD1602();
LCD1602_write_com(0x80);
LCD1602_write_word("Welcome to use!");
Delay_ms(1000); //延時,等待傳感器穩(wěn)定
Get_Maopi(); //稱毛皮重量
EA = 0;
Get_Weight(); //稱重
EA = 1;
Scan_Key();
//顯示當前重量
if( Flag_ERROR == 1)
Send_Word("ERROR\n");
LCD1602_write_com(0x80+0x40);
LCD1602_write_word("ERROR ");
speak=0;
speak=1;
Send_ASCII(Weight_Shiwu/1000 + 0X30);
Send_ASCII(Weight_Shiwu%1000/100 + 0X30);
Send_ASCII(Weight_Shiwu%100/10 + 0X30);
Send_ASCII(Weight_Shiwu%10 + 0X30);
Send_Word(" g\n");
LCD1602_write_data(Weight_Shiwu/1000 + 0X30);
LCD1602_write_data(Weight_Shiwu%1000/100 + 0X30);
LCD1602_write_data(Weight_Shiwu%100/10 + 0X30);
LCD1602_write_data(Weight_Shiwu%10 + 0X30);
LCD1602_write_word(" g");
//掃描按鍵
void Scan_Key()
if(KEY1 == 0)
Delay_ms(5);
if(KEY1 == 0)
while(KEY1 == 0);
Get_Maopi(); //去皮
//稱重
void Get_Weight()
Weight_Shiwu = HX711_Read();
Weight_Shiwu = Weight_Shiwu - Weight_Maopi; //獲取凈重
if(Weight_Shiwu > 0)
Weight_Shiwu = (unsigned int)((float)Weight_Shiwu/GapValue); //計算實物的實際重量
if(Weight_Shiwu > 5000) //超重報警
Flag_ERROR = 1;
Flag_ERROR = 0;
Weight_Shiwu = 0;
// Flag_ERROR = 1; //負重報警
//獲取毛皮重量
void Get_Maopi()
Weight_Maopi = HX711_Read();
//MS延時函數(shù)(12M晶振下測試)
void Delay_ms(unsigned int n)
unsigned int i,j;
for(i=0;i<n;i++)
for(j=0;j<123;j++);
HX711.7z
2020-5-5 14:37 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
1.25 MB, 下載次數(shù): 24, 下載積分: 黑幣 -5
