查看: 1421|回復: 1
單片機按鍵控制步進電機的程序修改
ID:978416 發(fā)表于 2023-2-21 14:59 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
寫了個按鍵控制步進電機的程序,按鍵控制正反轉和停止,但是因為用了延時導致按鍵不太好用,各位給看看要是用定時器實現(xiàn),需要怎么改一下,或者有什么更好,更簡潔的方法
單片機源程序如下:
#include "reg52.h"                         //此文件中定義了單片機的一些特殊功能寄存器
sbit MOTOA = P1^0;          //定義A極
sbit MOTOB = P1^1;          //定義B極
sbit MOTOC = P1^2;          //定義C極
sbit MOTOD = P1^3;          //定義D極
sbit key1  = P0^0;
sbit key2  = P0^1;
sbit key3  = P0^2;
sbit key4  = P0^3;
void keyscan();
#define SPEED 400
void delay(uint i)         //延時函數(shù)
        while(i--);
        P1=0X00;
        keyscan();
void keyscan()
        if(key1==0)
                delay(10);
                if(key1==0)
                MOTOA = 0;
                MOTOB = 0;
                MOTOC = 0;
                MOTOD = 0;
                delay(SPEED);//延時
                MOTOA = 0;
                MOTOB = 0;
                MOTOC = 0;
                MOTOD = 0;
                delay(SPEED);
                MOTOA = 0;
                MOTOB = 0;
                MOTOC = 0;
                MOTOD = 0;
                delay(SPEED);
                MOTOA = 0;
                MOTOB = 0;
                MOTOC = 0;
                MOTOD = 0;
                delay(SPEED);
                if(key2==0||key3==0||key4==0)break;
        if(key2==0)
                delay(10);
                if(key2==0)
                MOTOA = 0;
                MOTOB = 1;
                MOTOC = 1;
                MOTOD = 1;
                delay(SPEED);//延時
                MOTOA = 1;
                MOTOB = 0;
                MOTOC = 1;
                MOTOD = 1;
                delay(SPEED);
                MOTOA = 1;
                MOTOB = 1;
                MOTOC = 0;
                MOTOD = 1;
                delay(SPEED);
                MOTOA = 1;
                MOTOB = 1;
                MOTOC = 1;
                MOTOD = 0;
                delay(SPEED);
                if(key1==0||key3==0||key4==0)break;
        if(key3==0)
                delay(10);
                if(key3==0)
                MOTOA = 1;
                MOTOB = 1;
                MOTOC = 1;
                MOTOD = 0;
                delay(SPEED);//延時
                MOTOA = 1;
                MOTOB = 1;
                MOTOC = 0;
                MOTOD = 1;
                delay(SPEED);
                MOTOA = 1;
                MOTOB = 0;
                MOTOC = 1;
                MOTOD = 1;
                delay(SPEED);
                MOTOA = 0;
                MOTOB = 1;
                MOTOC = 1;
                MOTOD = 1;
                delay(SPEED);
                if(key1==0||key2==0||key4==0)break;
        if(key4==0)
                delay(10);
                if(key4==0)
                MOTOA = 1;
                MOTOB = 1;
                MOTOC = 1;
                MOTOD = 1;
                delay(SPEED);//延時
                MOTOA = 1;
                MOTOB = 1;
                MOTOC = 1;
                MOTOD = 1;
                delay(SPEED);
                MOTOA = 1;
                MOTOB = 1;
                MOTOC = 1;
                MOTOD = 1;
                delay(SPEED);
                MOTOA = 1;
                MOTOB = 1;
                MOTOC = 1;
                MOTOD = 1;
                delay(SPEED);
                if(key1==0||key2==0||key3==0)break;
ID:384109 發(fā)表于 2023-2-21 16:26 | 只看該作者
步進電機控制放到定時器里
