查看: 2182|回復: 0
大神們,戳進來看看,求幫忙,這個是我寫的紅外接收程序,調了很久都...
ID:89646 發(fā)表于 2015-9-12 20:38 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
/*說明:使用的是HS0038紅外接收頭                                                          */
/*功能:實現(xiàn)紅外接收,接收到的鍵值碼于數(shù)碼管顯示                  */
/*思路:檢測外部中斷下降沿的時間,來翻譯紅外信號                        */
#include<reg52.h>
#define DataProt P0
sbit IR = P3^2;
sbit du = P2^6;
sbit we = P2^7;
uchar IRtime;                //存儲低電平到下一個低電平持續(xù)的時間
bit IR_ok;                        //標志著已經(jīng)存好了全部IRtime
bit IR_receive_ok;        //標志著接收好了鍵值碼
uchar IRcord[4];        //存儲鍵值碼
uchar IRdata[33];        //存儲數(shù)據(jù)碼和用戶碼
uchar code leddata[]={
//0                1         2     3     4     5     6     7     8
0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F,
//9     A     B           C         D           E         F                -         .          關顯示
0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71, 0x40, 0x80, 0x00
void IR_init()
        TMOD = 0x02;        //8位可自動裝載定時器
        TH0 = 0x00;
        TL0 = 0x00;
        EA = 1;
        ET0 = 1;
        TR0 = 1;
/*        EX0 = 1;
        IT0 = 1;                //下降沿觸發(fā)式中斷                */
        IT0 = 1;
        EX0 = 1;
void IRcordpro()        //【鍵值碼獲取】將IRdata[k]里的時間數(shù)據(jù) 翻譯為 用戶碼和用戶碼
        uchar i,j,k,dat,value;
        k = 1;                //IRdata[0]是起始位。所以k = 1:33 共32個數(shù)
        for(i = 0;i < 4;i++)
                for(j = 0 ;j < 8;j++)
                        dat = IRdata[k];
                        value >>= 1;
                        if(dat > 5)
                                value |= 0x80;        //先接收低位
                        k++;
                IRcord[i] = value;                //將用戶碼和數(shù)據(jù)碼保存于數(shù)組中去
                value = 0;                                //置0,以便下次用
        IR_receive_ok = 1;                        //表示已經(jīng)把鍵值碼取完了
void IRwork()
        switch(IRcord[2])
                case 0x45:        DataProt = leddata[10];        break;
                case 0x46:        DataProt = leddata[11];        break;
                case 0x47:        DataProt = leddata[12];        break;
                case 0x44:        DataProt = leddata[13];        break;
                case 0x40:        DataProt = leddata[14];        break;
                case 0x43:        DataProt = leddata[15];        break;
                case 0x07:        DataProt = leddata[16];        break;
                case 0x15:        DataProt = leddata[17];        break;
                case 0x09:        DataProt = 0x70;                break;
                case 0x16:        DataProt = leddata[0];        break;
                case 0x19:        DataProt = 0x49;                break;
                case 0x0d:        DataProt = 0x38;                break;
                case 0x0c:        DataProt = leddata[1];        break;
                case 0x18:        DataProt = leddata[2];        break;
                case 0x5e:        DataProt = leddata[3];        break;
                case 0x08:        DataProt = leddata[4];        break;
                case 0x1c:        DataProt = leddata[5];        break;
                case 0x5a:        DataProt = leddata[6];        break;
                case 0x42:        DataProt = leddata[7];        break;
                case 0x52:        DataProt = leddata[8];        break;
                case 0x4a:        DataProt = leddata[9];        break;
                default: break;
        IR_receive_ok = 0;                        //表示已經(jīng)把鍵值碼轉換完了
        IR_init();
        DataProt = 0xff;
        we = 1;
        DataProt = 0xfe;
        we = 0;
        du = 1;
/*                if(IR_ok)
                        IRcordpro();
                        IR_ok = 0;
                        if(IR_receive_ok)
                                IRwork();
                if(IR_ok)
                        IRcordpro();
                        IR_ok = 0;
                if(IR_receive_ok)
                        IRwork();
void timer0()interrupt 1
        IRtime++;                //277us加一次
void int0()interrupt 0
        static uchar i = 0;
//        static bit start_flag = 0;
        static start_flag = 0;
        if(start_flag)
                if((IRtime > 47) && (IRtime < 50))                //如果IRtime處于(13053us:13053us),表示接收到起始信號
                        i = 0;
                IRdata[i] = IRtime;
                i++;
                if(i == 33)                //已經(jīng)接收完了
                        IR_ok = 1;
                        i = 0;
                start_flag = 1;
                IRtime = 0;
