大伙們我下面實(shí)現(xiàn)的功能是:按下第一個(gè)按鍵,從0加到80
按下第二個(gè)按鍵,從80減到10
按下第三個(gè)按鍵,顯示10
我下面的代碼當(dāng)按下第一個(gè)按鍵時(shí),會(huì)一直加到80,但是數(shù)碼管不能同時(shí)顯示這兩位,只能顯示一位,按下第二個(gè)按鍵也是一樣,第三個(gè)按鍵也是一樣
請大伙給個(gè)代碼例程或者給我講講哪些錯(cuò)誤的地方需要改,按鍵是由ADC來判斷的
- //段
- sbit pin_seg1 = P0^2;
- sbit pin_seg2 = P0^1;
- sbit pin_seg3 = P0^5;
- sbit pin_seg4 = P2^1;
- sbit pin_seg5 = P2^4;
- sbit pin_seg6 = P0^3;
- sbit pin_seg7 = P0^4;
- sbit pin_seg8 = P2^0;
- //位
- sbit pin_com1 = P1^7; //第一個(gè)數(shù)碼管
- sbit pin_com2 = P2^7; //第二個(gè)數(shù)碼管
- sbit pin_com3 = P2^5; //第三個(gè)數(shù)碼管
- sbit pin_com4 = P0^0; //第四個(gè)數(shù)碼管
- sbit pin_com5 = P1^6; //兩個(gè)點(diǎn)
- unsigned int ADCValue = 0x0000;
- bit AdcFlag = 0;
- //------------------------0,---1;-----2;----3;----4;----5;----6;----7;----8;----9;----10---11;--12;--13;---14;---15
- unsigned char code bcd[]={0x3f,0x30,0x5b,0x79,0x74,0x6d,0x6f,0x38,0x7f,0x7d,0x77,0x79,0x39,0x5e,0x4f,0x71};
- *函數(shù)名稱:void Delay_50us(unsigned int n)
- *函數(shù)功能:延時(shí)函數(shù)
- *入口參數(shù):n
- *出口參數(shù):void
- void Delay_50us(unsigned int n)
- unsigned char i;
- while(n--)
- for(i=0;i<15;i++);
- /**************************************ADC采樣口選擇*****************************************/
- #if (IC_MODEL == SC92F7323)
- enum Channel {AIN0=0,AIN1,AIN2,AIN3,AIN4,AIN5,AIN6,AIN7,AIN8,AIN9,VDD4=15};
- #endif
- #if (IC_MODEL == SC92F7322)
- enum Channel {AIN0=0,AIN1,AIN4=4,AIN5,AIN6,AIN7,AIN8,AIN9,VDD4=15};
- #endif
- #if (IC_MODEL == SC92F7321)
- enum Channel {AIN0=0,AIN1,AIN2,AIN3,AIN8=8,AIN9,VDD4=15};
- #endif
- #if (IC_MODEL == SC92F7320)
- enum Channel {AIN0=0,AIN1,AIN6=6,AIN7,VDD4=15};
- #endif
- *函數(shù)名稱:void ADC_Init(unsigned int Channel)
- *函數(shù)功能:ADC初始化
- *入口參數(shù):Channel
- *出口參數(shù):void
- void ADC_Init(unsigned int Channel)
- ADCCON = 0X80|Channel; //開啟ADC,ADC采樣頻率為2M ,選擇Channel位ADC采樣口
- if(Channel<8)
- ADCCFG0 = 1<<Channel; //設(shè)置Channel作為采樣口
- else
- ADCCFG1 = 1<<(Channel-8); //設(shè)置Channel作為采樣口
- IE |= 0X40; //開啟ADC中斷
- *函數(shù)名稱:void GetAdcValue(void)
- *函數(shù)功能:ADC測試
- *入口參數(shù):void
- *出口參數(shù):void
- *函數(shù)作用:獲取ADC的值
- unsigned int GetAdcValue(void)
- ADC_Init(AIN6); //設(shè)置通道6為ADC輸入
- ADCCON |= 0X40; //開始ADC轉(zhuǎn)換
- while(!AdcFlag); //等待 ADC轉(zhuǎn)換完成;
- AdcFlag = 0;
- ADCValue = (ADCVH<<4)+(ADCVL>>4);
- return ADCValue;
- void ADC_Interrupt(void) interrupt 6
- static unsigned char TIME1 = 0;
- ADCCON &= ~(0X10); //清中斷標(biāo)志位
- AdcFlag = 1;
- *函數(shù)名稱:void Seg_selection2(void)
- *函數(shù)功能:將傳進(jìn)來的num值,分別賦值給各個(gè)引腳
- *入口參數(shù):void
- *出口參數(shù):void
- void Seg_selection(unsigned char num) //num是a~h
- pin_seg1 = num & 0x01;num=num>>1; //num^0是a段
- pin_seg2 = num & 0x01;num=num>>1; //num^1是b段
- pin_seg3 = num & 0x01;num=num>>1; //num^2是c段
- pin_seg4 = num & 0x01;num=num>>1; //num^3是d段
- pin_seg5 = num & 0x01;num=num>>1; //num^4是e段
- pin_seg6 = num & 0x01;num=num>>1; //num^5是f段
- pin_seg7 = num & 0x01;num=num>>1; //num^6是g段
- pin_seg8 = num & 0x01;num=num>>1; //num^7是h段
- *函數(shù)名稱:void Pos_selection(void)
- *函數(shù)功能:點(diǎn)亮某一位數(shù)碼管
- *入口參數(shù):void
- *出口參數(shù):void
- void Pos_selection(unsigned char num) //num的1~5位分別對應(yīng)數(shù)碼管的1~5位
- pin_com1 = num & 0x01;num=num>>1; //num^0是第一個(gè)數(shù)碼管
- pin_com2 = num & 0x01;num=num>>1; //num^1是第二個(gè)數(shù)碼管
- pin_com3 = num & 0x01;num=num>>1; //num^2是第三個(gè)數(shù)碼管
- pin_com4 = num & 0x01;num=num>>1; //num^3是第四個(gè)數(shù)碼管
- pin_com5 = num & 0x01;num=num>>1; //num^4是第兩個(gè)點(diǎn)
- //數(shù)碼管處理顯示
- void Display(void)
- unsigned int Key_value;
- static unsigned char Current_num = 0;
- Key_value = GetAdcValue(); //獲取ADC的值
- if(Key_value > 2000 && Key_value < 2200) //第一個(gè)按鍵
- Current_num++;
- if(Current_num > 0 && Current_num < 80)
- Pos_selection(0x00); //消影
- Seg_selection(bcd[Current_num%10]); //顯示Current_num的個(gè)位
- Pos_selection(0x02); //第二位數(shù)碼管
- Delay_50us(2000);
- Seg_selection(bcd[Current_num/10]); //顯示Current_num的十位
- Pos_selection(0x01); //第一位數(shù)碼管
- Delay_50us(2000);
- else
- Current_num = 0;
- if(Key_value > 2600 && Key_value < 3000) //第二個(gè)按鍵
- Current_num--;
- if(Current_num > 10 && Current_num < 80)
- Delay_50us(2000);
- Delay_50us(2000);
- else
- Current_num = 0;
- if(Key_value > 3000 && Key_value < 3500) //第三個(gè)按鍵
- Seg_selection(0x30); //顯示1
- Delay_50us(2000); //延時(shí)
- Seg_selection(0x3F); //顯示1
- Pos_selection(0x02); //第一位數(shù)碼管
- void main(void)
- IO_Init();
- EA = 1;
- while(1)
- Display();
