查看: 1373|回復(fù): 0
單片機(jī)八鍵電子琴源程序
ID:169534 發(fā)表于 2020-7-8 04:48 | 顯示全部樓層 |閱讀模式
#include <reg52.H>
sbit SPEAKER  = P3^7;
#define KEY  P1
unsigned char MUSIC;
unsigned char STH0;
unsigned char STL0;
unsigned int code tab[]={
64021,64103,64260,64400,//低音3開始
64524,64580,64684,64777,
64820,64898,64968,65030,
65058,65110,65157,65178
void main(void){
        TMOD=0x01;
        ET0=1;
        EA=1;
        KEY = 0xff;
        while(1){
                if(KEY != 0xff){
                switch (~KEY){//顯示的列位置
                                case 0x01://
                                        MUSIC = 7;
                                        break;//
                                case 0x02://
                                        MUSIC = 6;
                                        break;//
                                case 0x04://
                                        MUSIC = 5;
                                        break;//
                                case 0x08://
                                        MUSIC = 4;
                                        break;//
                                case 0x10://
                                        MUSIC = 3;
                                        break;//
                                case 0x20://
                                        MUSIC = 2;
                                        break;//
                                case 0x40://
                                        MUSIC = 1;
                                        break;//
                                case 0x80://
                                        MUSIC = 0;
                                        break;//
                    STH0=tab[MUSIC]/256;
                    STL0=tab[MUSIC]%256;
                    TR0=1;
                }else{
                    SPEAKER = 1;
                        TR0=0;
void t0(void) interrupt 1 using 0{
  TH0=STH0;
  TL0=STL0;
  SPEAKER=~SPEAKER;
