返回列表 發(fā)新帖
樓主: zhugehei
基于單片機(jī)的自行車?yán)锍瘫碓O(shè)計(jì)(有原理圖 仿真電路 源程序 pcb)
ID:347274 發(fā)表于 2018-6-29 19:35 | 只看該作者
要是有各元器件的解釋和備注就完美了
ID:295874 發(fā)表于 2018-10-26 11:28 | 只看該作者
程序從頭到尾認(rèn)真研究與學(xué)習(xí)了一下,就程序整體邏輯而言,個(gè)人以為還是不錯(cuò)的,但是其中有一處個(gè)人以為還可以進(jìn)一步優(yōu)化,其中正常顯示的邏輯中,關(guān)于里程的存儲(chǔ)處理函數(shù)SETS();,放在if(Mode==0&&bike_set==0)中,具體見(jiàn)下屬函數(shù),會(huì)導(dǎo)致里程存儲(chǔ)過(guò)于頻繁,對(duì)于FLASH是一種考驗(yàn),又因?yàn)楸境绦虻倪壿嬛校瑴y(cè)速計(jì)算處于定時(shí)器中斷中,每隔500ms才計(jì)算一次速度及里程數(shù)據(jù),所以更沒(méi)有必要那么頻繁的存儲(chǔ)里程數(shù)據(jù)。還有其中的/40注釋沒(méi)有說(shuō)明,其實(shí)我以為就是前面別人所說(shuō)的磁極脈沖數(shù)。個(gè)人見(jiàn)解歡迎批評(píng)指正,謝謝。
if(Mode==0&&bike_set==0)//正常顯示模式
                //讀時(shí)間
                        Ds1302_Read_Time();
                        //顯示時(shí)間
                        write_1602com(0x80);
                        write_1602dat(0x30+time_buf1[1]/10);
                        write_1602dat(0x30+time_buf1[1]%10);
                        write_1602com(0x80+3);
                        write_1602dat(0x30+time_buf1[2]/10);
                        write_1602dat(0x30+time_buf1[2]%10);
                        write_1602com(0x80+6);
                        write_1602dat(0x30+time_buf1[3]/10);
                        write_1602dat(0x30+time_buf1[3]%10);
                        write_1602com(0x80+9);
                        write_1602dat(0x30+time_buf1[4]/10);
                        write_1602dat(0x30+time_buf1[4]%10);
                        write_1602com(0x80+12);
                        write_1602dat(0x30+time_buf1[5]/10);
                        write_1602dat(0x30+time_buf1[5]%10);
                        write_1602com(0x80+15);
                        write_1602dat(time_buf1[7]-1);
                        if(before_sec!=time_buf1[6])//:顯示周期為1s,500ms顯示:500ms顯示空
                                before_sec=time_buf1[6];
                                write_1602com(0x80+11);
                                write_1602dat(':');
                                LED_SEC=1;
                        if(LED_SEC==0)
                                write_1602dat(' ');
                        write_1602com(0x80+0x40);//顯示固定符號(hào)寫(xiě)入位置,從2行第2個(gè)位置后開(kāi)始顯示
                        if(Mileage/1000000==0)
                        write_1602dat(' ');
                        write_1602dat(0x30+Mileage/1000000);//數(shù)字+0x30得到該數(shù)字的LCD1602顯示碼
                        if(Mileage%1000000/100000==0)
                        write_1602dat(' ');
                        write_1602dat(0x30+Mileage%1000000/100000);//數(shù)字+0x30得到該數(shù)字的LCD1602顯示碼
                        write_1602dat(0x30+Mileage%1000000%100000/10000);//數(shù)字+0x30得到該數(shù)字的LCD1602顯示碼
                        write_1602com(0x80+0x40+4);
                        write_1602dat(0x30+Mileage%1000000%100000%10000/1000);//數(shù)字+30得到該數(shù)字的LCD1602顯示碼
                        write_1602dat(0x30+Mileage%1000000%100000%10000%1000/100);//數(shù)字+30得到該數(shù)字的LCD1602顯示碼
                        write_1602dat(0x30+Mileage%1000000%100000%10000%1000%100/10);//數(shù)字+30得到該數(shù)字的LCD1602顯示碼
                        SETS();
                        write_1602com(0x80+0x40+10);
                        write_1602dat(0x30+Velocity/10);
                        write_1602dat(0x30+Velocity%10);//數(shù)字+30得到該數(shù)字的LCD1602顯示碼
ID:409381 發(fā)表于 2018-10-29 22:35 | 只看該作者
給力 學(xué)習(xí)學(xué)習(xí)
ID:419294 發(fā)表于 2018-11-1 20:45 | 只看該作者
版主能否解釋一下里面的參數(shù)
Mileage=Mileage+10*(Velocity/3.6)/2;                 //里程m=里程+速度km/h/3.6/2
Velocity=count *2*3.14*RADIUS /100000*2*3600  /40;//將500ms的距離經(jīng)過(guò)運(yùn)算得到km/h,將速度/100,方便顯示
ID:419294 發(fā)表于 2018-11-3 21:38 | 只看該作者
值得學(xué)習(xí)
ID:443027 發(fā)表于 2018-12-19 10:58 來(lái)自觸屏版 | 只看該作者
我正需要這個(gè)太感謝了  萬(wàn)歲
ID:491184 發(fā)表于 2019-3-16 15:20 | 只看該作者
sec是什么功能??? 看不懂哎
ID:492079 發(fā)表于 2019-3-16 16:35 | 只看該作者
很好的分享,謝謝樓主
ID:551568 發(fā)表于 2019-6-1 00:57 | 只看該作者
denminshen 發(fā)表于 2018-6-24 00:19
終于弄明白了,那個(gè)除以40是樓主隨便寫(xiě)的樣,我沒(méi)有要,參考樓主朋友的程序,我打算用在電動(dòng)車?yán)锍瘫砩希?...
你好,能想你請(qǐng)教一些這個(gè)程序的相關(guān)問(wèn)題嗎,謝謝了
ID:551568 發(fā)表于 2019-6-1 00:58 | 只看該作者
liyongan_1985 發(fā)表于 2018-10-26 11:28
程序從頭到尾認(rèn)真研究與學(xué)習(xí)了一下,就程序整體邏輯而言,個(gè)人以為還是不錯(cuò)的,但是其中有一處個(gè)人以為還可 ...
你好 能想你請(qǐng)教一些關(guān)于這個(gè)程序的一些問(wèn)題嗎  謝謝
ID:551568 發(fā)表于 2019-6-1 01:18 | 只看該作者
你好 ,可以想你請(qǐng)教一些相關(guān)問(wèn)題嗎 謝謝
ID:565674 發(fā)表于 2019-7-6 11:09 | 只看該作者
是用的protel99嗎?怎么沒(méi)有pcb的源文件啊
ID:565674 發(fā)表于 2019-7-6 11:10 | 只看該作者
是用的protel99嗎,怎么沒(méi)找到pcb的源文件啊
ID:556689 發(fā)表于 2019-11-13 09:44 來(lái)自觸屏版 | 只看該作者
yilinghai 發(fā)表于 2017-11-10 16:43
親測(cè)能用,仿真圖如下
為什么我下載后用不了啊求解
ID:556689 發(fā)表于 2019-11-22 09:27 來(lái)自觸屏版 | 只看該作者
faridzled 發(fā)表于 2017-11-14 19:07
thanks for sharing
這個(gè)霍爾傳感器是怎么實(shí)現(xiàn)和單片機(jī)的連接呢  大佬
ID:556689 發(fā)表于 2019-11-22 09:28 來(lái)自觸屏版 | 只看該作者
a422714088 發(fā)表于 2018-3-13 17:44
如果做成實(shí)物的話,怎么添加信號(hào)源呢  就是把這塊板子放去哪里才可以測(cè)速呢。。。
我也是不知道
ID:538392 發(fā)表于 2019-11-29 20:04 | 只看該作者
非常給力老鐵!
ID:620287 發(fā)表于 2019-12-1 15:09 來(lái)自觸屏版 | 只看該作者
希望樓主做一個(gè)摩托車智能防盜的
ID:171036 發(fā)表于 2020-3-23 21:55 | 只看該作者
終于弄明白了,那個(gè)除以40是樓主隨便寫(xiě)的樣,我沒(méi)有要,參考樓主朋友的程序,我打算用在電動(dòng)車?yán)锍瘫砩,?...
老兄  你那maichong是脈沖個(gè)數(shù)還是磁鋼個(gè)數(shù) ?為什么除以maichong?還要除以10?
ID:722227 發(fā)表于 2020-4-6 23:16 | 只看該作者
十分感謝分享,很受用
ID:524001 發(fā)表于 2020-4-28 15:44 | 只看該作者
請(qǐng)問(wèn)mode和bike set代表什么。课沂切“卓床欢蠡卮
ID:783980 發(fā)表于 2020-6-21 09:08 | 只看該作者
多謝,幫大忙了。
ID:783980 發(fā)表于 2020-6-21 09:44 | 只看該作者
請(qǐng)問(wèn)一下那個(gè)源程序復(fù)制到Keil4里編譯不成功呀?
ID:744853 發(fā)表于 2020-6-23 22:49 | 只看該作者
找到寶了,切換能切換到初始模式嗎
ID:784145 發(fā)表于 2020-6-30 01:15 | 只看該作者
仿真測(cè)試不是從0開(kāi)始計(jì)里程數(shù)的,從何修改?
ID:860145 發(fā)表于 2020-12-15 19:08 | 只看該作者
您好,想問(wèn)一下,這個(gè)pcb文件打開(kāi)后與您的pcb截圖不一樣
ID:357153 發(fā)表于 2020-12-28 13:51 | 只看該作者
感謝樓主的分享。收藏、值得學(xué)習(xí)
ID:895892 發(fā)表于 2021-3-24 14:29 | 只看該作者
跟樓主好好學(xué)習(xí)
ID:905107 發(fā)表于 2021-4-13 16:13 | 只看該作者
CYQ-1011 發(fā)表于 2017-4-18 19:31
**** 作者被禁止或刪除 內(nèi)容自動(dòng)屏蔽 ****
能把文件分享一下嗎
ID:912838 發(fā)表于 2021-5-13 20:14 | 只看該作者
里程表怎么清零
ID:891876 發(fā)表于 2022-8-22 12:31 | 只看該作者
請(qǐng)問(wèn)查看原理圖用什么軟件?
ID:1075254 發(fā)表于 2023-5-7 14:51 | 只看該作者
幫助很大,希望繼續(xù)出帖子!嘿嘿
返回列表 發(fā)新帖
