以AT89C52為主控芯片,以DHT11為溫濕度傳感器,用LCD1602顯示數(shù)值,當(dāng)濕度過高時(shí),啟動電風(fēng)扇(用L298N驅(qū)動直流電機(jī)模擬),當(dāng)溫度過低時(shí),啟動電熱管(用OVEN器件模擬)
Proteus8.6
- #include <reg52.h> /////////////頭文件
- sbit IN1 = P2^3;
- sbit IN2 = P2^4;
- sbit ENA = P2^5;
- sbit Res = P2^6; //電熱絲控制口
- sbit Key = P2^7; //模擬光電門
- void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
- void ConfigTimer0(unsigned int ms);
- unsigned char IntToString(unsigned char *str, int dat);
- extern void LcdWriteCmd(unsigned char cmd);
- extern void LcdWriteDat(unsigned char dat);
- extern bit Start18B20();
- extern bit Get18B20Temp(int *temp);
- extern void InitLcd1602();
- bit DHT_Start();
- bit DHT_ByteRead(unsigned char *dat);
- ///////////////////////////// 數(shù)組命名
- int Humity,Tempature,x;
- int Count = 0; //工具計(jì)數(shù)值
- bit flag1s = 0; //1s定時(shí)標(biāo)志
- unsigned char T0RH = 0; //T0重載值的高字節(jié)
- unsigned char T0RL = 0; //T0重載值的低字節(jié)
- ///////////////////////////////// 延時(shí)子程序
- void delay()
- x=99999;
- while(x--);
- void Key_Scan( void )
- if( Key == 0 )
- delay();
- if( Key == 0 )
- Count++;
- if( Count > 20 )
- Count = 0;
- while(!Key);
- void main() ////////////////主程序
- int Tempature = 0;
- int Humidy = 0;
- bit tmp;
- unsigned char Decade = 0;
- unsigned char Digtal = 0;
- unsigned char str[12];
- unsigned char DHT[5];
- ////初始化///////////////////////
- EA = 1; //開總中斷
- ConfigTimer0(10); //T0定時(shí)10ms
- InitLcd1602(); //初始化液晶
- DHT_Start();
- delay();
- delay();
- delay();
- delay();
- ENA = 0;
- IN1 = 1;
- IN2 = 0;
- Res = 0;
- LcdShowStr(0, 0, "Temp:"); //顯示到液晶屏上
- LcdShowStr(0, 1, "Humi:"); //顯示到液晶屏上
- LcdShowStr(8, 0, "Num:"); //顯示到液晶屏上
- while (1)
- if (flag1s) //每秒更新一次溫度
- DHT_Start();
- tmp=DHT_ByteRead(&DHT);
- if(tmp==1)
- str[0] = (DHT[0]/10)%10 + '0'; //十位轉(zhuǎn)為ASCII碼
- str[1] = (DHT[0]%10) + '0'; //個(gè)位轉(zhuǎn)為ASCII
- LcdShowStr(5, 1, str);
- str[0] = (DHT[2]/10)%10 + '0'; //十位轉(zhuǎn)為ASCII碼
- str[1] = (DHT[2]%10) + '0'; //個(gè)位轉(zhuǎn)為ASCII
- str[2] = '\0';
- LcdShowStr(5,0, str);
- Tempature= DHT[2];
- Humity=DHT[0];
- if( Tempature >= 24 )
- Res = 0;
- else if ( Tempature < 24 )
- Res = 1;
- if( Humity >= 60 )
- ENA = 1;
- else if ( Humity < 60 )
- ENA = 0;
- Key_Scan();
- Decade = Count/10;
- Digtal = Count%10;
- LcdWriteCmd(0x80+12);
- LcdWriteDat(0x30+Decade);
- LcdWriteDat(0x30+Digtal);
- /* 整型數(shù)轉(zhuǎn)換為字符串,str-字符串指針,dat-待轉(zhuǎn)換數(shù),返回值-字符串長度 */
- signed char i = 0;
- unsigned char len = 0;
- unsigned char buf[6];
- if (dat < 0) //如果為負(fù)數(shù),首先取絕對值,并在指針上添加負(fù)號
- dat = -dat;
- *str++ = '-';
- len++;
- do { //先轉(zhuǎn)換為低位在前的十進(jìn)制數(shù)組
- buf[i++] = dat % 10;
- dat /= 10;
- } while (dat > 0);
- len += i; //i最后的值就是有效字符的個(gè)數(shù)
- while (i-- > 0) //將數(shù)組值轉(zhuǎn)換為ASCII碼反向拷貝到接收指針上
- *str++ = buf[i] + '0';
- *str = '\0'; //添加字符串結(jié)束符
- return len; //返回字符串長度
- /* 配置并啟動T0,ms-T0定時(shí)時(shí)間 */
- unsigned long tmp; //臨時(shí)變量
- tmp = 11059200 / 12; //定時(shí)器計(jì)數(shù)頻率
- tmp = (tmp * ms) / 1000; //計(jì)算所需的計(jì)數(shù)值
- tmp = 65536 - tmp; //計(jì)算定時(shí)器重載值
- tmp = tmp + 12; //補(bǔ)償中斷響應(yīng)延時(shí)造成的誤差
- T0RH = (unsigned char)(tmp>>8); //定時(shí)器重載值拆分為高低字節(jié)
- T0RL = (unsigned char)tmp;
- TMOD &= 0xF0; //清零T0的控制位
- TMOD |= 0x01; //配置T0為模式1
- TH0 = T0RH; //加載T0重載值
- TL0 = T0RL;
- ET0 = 1; //使能T0中斷
- TR0 = 1; //啟動T0
- /* T0中斷服務(wù)函數(shù),完成1秒定時(shí) */
- void InterruptTimer0() interrupt 1
- static unsigned char tmr1s = 0;
- TH0 = T0RH; //重新加載重載值
- TL0 = T0RL;
- tmr1s++;
- if (tmr1s >= 100) //定時(shí)1s
- tmr1s = 0;
- flag1s = 1;
仿真51hei下載地址:
溫濕度檢測.zip
(208.99 KB, 下載次數(shù): 78)
2021-4-14 20:53 上傳
點(diǎn)擊文件名下載附件
