查看: 1670|回復(fù): 0
單片機(jī)滑移率計(jì)算程序與Proteus仿真電路圖,方波做輪速信號(hào)
基于51單片機(jī),對(duì)方波信號(hào)的提取作為輪速信號(hào),再與選擇車速結(jié)合,計(jì)算當(dāng)前滑移率,并且將當(dāng)前滑移率,車速,輪速顯示在數(shù)碼管上,所有東西都在附件上
  1. #include <REG51.H>
  2. #define uint unsigned int
  4. sbit g=P2^3;
  5. sbit s=P2^2;
  6. sbit b=P2^1;
  7. sbit q=P2^0;
  8. sbit cs=P1^0;
  9. sbit ls=P1^1;
  10. sbit hy=P1^2;
  11. sbit cs1=P1^4;
  12. sbit cs2=P1^5;
  13. sbit cs3=P1^6;
  14. sbit LED1=P2^5;
  15. sbit LED2=P2^6;
  16. sbit LED3=P2^7;
  17. int num=0;int t=0;int count=0;int n1;int n2;int n3;
  18. unsigned char code dispcode1[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//段碼 陰碼
  19. unsigned char code dispcode[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};//段碼 陽(yáng)碼
  20. void delay(int z)
  21. {
  22.   int x,y;
  23.   for(x=z;x>0;x--)
  24.   for(y=110;y>0;y--);
  25. }
  26. //*****輪速*****//
  27. void init()
  28. {
  29. TMOD=0x01;//定義T0定時(shí)方式1
  30. TH0=(65536-50000)/256;
  31. TL0=(65536-50000)%256;//50ms計(jì)時(shí)
  32. TR0=1;//啟動(dòng)定時(shí)
  33. IT0=1;//下降沿觸發(fā)
  34. EX0=1;//允許外部中斷
  35.
  36. ET0=1;//外部中斷啟動(dòng)
  37. EA=1;//啟動(dòng)總中斷
  38. }
  39.
  40. void inter0() interrupt 0
  41. {
  42.    count++;
  43. }
  44. void timer0() interrupt 1
  45. {
  46.    t++;
  47.    if(t==2)
  48.    {
  49.     t=0;
  50.     n1=count ;
  51.         count=0;
  52.     }
  53.    TH0=(65536-50000)/256;
  54.    TL0=(65536-50000)%256;
  55. }
  56. //*****車速*****//
  57. void chesu()
  58. {
  59.    if(cs1==0)
  60.         {n2=60;}
  61.    else if(cs2==0)
  62.     {n2=90;}
  63.    else if(cs3==0)
  64.     {n2=120;}
  65. }
  66. //*****滑移率*****//
  67. void huayi()
  68. {
  69. n3=((n2-n1)*100)/n2;
  70. P2=0x00;
  71. if(n3>22)
  72. {LED1=1;}
  73. else if(n3>18)
  74. {LED2=1;}
  75. else if(n3<18)
  76. {LED3=1;}
  77. }
  78. //******顯示*****//
  79. void display(int n)
  80. {
  81. int ge,shi,bai,qian;
  82.   qian=n/1000;//千位
  83.   bai=n%1000/100;//百位
  84.   shi=n%100/10;//十位
  85.   ge=n%10;//個(gè)位
  86.    q=0;
  87.    P0=dispcode[qian];
  88.    delay(10);
  89.    q=1;
  90.    b=0;
  91.    P0=dispcode[bai];
  92.    delay(10);
  93.    b=1;
  94.    s=0;
  95.    P0=dispcode[shi];
  96.    delay(10);
  97.    s=1;
  98.    g=0;
  99.    P0=dispcode[ge];
  100. ……………………
  101. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
2.zip (94.12 KB, 下載次數(shù): 9)
