我用stm32 ds18b20 四位數(shù)碼管顯示,測(cè)量?jī)鋈獾臏囟仁秦?fù)的。但是把凍肉拿開測(cè)量大氣溫度的時(shí)候,負(fù)號(hào)就去不掉了。
請(qǐng)各位大佬幫我看看到底怎么回事
#include "74hc595.h"
#include "SysTick.h"
#include "ds18b20.h"
u8 fg=1;
u16 sdata;
unsigned char xiaoshu1; //小數(shù)第一位
unsigned char xiaoshu2; //小數(shù)第二位
unsigned char xiaoshu; //兩位小數(shù)
u8 LED_table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff,0xbf};
//共陽(yáng)數(shù)碼管段碼“0123456789-”
u8 LED_table_dp[16]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10,0x08,0x03,0x46,0x21,0x06,0x0e};
u8 wei_table[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
//第一位至第八位位碼
void HC595_GPIO_Configuration(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
GPIO_InitStructure.GPIO_Pin = SCL | RCL | DIO;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(SMG_PROT, &GPIO_InitStructure);
GPIO_SetBits(SMG_PROT,SCL);
GPIO_SetBits(SMG_PROT,RCL);
GPIO_SetBits(SMG_PROT,DIO);
void HC595_Send_Byte(unsigned char byte)
u8 i;
for(i = 0; i < 8; i++)
if(byte & 0x80)
DIO_HIGH;
DIO_LOW;
SCL_LOW;
delay_us(10);
SCL_HIGH;
delay_us(10);
byte <<= 1;
void DS18B20_UserConfig()
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//推挽輸出是GPIO_Mode_Out_PP
GPIO_InitStructure.GPIO_Pin = DS18B20;//定義管腳
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
GPIO_Init(DS18B20_PROT,&GPIO_InitStructure);
//GPIO_ResetBits(SMG_PROT,SCL|RCL|DIO);
//輸入輸出模式選擇函數(shù)
void Output_Input_Mode(u8 cmd)
GPIO_InitTypeDef GPIO_InitStructure;//定義結(jié)構(gòu)體
if(cmd)
{//1:輸出模式
GPIO_InitStructure.GPIO_Pin = DS18B20;//PB0
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;//端口輸出速率
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//推挽輸出模式
{//0:輸入模式
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;//上拉模式
GPIO_Init(DS18B20_PROT,&GPIO_InitStructure);//初始串口
//啟動(dòng)信號(hào) 判斷是否成功
u8 DS18B20_Start_Signal(void)
u8 data;
//寫
Output_Input_Mode(1);//輸入模式
DS18B20_LOW;
delay_us(480);
DS18B20_HIGH;
delay_us(30);
//讀引腳狀態(tài) 1:DS18B20失敗 0:DS18B20成功
Output_Input_Mode(0);//輸出模式
data = GPIO_ReadInputDataBit(DS18B20_PROT,DS18B20);//讀取輸入狀態(tài) 60~240us
delay_us(200);//200us 480+30+240=750 960-750=210 取200us即可
return data;
//向DS18B20寫數(shù)據(jù)
//寫:輸出模式 1
void DS18B20_Write_Byte(u8 data)
for(u8 i=0;i<8;i++){
DS18B20_LOW;
delay_us(2);
((data&0x01)) ? DS18B20_HIGH : DS18B20_LOW;//DS18B20 低位先出,故&0x01
delay_us(45);
DS18B20_HIGH;//拉高總線
data>>=1;//數(shù)據(jù)右移八次 既完成寫8bit數(shù)據(jù)
//讀DS18B20數(shù)據(jù)
//讀:輸入模式 0
u8 DS18B20_Read_Byte(void)
u8 data=0;
data>>=1;
DS18B20_LOW;
delay_us(2);
DS18B20_HIGH;//拉高總線
if(GPIO_ReadInputDataBit(DS18B20_PROT,DS18B20) == SET){
data |= 0x80;//從高位開始
delay_us(45);
return data;
//獲取溫度值
void DS18B20_Read_Temperature()
u8 LSB = 0,MSB = 0;
u16 temp=0;
//溫度轉(zhuǎn)換
DS18B20_Start_Signal();
DS18B20_Write_Byte(0xcc);//跳過(guò)ROM
DS18B20_Write_Byte(0x44);//溫度變換
//delay_ms(750);
//12位精度 750ms 數(shù)碼管本身有延時(shí),故這個(gè)延時(shí)可以去掉
//讀取寄存器
DS18B20_Write_Byte(0xbe);//讀暫存存儲(chǔ)器
LSB = DS18B20_Read_Byte();//讀出溫度的低位LSB
MSB = DS18B20_Read_Byte();//讀出溫度的高位MSB
if(MSB>0x7f)
LSB=~LSB+1;
MSB=~MSB;
fg=0;
sdata = LSB/16+MSB*16; //整數(shù)部分
xiaoshu1 = (LSB&0x0f)*10/16; //小數(shù)第一位
xiaoshu2 = (LSB&0x0f)*100/16%10; //小數(shù)第二位
xiaoshu=xiaoshu1*10+xiaoshu2; //小數(shù)兩位
void SMG_Display(u16 data)
if(fg==1)
HC595_Send_Byte(LED_table[data/10]);//送出段碼
HC595_Send_Byte(wei_table[3]);//送出位碼
RCL_LOW;
RCL_HIGH;
delay_ms(1);
HC595_Send_Byte(LED_table_dp[data%10]);//送出段碼
HC595_Send_Byte(wei_table[2]);//送出位碼
RCL_LOW;
RCL_HIGH;
delay_ms(1);
HC595_Send_Byte(LED_table[xiaoshu1]);//送出段碼
HC595_Send_Byte(wei_table[1]);//送出位碼
RCL_LOW;
RCL_HIGH;
delay_ms(1);
HC595_Send_Byte(LED_table[xiaoshu2]);//送出段碼
HC595_Send_Byte(wei_table[0]);//送出位碼
RCL_LOW;
RCL_HIGH;
delay_ms(1);
if(fg==0)
HC595_Send_Byte(LED_table[11]);//送出段碼
RCL_LOW;
RCL_HIGH;
delay_ms(1);
RCL_LOW;
RCL_HIGH;
delay_ms(1);
HC595_Send_Byte(LED_table_dp[data %10]);//送出段碼
RCL_LOW;
RCL_HIGH;
delay_ms(1);
RCL_LOW;
RCL_HIGH;
delay_ms(1);
SystemInit();
SysTick_Init(72);
HC595_GPIO_Configuration();
DS18B20_UserConfig();
DS18B20_Read_Temperature();
SMG_Display(sdata);
