謝謝回復(fù),整個程序如下,請問哪里可以BUFMOVE1是指針類型?不是bufMove1+index整體作為指針類型嗎?bufMove1不是這個16+sizeof(str1)+16范圍了嗎?再加上index是什么意思?不明白bufMove1+index是抽取了哪一段字符?
#include <reg52.h>
#define LCD1602_DB P0
sbit LCD1602_RS = P1^0;
sbit LCD1602_RW = P1^1;
sbit LCD1602_E = P1^5;
bit flag500ms = 0; //500ms 定時標(biāo)志
unsigned char T0RH = 0; //T0 重載值的高字節(jié)
unsigned char T0RL = 0; //T0 重載值的低字節(jié)
//待顯示的第一行字符串
unsigned char code str1[] = "Kingst Studio";
//待顯示的第二行字符串,需保持與第一行字符串等長,較短的行可用空格補(bǔ)齊
unsigned char code str2[] = "Let's move...";
void ConfigTimer0(unsigned int ms);
void InitLcd1602();
void LcdShowStr(unsigned char x, unsigned char y,
unsigned char *str, unsigned char len);
unsigned char i;
unsigned char index = 0; //移動索引
unsigned char pdata bufMove1[16+sizeof(str1)+16]; //移動顯示緩沖區(qū) 1
unsigned char pdata bufMove2[16+sizeof(str2)+16]; //移動顯示緩沖區(qū) 2
EA = 1; //開總中斷
ConfigTimer0(10); //配置 T0 定時 10ms
InitLcd1602(); //初始化液晶
//緩沖區(qū)開頭一段填充為空格
for (i=0; i<16; i++)
bufMove1 = ' ';
bufMove2 = ' ';
//待顯示字符串拷貝到緩沖區(qū)中間位置
for (i=0; i<(sizeof(str1)-1); i++)
bufMove1[16+i] = str1;
bufMove2[16+i] = str2;
//緩沖區(qū)結(jié)尾一段也填充為空格
for (i=(16+sizeof(str1)-1); i<sizeof(bufMove1); i++)
bufMove1 = ' ';
bufMove2 = ' ';
while (1)
if (flag500ms) //每 500ms 移動一次屏幕
flag500ms = 0;
//從緩沖區(qū)抽出需顯示的一段字符顯示到液晶上
LcdShowStr(0, 0, bufMove1+index, 16);
LcdShowStr(0, 1, bufMove2+index, 16);
//移動索引遞增,實(shí)現(xiàn)左移
index++;
if (index >= (16+sizeof(str1)-1))
{ //起始位置達(dá)到字符串尾部后即返回從頭開始
index = 0;
/* 配置并啟動 T0,ms-T0 定時時間 */
unsigned long tmp; //臨時變量
tmp = 11059200 / 12; //定時器計數(shù)頻率
tmp = (tmp * ms) / 1000; //計算所需的計數(shù)值
tmp = 65536 - tmp; //計算定時器重載值
tmp = tmp + 12; //補(bǔ)償中斷響應(yīng)延時造成的誤差
T0RH = (unsigned char)(tmp>>8); //定時器重載值拆分為高低字節(jié)
T0RL = (unsigned char)tmp;
TMOD &= 0xF0; //清零 T0 的控制位
TMOD |= 0x01; //配置 T0 為模式 1
TH0 = T0RH; //加載 T0 重載值
TL0 = T0RL;
ET0 = 1; //使能 T0 中斷
TR0 = 1; //啟動 T0
/* 等待液晶準(zhǔn)備好 */
void LcdWaitReady()
unsigned char sta;
LCD1602_DB = 0xFF;
LCD1602_RS = 0;
LCD1602_RW = 1;
do {
LCD1602_E = 1;
sta = LCD1602_DB; //讀取狀態(tài)字
LCD1602_E = 0;
} while (sta & 0x80); //bit7 等于 1 表示液晶正忙,重復(fù)檢測直到其等于 0 為止
/* 向 LCD1602 液晶寫入一字節(jié)命令,cmd-待寫入命令值 */
void LcdWriteCmd(unsigned char cmd)
LcdWaitReady();
LCD1602_RS = 0;
LCD1602_RW = 0;
LCD1602_DB = cmd;
LCD1602_E = 1;
LCD1602_E = 0;
/* 向 LCD1602 液晶寫入一字節(jié)數(shù)據(jù),dat-待寫入數(shù)據(jù)值 */
void LcdWriteDat(unsigned char dat)
LcdWaitReady();
LCD1602_RS = 1;
LCD1602_RW = 0;
LCD1602_DB = dat;
LCD1602_E = 1;
LCD1602_E = 0;
/* 設(shè)置顯示 RAM 起始地址,亦即光標(biāo)位置,(x,y)-對應(yīng)屏幕上的字符坐標(biāo) */
void LcdSetCursor(unsigned char x, unsigned char y)
unsigned char addr;
if (y == 0) //由輸入的屏幕坐標(biāo)計算顯示 RAM 的地址
addr = 0x00 + x; //第一行字符地址從 0x00 起始
addr = 0x40 + x; //第二行字符地址從 0x40 起始
LcdWriteCmd(addr | 0x80); //設(shè)置 RAM 地址
/* 在液晶上顯示字符串,(x,y)-對應(yīng)屏幕上的起始坐標(biāo),
str-字符串指針,len-需顯示的字符長度 */
LcdSetCursor(x, y); //設(shè)置起始地址
while (len--) //連續(xù)寫入 len 個字符數(shù)據(jù)
LcdWriteDat(*str++); //先取 str 指向的數(shù)據(jù),然后 str 自加 1
/* 初始化 1602 液晶 */
void InitLcd1602()
LcdWriteCmd(0x38); //16*2 顯示,5*7 點(diǎn)陣,8 位數(shù)據(jù)接口
LcdWriteCmd(0x0C); //顯示器開,光標(biāo)關(guān)閉
LcdWriteCmd(0x06); //文字不動,地址自動+1
LcdWriteCmd(0x01); //清屏
/* T0 中斷服務(wù)函數(shù),定時 500ms */
void InterruptTimer0() interrupt 1
static unsigned char tmr500ms = 0;
TH0 = T0RH; //重新加載重載值
TL0 = T0RL;
tmr500ms++;
if (tmr500ms >= 50)
tmr500ms = 0;
flag500ms = 1;
