不要黑 發(fā)表于 2020-7-1 21:19
看看顯示函數(shù)后面有沒有,或者把程序貼一下 - #include <STC12C5A60S2.H>
- #include "intrins.h"
- sbit DS1302_CE = P0^0;
- sbit DS1302_CK = P0^1;
- sbit DS1302_IO = P0^2;
- bit flag200ms = 0; //200ms定時(shí)標(biāo)志
- unsigned char T0RH = 0; //T0重載值的高字節(jié)
- unsigned char T0RL = 0; //T0重載值的低字節(jié)
- void ConfigTimer0(unsigned int ms);
- void InitDS1302();
- unsigned char DS1302SingleRead(unsigned char reg);
- extern void InitLcd1602();
- extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
- void main()
- unsigned char i;
- unsigned char psec=0xAA; //秒備份,初值A(chǔ)A確保首次讀取時(shí)間后會(huì)刷新顯示
- unsigned char time[8]; //當(dāng)前時(shí)間數(shù)組
- unsigned char str[12]; //字符串轉(zhuǎn)換緩沖區(qū)
- EA = 1; //開總中斷
- ConfigTimer0(1); //T0定時(shí)1ms
- InitDS1302(); //初始化實(shí)時(shí)時(shí)鐘
- InitLcd1602(); //初始化液晶
- while (1)
- if (flag200ms) //每200ms讀取依次時(shí)間
- flag200ms = 0;
- for (i=0; i<7; i++) //讀取DS1302當(dāng)前時(shí)間
- time[i] = DS1302SingleRead(i);
- if (psec != time[0]) //檢測到時(shí)間有變化時(shí)刷新顯示
- str[0] = '2'; //添加年份的高2位:20
- str[1] = '0';
- str[2] = (time[6] >> 4) + '0'; //“年”高位數(shù)字轉(zhuǎn)換為ASCII碼
- str[3] = (time[6]&0x0F) + '0'; //“年”低位數(shù)字轉(zhuǎn)換為ASCII碼
- str[4] = '-'; //添加日期分隔符
- str[5] = (time[4] >> 4) + '0'; //“月”
- str[6] = (time[4]&0x0F) + '0';
- str[7] = '-';
- str[8] = (time[3] >> 4) + '0'; //“日”
- str[9] = (time[3]&0x0F) + '0';
- str[10] = '\0';
- LcdShowStr(0, 0, str); //顯示到液晶的第一行
- str[0] = (time[5]&0x0F) + '0'; //“星期”
- str[1] = '\0';
- LcdShowStr(11, 0, "week");
- LcdShowStr(15, 0, str); //顯示到液晶的第一行
- str[0] = (time[2] >> 4) + '0'; //“時(shí)”
- str[1] = (time[2]&0x0F) + '0';
- str[2] = ':'; //添加時(shí)間分隔符
- str[3] = (time[1] >> 4) + '0'; //“分”
- str[4] = (time[1]&0x0F) + '0';
- str[5] = ':';
- str[6] = (time[0] >> 4) + '0'; //“秒”
- str[7] = (time[0]&0x0F) + '0';
- str[8] = '\0';
- LcdShowStr(4, 1, str); //顯示到液晶的第二行
- psec = time[0]; //用當(dāng)前值更新上次秒數(shù)
- void BusDelay()
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- /* 發(fā)送一個(gè)字節(jié)到DS1302通信總線上 */
- void DS1302ByteWrite(unsigned char dat)
- unsigned char mask;
- for (mask=0x01; mask!=0; mask<<=1) //低位在前,逐位移出
- if ((mask&dat) != 0) //首先輸出該位數(shù)據(jù)
- DS1302_IO = 1;
- else
- DS1302_IO = 0;
- DS1302_CK = 1; //然后拉高時(shí)鐘
- BusDelay();
- DS1302_CK = 0; //再拉低時(shí)鐘,完成一個(gè)位的操作
- DS1302_IO = 1; //最后確保釋放IO引腳
- /* 由DS1302通信總線上讀取一個(gè)字節(jié) */
- unsigned char DS1302ByteRead()
- unsigned char dat = 0;
- for (mask=0x01; mask!=0; mask<<=1) //低位在前,逐位讀取
- if (DS1302_IO != 0) //首先讀取此時(shí)的IO引腳,并設(shè)置dat中的對(duì)應(yīng)位
- dat |= mask;
- BusDelay();
- return dat; //最后返回讀到的字節(jié)數(shù)據(jù)
- /* 用單次寫操作向某一寄存器寫入一個(gè)字節(jié),reg-寄存器地址,dat-待寫入字節(jié) */
- void DS1302SingleWrite(unsigned char reg, unsigned char dat)
- DS1302_CE = 1; //使能片選信號(hào)
- DS1302ByteWrite((reg<<1)|0x80); //發(fā)送寫寄存器指令
- DS1302ByteWrite(dat); //寫入字節(jié)數(shù)據(jù)
- DS1302_CE = 0; //除能片選信號(hào)
- /* 用單次讀操作從某一寄存器讀取一個(gè)字節(jié),reg-寄存器地址,返回值-讀到的字節(jié) */
- unsigned char dat;
- DS1302ByteWrite((reg<<1)|0x81); //發(fā)送讀寄存器指令
- dat = DS1302ByteRead(); //讀取字節(jié)數(shù)據(jù)
- return dat;
- /* DS1302初始化,如發(fā)生掉電則重新設(shè)置初始時(shí)間 */
- void InitDS1302()
- unsigned char i;
- unsigned char code InitTime[] = {
- 0x70,0x30,0x07, 0x30, 0x05, 0x06, 0x21
- DS1302_CE = 0; //初始化DS1302通信引腳
- DS1302_CK = 0;
- i = DS1302SingleRead(0); //讀取秒寄存器
- if ((i & 0x80) != 0) //由秒寄存器最高位CH的值判斷DS1302是否已停止
- DS1302SingleWrite(7, 0x00); //撤銷寫保護(hù)以允許寫入數(shù)據(jù)
- for (i=0; i<7; i++) //設(shè)置DS1302為默認(rèn)的初始時(shí)間
- DS1302SingleWrite(i, InitTime[i]);
- /* 配置并啟動(dòng)T0,ms-T0定時(shí)時(shí)間 */
- unsigned long tmp; //臨時(shí)變量
- AUXR=0x80; //不分頻
- tmp = 33177600; //定時(shí)器計(jì)數(shù)頻率
- tmp = (tmp * ms) / 1000; //計(jì)算所需的計(jì)數(shù)值
- tmp = 65536 - tmp; //計(jì)算定時(shí)器重載值
- tmp = tmp + 28; //補(bǔ)償中斷響應(yīng)延時(shí)造成的誤差
- T0RH = (unsigned char)(tmp>>8); //定時(shí)器重載值拆分為高低字節(jié)
- T0RL = (unsigned char)tmp;
- TMOD &= 0xF0; //清零T0的控制位
- TMOD |= 0x01; //配置T0為模式1
- TH0 = T0RH; //加載T0重載值
- TL0 = T0RL;
- ET0 = 1; //使能T0中斷
- TR0 = 1; //啟動(dòng)T0
- /* T0中斷服務(wù)函數(shù),執(zhí)行200ms定時(shí) */
- void InterruptTimer0() interrupt 1
- static unsigned int tmr200ms = 0;
- TH0 = T0RH; //重新加載重載值
- TL0 = T0RL;
- tmr200ms++;
- if (tmr200ms >= 200) //定時(shí)200ms
- tmr200ms = 0;
- flag200ms = 1;
復(fù)制代碼 |
