調(diào)整電位器的阻值改變模擬輸入電壓
完成對ADC0809(模數(shù)轉(zhuǎn)換器)的兩個通道的輸入模擬量進行轉(zhuǎn)換,兩個通道的結(jié)果顯示各占3位,同時顯示在8位數(shù)碼管上(有效顯示位數(shù)為6位)。兩個通道的采集模擬輸入電壓的大小由兩個滑動電位器來調(diào)節(jié),后續(xù)也可以換成溫度傳感器,光線傳感器,紅外傳感器等各種傳感器,可構(gòu)成測量不同變量的檢測電路。
單片機源程序如下:
- #include <reg51.h>
- #define uchar unsigned char
- sbit dula=P2^0;
- sbit wela=P2^1;
- sbit CLK=P1^3;
- sbit ST=P1^2;
- sbit OE=P1^0;
- sbit EOC=P1^1;
- sbit wei1=P2^1;
- sbit wei2=P2^2;
- sbit wei3=P2^3;
- sbit wei4=P2^5;
- sbit wei5=P2^6;
- sbit wei6=P2^7;
- uchar code dulatab[]={0x3f,0x06,0x5b,0x4f,0x66,
- 0x6d,0x7d,0x07,0x7f,0x6f,0x40}; //數(shù)字編碼0-9
- uchar code welatab[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//位控制字
- uchar count;
- void delay(uchar time) //延時
- uchar i,j;
- for(i=0;i<time;i++)
- for(j=0;j<110;j++)
- /*********系統(tǒng)初始化***********/
- void init()
- P2=0xff;
- EA = 1; //開總中斷
- TMOD = 0x02; //設(shè)定定時器T0工作方式
- TH0=216; //利用T0中斷產(chǎn)生CLK信號
- TL0=216; //定時40us頻率25K
- TR0=1; //啟動定時器T0
- ET0=1;
- ST=0;
- OE=0;
- P1=0x30;
- void write1(uchar num)
- uchar i,j,k;
- k=num/100;
- j=num%100/10;
- i=num%10;
- P2=0xff;
- P0=dulatab[k];
- wei4=0;
- delay(4);
- P2=0xff;
- P0=dulatab[j];
- wei5=0;
- delay(4);
- P2=0xff;
- P0=dulatab[i];
- wei6=0;
- delay(4);
- void write0(uchar num)
- uchar i,j,k;
- k=num/100;
- j=num%100/10;
- i=num%10;
- P2=0xff;
- P0=dulatab[k];
- wei1=0;
- delay(4);
- P2=0xff;
- P0=dulatab[j];
- wei2=0;
- delay(4);
- P2=0xff;
- P0=dulatab[i];
- wei3=0;
- delay(4);
- uchar adin0()
- uchar value;
- OE=0;
- EOC=1;
- ST=0;
- P1&=0x8f;
- P1|=0x30;
- delay(10);
- ST=1;
- delay(10);
- ST=0;
- while(!EOC);
- // EOC=0;
- delay(10);
- OE=1;
- delay(1);
- value=P3;
- OE=0;
- return value;
- uchar adin1()
- uchar value;
- OE=0;
- EOC=1;
- ST=0;
- P1&=0x8f;
- P1|=0x00;
- delay(10);
- ST=1;
- delay(10);
- ST=0;
- while(!EOC);
- // EOC=0;
- delay(10);
- OE=1;
- delay(1);
- value=P3;
- OE=0;
- return value;
- void main()
- uchar in0,in1;
- init();
- while(1)
- in0=adin0();
- write0(in0);
- in1=adin1();
- write1(in1);
- void timer0(void) interrupt 1
- CLK=~CLK;
基于AT89C51的兩路數(shù)據(jù)采集.zip
(512.5 KB, 下載次數(shù): 93)
2021-5-17 17:37 上傳
點擊文件名下載附件
