查看: 1011|回復: 6
error C141: syntax error near '[', expected ')'
ID:1043127 發(fā)表于 2022-8-28 14:44 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
大佬們可以幫我看看這個錯誤怎么改嗎,就這一個錯生成不了
111.c(10): error C141: syntax error near '[', expected ')'
這是代碼
#include <reg52.h>
#include<intrins.h>
#include"1602.h"
unsigned long num = 0,time = 0;
unsigned char dis1[]={"Welcome!"};
unsigned char dis2[]={"heart rate:"};
unsigned long LcdOut[4];
unsigned long rate;
unsigned long lcd_init();
unsigned long lcd_wdat(dis1[ i]);[ i]
void Timer0() interrupt 1
        TH0 = 0x0D8;         //10ms????
TL0 = 0x0F0;
        time++;                  //time????,?????
void exint0() interrupt 0                //????0
           if(num==0)                 //?????????,???????R?
                ET0=1;
    TR0 = 1;         //?????????
                rate=0;                 //?????0???
        num++;                 //??????,num??,?R???
  unsigned char i = 0;
  //??????0
  TMOD = 0x01;
  TL0 = 0x0F0;
  IT0 = 1;                  //????0?????
  EA = 1;             //?????
  EX0 = 1;                 //??????0
  lcd_init();                                //???LCD
  delay(10);
  lcd_pos(4);                                //????????????5???
        while(dis1[ i] != '\0')[ i]
        {                                                //????"welcome!"
                i++;
  delay(2000);         //??2?,??????
  //?????? heart rate: ??
  lcd_init();
  i = 0;
  lcd_pos(1);                                //????????????1???
        while(dis2[ i] != '\0')[ i]
        {                                                //????"welcome!"
                lcd_wdat(dis2[ i]);[ i]
                i++;
          if(num>=3)
                rate = 6000*2/time;        //????(?/??),?2?R-R?????????
                num=1;time=0;                        //?0(1)??,????????2?RR??
//????????RR?????????,?????????,????,???????????
                  //?LCD1602?????
                  LcdOut[0]=rate%1000/100+0x30;
     LcdOut[1]=rate%100/10+0x30;
     LcdOut[2]=rate%10+0x30;
                  for( i=0; i<3; i++)
                lcd_pos(i+0x43);                //????????2?
                lcd_wdat(LcdOut[ i]);[ i]
ID:1043127 發(fā)表于 2022-8-28 14:46 | 只看該作者
unsigned long lcd_wdat(dis1);這行的錯誤
ID:883242 發(fā)表于 2022-8-28 16:25 | 只看該作者
ID:94031 發(fā)表于 2022-8-28 18:42 | 只看該作者
程序沒給全。
ID:59202 發(fā)表于 2022-8-28 20:52 | 只看該作者
不是說的很清楚了嗎?第10行語句有語法錯誤,轉到第10行:unsigned long lcd_wdat(dis1[ i]);[ i]一看不就發(fā)現(xiàn)語句末分號后面多了個[i],這種keil軟件的錯誤提示看不懂就查百度啊
ID:1023753 發(fā)表于 2022-8-29 07:45 | 只看該作者
復制的程序,好多錯誤  不止這一處,都需要改
ID:824490 發(fā)表于 2022-8-29 17:42 | 只看該作者
百度翻譯是個好工具,你值得擁有!
