ADC0832兩路ad轉(zhuǎn)換仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
2021-4-22 18:32 上傳
2017-7-13 16:48 上傳
2017-7-13 16:48 上傳
- #include <REGX51.H>
- #define uchar unsigned char
- #define uint unsigned int
- sbit AD0832_CS = P1^0 ; //片選信號(hào)
- sbit AD0832_CLK = P1^1; //時(shí)鐘接口
- sbit AD0832_DI = P1^2; //數(shù)據(jù)接口
- uchar code table[8]={0x0c,0x12,0x12,0x0c,0x00,0x00,0x00,0x00}; // 攝氏溫度符號(hào)
- sbit RS = P2^0; //LCD數(shù)據(jù)/命令選擇端(H/L)位聲明
- sbit RW = P2^1; //LCD讀寫控制,寫為0,讀為1
- sbit EN = P2^2; //LCD使能信號(hào)端位聲明
- sbit k1=P2^3; //按鍵定義
- sbit k2=P2^4;
- sbit k3=P2^5;
- sbit k4=P2^6;
- int shang=40; //上限溫度定義
- int xia=20;
- uchar data disdata[7];
- uchar data data1[7];
- 利用按鍵來控制上限下限溫度
- void delay1(unsigned short i)
- while(i--);
- void keypros()
- if(k1==0) //上加
- delay1(1000);
- shang=shang+1;
- if(k2==0) //上減
- delay1(1000);
- shang=shang-1;
- if(k3==0) //下加
- delay1(1000);
- xia=xia+1;
- if(k4==0) //下減
- delay1(1000);
- xia=xia-1;
- if((k3==0)&&(k1==0) ) //歸位
- delay1(1000);
- shang=40;
- xia=20;
- /*************************lcd1602程序**************************/
- void delay1ms(uint ms)//延時(shí)1毫秒(不夠精確的)
- { uint i,j;
- for(i=0;i<ms;i++)
- for(j=0;j<100;j++);
- void wr_com(uchar com)//寫指令//
- delay1ms(1);
- RS=0;
- RW=0;
- EN=0;
- P0=com;
- delay1ms(1);
- EN=1;
- delay1ms(1);
- EN=0;
- void wr_dat(uchar dat)//寫數(shù)據(jù)//
- delay1ms(1);
- RS=1;
- RW=0;
- EN=0;
- P0=dat;
- delay1ms(1);
- EN=1;
- delay1ms(1);
- EN=0;
- void wr_new() //寫新字符
- uchar i;
- wr_com(0x40);
- for(i=0;i<8;i++)
- wr_dat(table[i]);
- void lcd_init()//初始化設(shè)置//
- { delay1ms(15);
- wr_com(0x38);delay1ms(5);
- wr_com(0x08);delay1ms(5);
- wr_com(0x01);delay1ms(5);
- wr_com(0x06);delay1ms(5);
- wr_com(0x0c);delay1ms(5);
- uchar GetAD0832(uint Channel)
- uchar i=0 , Data1 =0 , Data2 = 0 ;
- AD0832_CLK = 0 ; //時(shí)鐘置低平
- AD0832_DI = 1 ; //開始信號(hào)為高電平
- AD0832_CS = 0 ; //片選信號(hào)置低,啟動(dòng)AD轉(zhuǎn)換芯片
- AD0832_CLK = 1 ; //輸入開始信號(hào)(構(gòu)成一個(gè)正脈沖),時(shí)鐘上升沿,輸入開始信號(hào)
- AD0832_CLK = 0 ; //時(shí)鐘下降沿
- //模擬信號(hào)輸入模式選擇(1:?jiǎn)文P盘?hào),0:雙模差分信號(hào))
- AD0832_DI = 1 ;
- AD0832_CLK = 1 ; //時(shí)鐘上升沿,輸入開始信號(hào)
- //模擬信號(hào)輸入通道選擇(1:通道CH1,0:通道CH0)
- AD0832_DI = Channel ; //選擇通道0
- AD0832_DI = 1 ; //數(shù)據(jù)線置高,準(zhǔn)備接收數(shù)據(jù)
- for(i=0;i<8;i++) //從高位移入數(shù)據(jù)
- AD0832_CLK = 1 ;
- AD0832_CLK = 0 ; //時(shí)鐘下降沿,AD0832輸出數(shù)據(jù),高位(MSB)先
- Data1 = Data1<<1;
- if(AD0832_DI == 1)
- {Data1 = Data1 | 0x01;} //數(shù)據(jù)左移位,補(bǔ)0 ,如果數(shù)據(jù)為“1”,移入1, 如果數(shù)據(jù)為“0”,移入0,
- for(i=0;i<8;i++) //從低位移入數(shù)據(jù)
- Data2 = Data2>>1;
- { Data2 = Data2 | 0x80;} //數(shù)據(jù)右移位,補(bǔ)0,如果數(shù)據(jù)為“1”,移入1如果數(shù)據(jù)為“0”,移入0,
- AD0832_CLK = 1 ;
- //數(shù)據(jù)線置高,釋放總線,完成一次轉(zhuǎn)換
- AD0832_CLK = 1 ;
- AD0832_DI = 1 ;
- AD0832_CS = 1 ;
- return (Data1==Data2)?Data1:0; // 如果相等輸出data1 or 0
- void delay(uint i) //延時(shí)程序,i是形式參數(shù),i為1時(shí) 延時(shí)約1MS
- uint j;
- for(;i>0;i--) //變量i由實(shí)際參數(shù)傳入一個(gè)值,因此i不能賦初值
- for(j=0;j<125;j++) //j由0自增到125 所用的時(shí)間大約是1MS
- void main() //主函數(shù)
- uchar AD_val1; //儲(chǔ)存A/D轉(zhuǎn)換后的值
- uchar AD_val2;
- delay1(1000);
- lcd_init();//初始化顯示
- delay1(1000);
- while(1)
- keypros() ;
- data1[0] = shang / 10;
- data1[1] = shang % 10;
- data1[2] = xia / 10;
- data1[3] = xia % 10;
- wr_com(0xc0); //寫地址 第二行
- wr_dat('0'+data1[0]);
- wr_com(0xc1); //寫地址 第二行
- wr_dat('0'+data1[1]);
- wr_com(0xc3); //寫地址 第二行
- wr_dat('0'+data1[2]);
- wr_com(0xc4); //寫地址 第二行
- wr_dat('0'+data1[3]);
- AD_val1= GetAD0832(0); //進(jìn)行A/D轉(zhuǎn)換
- if(AD_val1!=0)
- disdata[1]=AD_val1/100+0x30;//?位數(shù)
- disdata[2]=AD_val1%100/10+0x30;//?位數(shù)
- disdata[3]=AD_val1%10/1+0x30;//?數(shù)位
- delay(5);
- wr_com(0x81);
- wr_dat(disdata[1]);//顯示小數(shù)點(diǎn)
- delay(5);
- wr_com(0x82); //寫地址 第一行
- wr_dat(disdata[2]) ;
- delay(5); //延時(shí)1ms
- wr_com(0x83); //寫地址 第一行
- wr_dat(disdata[3]) ;
- AD_val2= GetAD0832(1); //進(jìn)行A/D轉(zhuǎn)換
- if(AD_val2!=0)
- disdata[4]=AD_val2/100+0x30;//?位數(shù)
- disdata[5]=AD_val2%100/10+0x30;//?位數(shù)
- disdata[6]=AD_val2%10/1+0x30;//?數(shù)位
- delay(5);
- wr_com(0x85);
- wr_dat(disdata[4]);//顯示小數(shù)點(diǎn)
- delay(5);
- wr_com(0x86); //寫地址 第一行
- wr_dat(disdata[5]) ;
- wr_com(0x87); //寫地址 第一行
- wr_dat(disdata[6]) ;
代碼肯定還存在很多問題,求大神指導(dǎo),需要用Proteus7.5版本打開:
adc0832.zip
(90.32 KB, 下載次數(shù): 463)
2017-7-13 13:06 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
