代碼如下,仿真時(shí)可以運(yùn)行兩個(gè)舵機(jī),到了普中開(kāi)發(fā)板上就只有一個(gè)口能用?
求助求助
#include <reg51.h>
#include <stdio.h>
typedef unsigned char uchar;//0~255
typedef unsigned int uint;//0~65535
uchar Turn_angle=1;
sbit PWM_1 = P3^7;
sbit PWM_2 = P3^5;//
uchar kk =0;
uint control_pwm;
uint clfition;//·ÖÀà±äÁ¿
void delay_ms(uint c)
uint a,b;
for(;c>0;c--)
for(b=102;b>0;b--)
for(a=3;a>0;a--);
void Time0_Init()
TMOD=0x01;
EA=1;
ET0=1;
TH0=0xff;
TL0=0xa3;
TR0=1;
Time0_Init();
kk=0;
clfition=0;
while(1){
control_pwm=0;
switch(clfition)
case 0:{
Turn_angle=5;
delay_ms(2000);
control_pwm=1;
Turn_angle=20;
delay_ms(2000);
Turn_angle=5;
delay_ms(1000);
clfition=4;
break;}
case 1:{
Turn_angle=10;
delay_ms(2000);
control_pwm=1;
Turn_angle=20;
delay_ms(2000);
Turn_angle=5;
delay_ms(1000);
clfition=4;
break;}
case 2:{
Turn_angle=15;
delay_ms(2000);
control_pwm=1;
Turn_angle=20;
delay_ms(2000);
Turn_angle=5;
delay_ms(1000);
clfition=4;
break;}
case 3:{
Turn_angle=20;
delay_ms(2000);
control_pwm=1;
Turn_angle=20;
delay_ms(2000);
Turn_angle=5;
delay_ms(1000);
clfition=4;
break;}
default:break;
void timer() interrupt 1
TR0=0;
TH0=0xff;
TL0=0xa3;
switch(control_pwm){
case 0:
if(kk<=Turn_angle)
PWM_1=1;
PWM_1=0;
if(kk==200)
kk=0;
kk++;
TR0=1;
break;}
case 1:
{if(kk<=Turn_angle)
PWM_2=1;
PWM_2=0;
if(kk==200)
kk=0;
kk++;
TR0=1;
break;}
