分享一個(gè)51單片機(jī)驅(qū)動(dòng)2.7寸tft液晶 自己編寫(xiě)可以用的
完整代碼下載:
程序.rar
(41.28 KB, 下載次數(shù): 20)
2017-4-17 11:06 上傳
點(diǎn)擊文件名下載附件
主程序:
- #include <reg52.h>
- #define DBL P0
- #define SWITCH_TIME 4000 //默認(rèn)2s
- unsigned char a;
- unsigned int pic;
- bit delayflag=0;
- void Initial(void);
- void Write_Command(unsigned char RegisterName);
- void Write_Data(unsigned char RegisterValue);
- void fill(unsigned char dat1,unsigned char dat2);
- void Delay(unsigned int count);
- void pane();
- void showpic();
- void pictrue();
- sbit CS =P1^0;
- sbit DC =P1^2;
- sbit W_R =P3^6;
- sbit R_D =P3^7;
- sbit RES =P1^1;
- sbit SCLK = P0^0; // Serial Clock Input
- sbit SDIN = P0^1; // Serial Data Input
- sbit key_stop = P1^3;//按鍵,按下為0暫停循環(huán),松開(kāi)為1循環(huán)跑動(dòng)
- sbit key_mod = P1^4;//并串模式切換按鍵,為0串行模式,為1為并行模式,僅在程序開(kāi)機(jī)時(shí)判斷
- bit mod_flag = 1;
- unsigned int i,j;
- for(i=0;i<count;i++)
- for(j=0;j<114;j++);
- unsigned char code show1[]=
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,
- 0xFC,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xF0,
- 0xF0,0xF0,0xF0,0xF0,0xF0,0x00,0x00,0x80,0xC0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,
- 0xF0,0xF0,0xF0,0xF0,0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,
- 0xF0,0xF0,0xF0,0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,
- 0xF0,0xF0,0x00,0xF0,0xF0,0xF0,0xF0,0xF0,0x00,0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF0,
- 0xF0,0xF0,0x00,0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF0,0xF0,0xF0,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,
- 0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xFF,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,
- 0x7F,0x7F,0x00,0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0x7F,0x3F,0x1F,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0x01,0xFE,0xFF,0xFF,0xFF,0xFF,0x07,0x43,0xE3,0xF3,0xFB,0xFF,
- 0xFF,0xFF,0xBF,0x1F,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0x43,0xE3,0xF3,0xFB,0xFF,0xFF,
- 0xFF,0xBF,0x1F,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xC3,0x83,0xC3,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFE,0xFF,0x7F,0x3F,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xFC,0xFE,0x7F,0x7F,0x3F,0x0F,0x07,0x03,0x01,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0xEF,0xEF,0xEF,0xEF,0xEF,0xE7,0xE1,0xE0,0xE0,0xE0,0xE0,0xEF,
- 0xEF,0xEF,0xEF,0xEF,0xE0,0x0F,0x0F,0x8F,0xEF,0xEF,0xE0,0xE0,0xE0,0x01,0x83,0xC7,
- 0xEF,0xEF,0xEF,0xEF,0x0F,0x0F,0x8F,0xCF,0xEF,0xEF,0xE0,0xE0,0xE1,0x03,0x07,0x0F,
- 0x0F,0x0F,0x0F,0x00,0xEF,0xEF,0xEF,0xEF,0xEF,0x0F,0x0F,0x0F,0x0F,0xEF,0xE7,0xE3,
- 0xE1,0xE0,0x00,0x0F,0x0F,0x0F,0x0F,0x07,0x03,0x01,0x00,0x00,0x00,0x0F,0x0F,0x0F,
- 0x0F,0x07,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0xF8,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x00,0x00,0x00,0x03,0x03,0x03,0x03,0x03,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0x03,
- 0x03,0x03,0x03,0x03,0x01,0xFE,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0xFF,0xFF,0xBF,0xFF,
- 0xEF,0xE7,0xF3,0xE1,0xFE,0xFE,0xFF,0xFF,0xFF,0xFF,0x87,0x83,0x81,0xC0,0xE0,0xF0,
- 0xF8,0xFC,0xFC,0x7C,0xFF,0xFF,0xFF,0xFF,0xFF,0x7C,0x7C,0x7C,0x7C,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x1F,0x1F,0x1F,0x1F,0x0F,0x07,0x03,0x01,0x00,0x1F,0x1F,0x1F,
- 0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x1F,0x1F,0x1F,0x1F,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,
- 0x0F,0x07,0x03,0x01,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x0F,0x07,
- 0x03,0x01,0x00,0x00,0x1F,0x1F,0x1F,0x1F,0x1F,0x00,0x00,0x00,0x00,0x1F,0x1F,0x1F,
- 0x1F,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- unsigned char code show[]=
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x08,
- 0xA8,0xA8,0xA8,0xE8,0xA8,0xA8,0xA8,0xA8,0x28,0x00,0x00,0x00,0xC0,0x08,0x30,0x00,
- 0x10,0x10,0x10,0x10,0x10,0x10,0x10,0xF0,0x00,0x00,0x20,0x20,0x20,0x20,0x78,0x20,
- 0xA0,0x20,0x78,0x20,0x20,0x20,0x20,0x00,0x00,0x60,0xA0,0xA0,0xA0,0xA0,0xA0,0xB8,
- 0xA8,0xA8,0xA8,0xA8,0xA0,0x60,0x00,0x00,0x00,0x10,0x60,0x00,0x40,0x40,0x40,0x40,
- 0xF8,0x40,0x40,0x40,0x40,0x00,0x00,0x00,0xC0,0x40,0x40,0x40,0x40,0xF8,0x40,0x40,
- 0x40,0x40,0xC0,0x00,0x00,0x00,0x00,0x08,0x08,0x08,0x08,0x08,0x08,0x88,0x48,0x28,
- 0x18,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x3F,0x00,
- 0x4F,0x2A,0x7A,0xAA,0xAA,0xAA,0x6A,0x2F,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x10,0x10,0x9F,0x91,0x51,0x31,
- 0x1F,0x31,0x51,0x91,0x9F,0x10,0x10,0x00,0x00,0x08,0x0A,0xFD,0x54,0x56,0x55,0x54,
- 0x55,0x56,0x54,0xFD,0x0A,0x08,0x00,0x00,0x02,0x82,0x7E,0x80,0x20,0x10,0x08,0x06,
- 0x01,0x02,0x04,0x08,0x30,0x00,0x00,0x00,0x3F,0x12,0x12,0x12,0x12,0xFF,0x12,0x12,
- 0x12,0x12,0x1F,0xC0,0x00,0x00,0x02,0x02,0x02,0x02,0x02,0x02,0xFF,0x02,0x02,0x02,
- 0x02,0x02,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x01,
- 0x01,0x01,0x01,0x00,0x00,0x00,0x01,0x01,0x01,0x00,0x00,0x00,0x01,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x00,0x00,0x01,0x01,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,
- 0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x01,0x01,0x01,0x01,
- 0x01,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,
- 0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x81,0xFF,0x81,0x03,
- 0x00,0x81,0xFF,0x89,0x9D,0xC3,0x00,0x81,0xFF,0x81,0x80,0x80,0xC0,0x00,0x80,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x84,0x00,0x00,0x00,0x7E,0x81,0x81,0x81,0x7E,0x00,0x4F,
- 0x89,0x89,0x89,0x71,0x00,0x0E,0xD1,0x91,0x91,0x7E,0x00,0xC6,0xA1,0x91,0x89,0x86,
- 0x00,0x08,0x08,0x08,0x08,0x08,0x00,0x4F,0x89,0x89,0x89,0x71,0x00,0x03,0x01,0xF9,
- 0x07,0x01,0x00,0x00,0x82,0xFF,0x80,0x00,0x00,0x4F,0x89,0x89,0x89,0x71,0x00,0x00,
- 0x82,0xFF,0x80,0x00,0x00,0x4F,0x89,0x89,0x89,0x71,0x00,0x7E,0x89,0x89,0x8B,0x70,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x81,0xFF,0x89,0x1D,0x03,
- 0x00,0x80,0xF8,0x27,0x3C,0xE0,0x80,0x81,0xE7,0x18,0xE7,0x81,0x00,0x00,0x80,0x00,
- 0x00,0x08,0x08,0x08,0x08,0x08,0x00,0x42,0x81,0x89,0x89,0x76,0x00,0x76,0x89,0x89,
- 0x89,0x76,0x00,0x0E,0xD1,0x91,0x91,0x7E,0x00,0x4F,0x89,0x89,0x89,0x71,0x00,0x0E,
- 0xD1,0x91,0x91,0x7E,0x00,0x0E,0xD1,0x91,0x91,0x7E,0x00,0x4F,0x89,0x89,0x89,0x71,
- // 8-bit 80XX Parallel
- void Write_Command_Para(unsigned char RegisterName)
- CS=0;
- DC=0;
- DBL=RegisterName;
- W_R=0;
- W_R=1;
- CS=1;
- void Write_Data_Para(unsigned char RegisterValue)
- CS=0;
- DC=1;
- DBL= (unsigned char)RegisterValue;
- W_R=0;
- W_R=1;
- CS=1;
- // 4-wire SPI
- void Write_Command_SPI(unsigned char Data)
- unsigned char i;
- CS=0;
- DC=0;
- for (i=0; i<8; i++)
- SCLK=0;
- SDIN=(Data&0x80)>>7;
- Data = Data << 1;
- // uDelay(1);
- SCLK=1;
- // uDelay(1);
- // SCLK=0;
- DC=1;
- CS=1;
- void Write_Data_SPI(unsigned char Data)
- unsigned char i;
- CS=0;
- DC=1;
- SCLK=0;
- Data = Data << 1;
- // uDelay(1);
- SCLK=1;
- // uDelay(1);
- // SCLK=0;
- DC=1;
- CS=1;
- if(mod_flag == 1)
- Write_Command_Para(RegisterName);
- else
- Write_Command_SPI(RegisterName);
- //Delay(5);
- if(mod_flag == 1)
- Write_Data_Para(RegisterValue);
- else
- Write_Data_SPI(RegisterValue);
- //Delay(5);
- Write_Command(0xAE); /* display off */
- Write_Command(0xB3); /* set osc division */
- Write_Command(0x91); /*100 */
- Write_Command(0xA8); /* multiplex ratio */
- Write_Command(0x3f); /* duty = 1/64 */
- Write_Command(0xA2); /* set display offset --- */
- Write_Command(0x44); /* 72 */
- Write_Command(0xa1); /*set start line */
- Write_Command(0x00); /* ------ */
- Write_Command(0xA0); /* set segment remap------ */
- Write_Command(0x63); /* disable Nibble Remap */
- /* Horizontal Address Incremen */
- /* Scan from COM[N-1] to COM0 */
- /* Enable COM Split Odd Even */
- Write_Command(0xAD); /*Set Master Config DC/DC Converter*/
- Write_Command(0x02);
- Write_Command(0x81); /* set contract current */
- Write_Command(0x40);
- Write_Command(0x86); /* Set Full Current Range */
- Write_Command(0xBE); /* Set High Voltage Level of COM Pin */
- Write_Command(0x02); /* 0.53Vref */
- Write_Command(0xBF); /*set Low Voltage Level of SEG Pin */
- Write_Command(0x0e);
- Write_Command(0xA4); /* set display mode */
- /* Clear Screen */
- Write_Command(0x23); /*set graphic acceleration commmand */
- Write_Command(0x01);
- Write_Command(0x24); /* draw rectangle */
- Write_Command(0x00); /* Gray Scale Level 1 */
- Write_Command(0x00); /* Gray Scale Level 3 & 2 */
- Write_Command(0x3f); /* Gray Scale Level 3 & 2 */
- Write_Command(0x3f); /* Gray Scale Level 3 & 2 0x00*/
- Write_Command(0xAF); /* display ON */
- //void fill(unsigned char dat1,unsigned char dat2)
- //unsigned char x,y;
- //Write_Command(0x15); /* set column address */
- //Write_Command(0x00); /* set column start address */
- //Write_Command(0x3f); /* set column end address */
- //Write_Command(0x75); /* set row address */
- //Write_Command(0x00); /* set row start address */
- //Write_Command(0x3f); /* set row end address */
- //for(y=0;y<64;y++)
- //for(x=0;x<32;x++)
- //Write_Data(dat1);
- //Write_Data(dat2);
- //Delay(2);
- void Clear()
- unsigned char x,y;
- Write_Command(0x15); /* set column address */
- Write_Command(0x00); /* set column start address */
- Write_Command(0x3f); /* set column end address */
- Write_Command(0x75); /* set row address */
- Write_Command(0x00); /* set row start address */
- Write_Command(0x4f); /* set row end address */
- for(y=0;y<64;y++)
- for(x=0;x<80;x++)
- Write_Data(0x00);
- //方框
- void pane()
- // row0
- Write_Command(0); /* set row start address */
- Write_Command(0); /* set row end address */
- for(x=0;x<64;x++)
- Write_Data(0xff);
- Delay(2);
- //row 1 - 62
- for(y=1;y<63;y++)
- Write_Command(y); /* set row start address */
- Write_Command(y); /* set row end address */
- Write_Data(0x0f);//低位在前
- for(x=1;x<63;x++)
- Write_Data(0x00);
- Write_Data(0xf0);//低位在前
- Delay(2);
- //row 63
- Write_Command(63); /* set row start address */
- Write_Command(63); /* set row end address */
- for(x=0;x<64;x++)
- Write_Data(0xff);
- Delay(2);
- void pictrue()
- unsigned char x,y,z;
- unsigned char value,temp_h,temp_l;
- Write_Command(0x3f); /* set row end address */
- //x,y確定數(shù)組的位置,z確定數(shù)組的bit位數(shù)
- for(y=0;y<8;y++)
- for(z=0;z<8;z++)
- for(x=0;x<64;x++)
- //value = ((show[y*128 + x*2] & (0x01<<z))>>z)*0x0f + ((show[y*128 + x*2+1] & (0x01<<z))>>z)*0xf0;
- temp_l = show1[y*128 + x*2] & (0x01<<z);
- temp_h = show1[y*128 + x*2+1] & (0x01<<z);
- if(temp_l > 0) value = 0x0f;
- else value = 0x00;
- if(temp_h > 0) value |= 0xf0;
- Write_Data(value);
- void pictrue1()
- for(y=0;y<8;y++)
- for(z=0;z<8;z++)
- for(x=0;x<64;x++)
- temp_l = show[y*128 + x*2] & (0x01<<z);
- temp_h = show[y*128 + x*2+1] & (0x01<<z);
- //豎條紋
- void pane2()
- for(y=0;y<64;y++)
- for(x=0;x<64;x++)
- Write_Data(0x0f);
- Delay(2);
- //橫條紋
- void pane1()
- for(y=0;y<64;y++)
- for(x=0;x<64;x++)
- Write_Data(0xff);
- for(x=0;x<64;x++)
- Write_Data(0x00);
- Delay(1);
- void snow()
- for(y=0;y<32;y++)
- for(x=0;x<64;x++)
- Write_Data(0x0f);
- for(x=0;x<64;x++)
- Write_Data(0xf0);
- Delay(1);
- void Fill_Block(unsigned char Data, unsigned char a, unsigned char b, unsigned char c,unsigned char d)
- unsigned char i,j;
- Write_Command(a); /* set column start address */
- Write_Command(b); /* set column end address */
- Write_Command(c); /* set row start address */
- Write_Command(d); /* set row end address */
- for(i=0;i<(d-c+1);i++)
- for(j=0;j<(b-a+1);j++)
- Write_Data(Data);
- Write_Data(Data);
- Delay(2);
- void Grayscale()
- Fill_Block(0x11,0x00,0x3f,0x00,0x3f);
- /* Level 16 => Column 1~8 */
- // Fill_Block(0xCF,0x00,0x03,0x00,0x3f);
- /* Level 15 => Column 9~16*/
- // Fill_Block(0xEE,0x04,0x07,0x00,0x3f);
- /* Level 14 => Column 17~24*/
- // Fill_Block(0xDD,0x08,0x0B,0x00,0x3f);
- /* Level 13 => Column 25~32*/
- // Fill_Block(0xCC,0x0C,0x0F,0x00,0x3f);
- /* Level 12 => Column 33~40*/
- // Fill_Block(0xBB,0x10,0x13,0x00,0x3f);
- /* Level 11 => Column 41~48*/
- // Fill_Block(0xAA,0x14,0x17,0x00,0x3f);
- /* Level 10 => Column 48~56*/
- // Fill_Block(0x99,0x18,0x1B,0x00,0x3f);
- /* Level 9 => Column 57~64*/
- // Fill_Block(0x88,0x1C,0x1F,0x00,0x3f);
- /* Level 8 => Column 65~72*/
- // Fill_Block(0x77,0x20,0x23,0x00,0x3f);
- /* Level 7 => Column 73~80*/
- // Fill_Block(0x66,0x24,0x27,0x00,0x3f);
- /* Level 6 => Column 81~86*/
- // Fill_Block(0x55,0x28,0x2B,0x00,0x3f);
- /* Level 5 => Column 87~94*/
- // Fill_Block(0x44,0x2C,0x2F,0x00,0x3f);
- /* Level 4 => Column 95~104*/
- // Fill_Block(0x33,0x30,0x33,0x00,0x3f);
- /* Level 3 => Column 105~112*/
- // Fill_Block(0x22,0x34,0x37,0x00,0x3f);
- /* Level 2 => Column 113~120*/
- // Fill_Block(0x11,0x38,0x3B,0x00,0x3f);
- /* Level 1 => Column 121~128*/
- // Fill_Block(0x00,0x3C,0x3f,0x00,0x3f);
- void Grayscale2()
- Fill_Block(0x88,0x00,0x3f,0x00,0x3f);
- void Grayscale3()
- Fill_Block(0xff,0x00,0x3f,0x00,0x3f);
- void main(void)
- key_stop = 1;
- key_mod = 1;
- Delay(5);
- RES=0;
- Delay(10);
- RES=1;
