數(shù)據(jù)手冊
US-015是US-020模塊的升級版本,和US-020兼容,以前US-020的測試程序US-015也適用。
US-015超聲波測距模塊例程與US-020的測試?yán)滔嗤?br />
電路原理圖如下:
單片機源程序如下:
- #include "US020Test.h"
- void Delay1Ms(void);
- void Delay5Ms(void);
- void Delay400Ms(void);
- void UART_ISR(void);
- void UARTSnd(unsigned char dat);
- void UART_init();
- void init(void);
- sbit RCK_STMM = P2^7;
- sbit DIO_DS = P2^6;
- sbit SCK_SHBit = P2^5;
- sbit Trig_Mode = P2^0;
- sbit UART_Mode = P2^1;
- sbit UART_TEMP = P2^2;
- sbit Trig_Pin = P1^7;
- sbit Echo_Pin = P1^6;
- void InitIOPort()
- // P0M1 = 0XFF //p0口設(shè)為輸入。
- P0M1 = 0;//P0口設(shè)為雙向口,可輸入輸出
- P0M2 = 0;//P0口設(shè)為雙向口,可輸入輸出
- P2M1 &= 0X0F;//P2口的P2.5,P2.6,P2.7設(shè)為雙向口,可輸入輸出
- P2M2 &= 0X0F;//P2口的P2.5,P2.6,P2.7設(shè)為雙向口,可輸入輸出
- void DisplayLED(unsigned char LEDid, unsigned char Value, unsigned char Isdot)
- unsigned char tempa, tempb;
- unsigned char tempc, tempd;
- const unsigned char NumValue[11] = {0X40, 0X79, 0X24, 0X30, 0X19, 0X12, 0X02, 0X78, 0X00, 0X10, 0X3F};//0, 1, 2, 3, 4, 5, 6, 7, 8, 9, -.
- tempa = 1;
- tempa <<= (LEDid-1);
- if(Value >= 11)//value should little than 10
- Value = 0;
- tempb = NumValue[Value];
- if(Isdot == 0)
- tempb += 0X80;
- //begin output
- tempd = 0X80;
- for(tempc = 0; tempc < 8; tempc++)
- SCK_SHBit = 0;
- SCK_SHBit = 0;
- DIO_DS = (tempa&tempd);
- SCK_SHBit = 1;
- SCK_SHBit = 1;
- tempd >>= 1;
- tempd = 0X80;
- SCK_SHBit = 0;
- SCK_SHBit = 0;
- DIO_DS = (tempb&tempd);
- SCK_SHBit = 1;
- SCK_SHBit = 1;
- tempd >>= 1;
- RCK_STMM = 0;
- RCK_STMM = 0;
- RCK_STMM = 0;
- RCK_STMM = 0;
- RCK_STMM = 1;
- RCK_STMM = 1;
- RCK_STMM = 1;
- RCK_STMM = 1;
- //Delay1Ms();
- void DisplayLength(unsigned long number)
- unsigned char Thousand, Hundred, Decade, Unit;
- if(number > 9999)
- number = 0;
- Thousand = number/1000;
- number = number%1000;
- Hundred = number/100;
- number = number%100;
- Decade = number/10;
- Unit = number%10;
- DisplayLED(1, Thousand, 0);
- DisplayLED(2, Hundred, 0);
- DisplayLED(3, Decade, 0);
- DisplayLED(4, Unit, 0);
- unsigned long MeterByTrig()
- unsigned char tempa;
- unsigned char IsOverFlow;
- unsigned long PresentTime, tempb;
- IsOverFlow = 0;
- //Delay1Ms();
- P1M1 &= 0X7F;
- P1M2 &= 0X7F;
- P1M1 |= 0X40;
- P1M2 &= 0XBF;
- //Timer Init
- TMOD = 0X11;
- TAMOD = 0X00;
- TCON = 0X00;
- TH1 = 0;
- TL1 = 0;
- Trig_Pin = 0;
- for(tempa = 0; tempa < 10; tempa++)
- Trig_Pin = 1;
- Trig_Pin = 0;
- while(1)
- if(Echo_Pin == 1)
- {//Start Timer;
- TCON = 0X40;//start timer
- break;
- if(TCON&0X80)
- IsOverFlow = 1;
- break;//overflow;
- while(1)
- if(Echo_Pin == 0)
- {//Stop Timer;
- TCON = 0X00;
- break;
- if(TCON&0X80)
- IsOverFlow = 1;
- break;//overflow;
- // unsigned long PresentTime, tempb;
- PresentTime = TH1;
- PresentTime <<= 0X08;
- PresentTime += TL1;
- tempb = PresentTime/137;
- PresentTime /= 7;//*3
- PresentTime -= tempb;//time, us
- tempb = PresentTime/150;
- PresentTime /= 3;
- PresentTime += tempb;
- //Delay1Ms();
- return PresentTime;
- void main(void)
- unsigned long PreLength;
- InitIOPort();
- while(1)
- PreLength = MeterByTrig();
- for(tempa = 0; tempa < 200; tempa++)
- DisplayLength(PreLength);
- //1ms延時
- unsigned long TempCyc = 90;//36865;//5552;
- while(TempCyc--);
- //5ms延時
- unsigned long TempCyc = 460;//36865;//5552;
- while(TempCyc--);
- //400ms延時
- unsigned char TempCycA = 80;//5;
- unsigned long TempCycB;
- while(TempCycA--)
- TempCycB=460;//50000; //7269;
- while(TempCycB--);
US-015使用說明書及例程.rar
(2.14 MB, 下載次數(shù): 15)
2021-4-7 16:23 上傳
點擊文件名下載附件
