#include <reg52.h>
#include <intrins.h>
sbit CS =P2^6;
sbit SCK=P2^7;
sbit SID=P2^5;
sbit PSB=P3^2;
sbit KEY_ADD=P3^0; //定義按鍵輸入端口
sbit KEY_DEC=P3^1;
unsigned char code AC_TABLE[]={
0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,
0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,
0x88,0x89,0x8a, 0x8b,0x8c,0x8d,0x8e,0x8f,
0x98,0x99,0x9a,0x9b,0x9c,0x9d,0x9e,0x9f,
//#define keyport P3
unsigned char curr,currold;//全局變量,當(dāng)前箭頭位置
unsigned char code user16x16[]={ //箭頭圖片
0x00,0x00,0x20,0x00,0x30,0x00,0x38,0x00,0x3C,0x00,0x3E,0x00,0x3F,0x00,0x3F,0x80,
0x3F,0xC0,0x3F,0x80,0x3F,0x00,0x3E,0x00,0x3C,0x00,0x38,0x00,0x30,0x00,0x20,0x00,
//☆(0)
unsigned char code star16x16[]={//五角星
0xBF,0x3F,0xBF,0xBF,0xBF,0x9F,0xE3,0xFC,0xE3,0x9F,0xBF,0xBF,0xBF,0x3F,0xBF,0xFF,
0xFF,0xFF,0xBE,0xC6,0xD9,0xEF,0xEF,0xF7,0xF7,0xEF,0xD9,0xC6,0xBE,0xFF,0xFF,0xFF};/*"☆",0*/
unsigned char code *MainMenu[]=
{"1.設(shè)置1"},
{"2.設(shè)置2"},
{"3.設(shè)置3"},
{"4.設(shè)置4"},
{"5.設(shè)置5"},
{"6.設(shè)置6"},
{"7.設(shè)置7"},
{"8.設(shè)置8"},
{"9.設(shè)置9"},
{"10. 設(shè)置10"},
延時
void DelayUs2x(unsigned char t)
while(--t);
void DelayMs(unsigned char t)
while(t--)
//大致延時1mS
DelayUs2x(245);
DelayUs2x(245);
發(fā)送
void SendByte(unsigned char Dbyte)
unsigned char i;
for(i=0;i<8;i++)
SCK = 0;
Dbyte=Dbyte<<1;
SID = CY;
SCK = 1;
SCK = 0;
接收
unsigned char ReceiveByte(void)
unsigned char i,temp1,temp2;
temp1=temp2=0;
for(i=0;i<8;i++)
temp1=temp1<<1;
SCK = 0;
SCK = 1;
SCK = 0;
if(SID) temp1++;
for(i=0;i<8;i++)
temp2=temp2<<1;
SCK = 0;
SCK = 1;
SCK = 0;
if(SID) temp2++;
return ((0xf0&temp1)+(0x0f&temp2));
忙檢測
void CheckBusy( void )
do SendByte(0xfc); //11111,RW(1),RS(0),0
while(0x80&ReceiveByte());
寫指令
void WriteCommand( unsigned char Cbyte )
CS = 1;
CheckBusy();
SendByte(0xf8); //11111,RW(0),RS(0),0
SendByte(0xf0&Cbyte);
SendByte(0xf0&Cbyte<<4);
CS = 0;
寫數(shù)據(jù)
void WriteData( unsigned char Dbyte )
CS = 1;
CheckBusy();
SendByte(0xfa); //11111,RW(0),RS(1),0
SendByte(0xf0&Dbyte);
SendByte(0xf0&Dbyte<<4);
CS = 0;
延時
void delay(unsigned int MS)
unsigned char us,usn;
while(MS!=0) //for 12M
{ usn = 2;
while(usn!=0)
us=0xf5;
while (us!=0){us--;};
usn--;
MS--;
12864初始化
void LcmInit( void )
WriteCommand(0x30);
WriteCommand(0x03);
WriteCommand(0x0C);
WriteCommand(0x01);
WriteCommand(0x06);
清屏
void ClrScreen()
WriteCommand(0x01);
DelayMs(15);
/*void LcmClearTXT( void )
unsigned char i;
WriteCommand(0x30);
WriteCommand(0x80);
for(i=0;i<64;i++)
WriteData(0x20);
void LcmClearBMP( void )
unsigned char i,j;
WriteCommand(0x34);
WriteCommand(0x36);
for(i=0;i<32;i++)
WriteCommand(0x80|i);
WriteCommand(0x80);
for(j=0;j<32;j++)
WriteData(0);
字符串
void PutStr(unsigned char x,unsigned char y,unsigned char code *s)
switch(y)
case 1: WriteCommand(0x80+x);break;
case 2: WriteCommand(0x90+x);break;
case 3: WriteCommand(0x88+x);break;
case 4: WriteCommand(0x98+x);break;
default:break;
while(*s>0)
WriteData(*s);
s++;
DelayUs2x(50);
圖片
void PutBMP(unsigned char *puts)
unsigned int x=0;
unsigned char i,j;
WriteCommand(0x34);
WriteCommand(0x36);
for(i=0;i<32;i++)
WriteCommand(0x80);
for(j=0;j<32;j++)
WriteData(puts[x]);
x++;
用戶自定義字符
void CGRAM()
int i;
WriteCommand(0x30);
WriteCommand(0x40);
for(i=0;i<16;i++)
WriteData(user16x16[i*2]);
WriteData(user16x16[i*2+1]);
void STRAM()
int i;
WriteCommand(0x30);
WriteCommand(0x40);
for(i=0;i<16;i++)
WriteData(star16x16[i*2]);
WriteData(star16x16[i*2+1]);
顯示用戶自定義字符
void DisplayCGRAM(unsigned char x,unsigned char y)
switch(y)
default:break;
WriteData(00);
WriteData(00);
調(diào)用顯示更新
void DisplayUpdata(void)
unsigned char num;
ClrScreen();
num=sizeof(MainMenu)/sizeof(MainMenu[0]);//判斷數(shù)組中數(shù)值個數(shù)
if((0+(curr/4)*4)<num)
PutStr(0,1,MainMenu[0+(curr/4)*4]);
else //如果超出數(shù)組最大元素,則寫空信息,不判斷此信息可能會出現(xiàn)亂碼
PutStr(0,1,"");
if((1+(curr/4)*4)<num)
PutStr(0,2,MainMenu[1+(curr/4)*4]);
PutStr(0,2,"");
if((2+(curr/4)*4)<num)
PutStr(0,3,MainMenu[2+(curr/4)*4]);
PutStr(0,3,"");
if((3+(curr/4)*4)<num)
PutStr(0,4,MainMenu[3+(curr/4)*4]);
PutStr(0,4,"");
DisplayCGRAM(0,curr%4+1);
void main( void )
PSB=0;
LcmInit();
PutStr(0,0,*MainMenu);//開機(jī)界面
DisplayUpdata();
delay(10);
if(curr!=currold) //光標(biāo)位置變化,則更新顯示
DisplayUpdata();
currold=curr;
if(KEY_ADD == 0)
delay(10);
if(KEY_ADD == 0)
while (KEY_ADD == 0);
if(curr<sizeof(MainMenu)/sizeof(MainMenu[0])-1)
curr++;
if (KEY_DEC == 0)
delay(10);
if(KEY_DEC == 0)
while (KEY_DEC == 0);
if(curr>0)
curr--;
//end while
}//end main
Keil代碼下載:
1.zip
(48.02 KB, 下載次數(shù): 21)
2022-1-7 08:47 上傳
點擊文件名下載附件
