- #include<reg52.h>
- #include<intrins.h>
- #define uchar unsigned char//o궨òå
- #define uint unsigned int
- ////////////////////諾ֱäá¿/////////////////////////////
- float TEMP_NOW=0.0;
- float TEMP_SET=30.0;
- uint T_Count=0;
- uint S_Count=0;
- uint P_Count=0;
- uint N_Count=0;
- uint M_Count=1;
- #define K_UP 0X20//¶¨òå¼üÖμ
- #define K_DOWN 0X21
- #define K_CLEAR 0X24
- #define K_OK 0X25
- #define K_ONE 0X30
- #define K_FOUR 0X31
- #define K_SEVEN 0X32
- #define K_POINT 0X33
- #define K_TWO 0X34
- #define K_FIVE 0X43
- #define K_EIGHT 0X36
- #define K_ZERO 0X37
- #define K_THREE 0X38
- #define K_SIX 0X40
- #define K_NINE 0X41
- #define K_SET 0X42
- extern float TEMP_NOW;
- extern float TEMP_SET;
- extern uint T_Count;
- extern uint S_Count;
- extern uint P_Count;
- extern uint N_Count;
- extern uint M_Count;
- extern uchar Current_Temp_Display_Buffer[];
- extern uchar set_Temp_Display_Buffer[];
- extern int sel;
- sbit lcden=P2^7;//òo¾§ê1Äü
- sbit lcdrs=P2^6;//òo¾§êy¾Y/ÃüáîÑ¡Ôñ¶Ë
- sbit DQ =P3^7;//DS18B20êy¾Y¶Ë
- sbit XX =P2^5;//¶áD′Ñ¡Ôñ¶Ë
- sbit cold =P2^0;//êä3öDÅoÅ
- sbit warm =P2^1;//êä3öDÅoÅ
- uchar Current_Temp_Display_Buffer[]={" NOW: 0.0"};
- uchar set_Temp_Display_Buffer[]= {" SET: 30.0"};
- int sel=0;
- uchar code KeyCodeTable[]=
- 0x11,0x12,0x14,0x18,0x21,0x22,0x24,0x28,0x41,0x42,0x44,0x48,0x81,0x82,0x84,0x88
- #define delayNOP() {_nop_();_nop_();_nop_();_nop_();}
- uchar code Temperature_Char[8] = {0x0c,0x12,0x12,0x0c,0x00,0x00,0x00,0x00};
- uchar code df_Table[]={0,1,1,2,3,3,4,4,5,6,6,7,8,8,9,9};
- uchar CurrentT = 0;
- uchar Temp_Value[]={0x00,0x00};
- uchar Display_Digit[]={0,0,0,0};
- bit DS18B20_IS_OK = 1;
- void Read_Temperature();
- void Display_Temperature();
- void Comparison();
- //////////////////////¶¨ê±///////////////////////////////
- void timer0_init(void)
- TMOD = 0x00 ; //éèÖö¨ê±Æ÷0μÄ1¤×÷·½ê½
- TH0 = (8192-5000)/32;//μ¥Ƭ»ú¾§ÕñÎa12MHz£¬»úÆ÷ÖüÆúÎa1us£¬t=5ms£¬
- //N=5000/1=5000
- TL0 = (8192-5000)%32;
- IE = 0x82;
- TR0=1;
- void timer0() interrupt 1
- if(++T_Count == 100) //////100Îa0.5s
- TR0=0;
- Read_Temperature();
- Display_Temperature() ;
- T_Count=0;
- if(++P_Count == 6)
- N_Count=1;
- TR0=1;
- void delay1(uint z) //Ñóê±oˉêy
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void write_com(uchar com) //D′Ãüáîoˉêy
- lcdrs=0; //Ñ¡ÔñD′ÃüáîÄ£ê½
- P0=com; //½«òaD′μÄÃüáî×ÖËíμ½êy¾Y×üÏßéÏ
- delay1(5); //éÔ×÷Ñóê±òÔ′yêy¾YÎ趨
- lcden=1; //ê1Äü¶Ë¸øò»¸ßÂö3壬òòÎa3õê¼»ˉoˉêyÖDòѾ-½«lcdenÖÃáã
- lcden=0; //½«ê1Äü¶ËÖÃ0íê3é¸ßÂö3å
- void write_date(uchar date) //D′êy¾Yoˉêy
- lcdrs=1; //Ñ¡ÔñD′êy¾YÄ£ê½
- P0=date;
- delay1(5);
- lcden=1;
- delay1(5);
- lcden=0;
- void init_lcd() //3õê¼»ˉoˉêy
- lcden=0;
- write_com(0x38); //éèÖÃ16*2ÏÔê¾£¬5*7μãÕó£¬8λêy¾Y½ó¿ú
- write_com(0x0c); //éèÖÿaÏÔê¾£¬2»ÏÔê¾1a±ê
- write_com(0x06); //D′ò»¸ö×Ö·ûoóμØÖ·Ö¸Õë¼ó1
- write_com(0x01); //ÏÔê¾Çå0,êy¾YÖ¸ÕëÇå0
- void Print()
- uchar num;
- write_com(0x80);
- for(num=0;num<12;num++)
- write_date(Current_Temp_Display_Buffer[num]);
- write_date(0xdf);
- write_date('C');
- write_com(0x80+0x40);
- write_date(set_Temp_Display_Buffer[num]);
- write_date(0xdf);
- write_date('C');
- void Delay_INI(uint x)
- while(--x);
- void Delay(unsigned int n)
- do
- _nop_();_nop_();
- _nop_();_nop_();
- _nop_();_nop_();
- _nop_();_nop_();
- _nop_();
- n--;
- }while(n);
- uchar Init_DS18B20()
- uchar status;
- DQ = 1;
- Delay_INI(8);
- DQ = 0;
- Delay_INI(90);
- DQ = 1;
- Delay_INI(8);
- status=DQ;
- Delay_INI(100);
- DQ = 1;
- return status;
- uchar ReadOneByte()
- uchar i,dat=0;
- DQ = 1;
- _nop_();
- for(i=0;i<8;i++)
- DQ = 0;
- dat >>= 1;
- DQ = 1;
- _nop_();
- _nop_();
- if(DQ)
- dat |= 0X80;
- Delay(30);
- DQ = 1;
- return dat;
- void WriteOneByte(uchar dat)
- uchar i;
- for(i=0;i<8;i++)
- DQ = 0;
- DQ = dat& 0x01;
- Delay(5);
- DQ = 1;
- dat >>= 1;
- if(Init_DS18B20()==1)
- DS18B20_IS_OK=0;
- else
- WriteOneByte(0xcc);
- WriteOneByte(0x44);
- Init_DS18B20();
- WriteOneByte(0xbe);
- Temp_Value[0] = ReadOneByte();
- Temp_Value[1] = ReadOneByte();
- DS18B20_IS_OK=1;
- uchar t = 150, ng = 0;
- if((Temp_Value[1]&0xf8)==0xf8)
- Temp_Value[1] = ~Temp_Value[1];
- Temp_Value[0] = ~Temp_Value[0]+1;
- if(Temp_Value[0]==0x00)
- Temp_Value[1]++;
- ng = 1;
- Display_Digit[0] = df_Table[Temp_Value[0]&0x0f];
- CurrentT = ((Temp_Value[0]&0xf0)>>4) | ((Temp_Value[1]&0x07)<<4);
- Display_Digit[3] = CurrentT/100;
- Display_Digit[2] = CurrentT%100/10;
- Display_Digit[1] = CurrentT%10;
- Current_Temp_Display_Buffer[11] = Display_Digit[0] + '0';
- Current_Temp_Display_Buffer[10] = '.';
- Current_Temp_Display_Buffer[9] = Display_Digit[1] + '0';
- Current_Temp_Display_Buffer[8] = Display_Digit[2] + '0';
- Current_Temp_Display_Buffer[7] = Display_Digit[3] + '0';
- TEMP_NOW=Display_Digit[2]*10+Display_Digit[1]+Display_Digit[0]*0.1 ;
- if(Display_Digit[3] == 0)
- Current_Temp_Display_Buffer[7] = ' ';
- if(Display_Digit[2] == 0&&Display_Digit[3]==0)
- Current_Temp_Display_Buffer[8] = ' ';
- if(ng)
- TEMP_NOW=-(Display_Digit[2]*10+Display_Digit[1]+Display_Digit[0]*0.1);
- if(Current_Temp_Display_Buffer[8] == ' ')
- Current_Temp_Display_Buffer[8] = '-';
- else if(Current_Temp_Display_Buffer[7] == ' ')
- Current_Temp_Display_Buffer[7] = '-';
- else
- Current_Temp_Display_Buffer[6] = '-';
- void Delay_key()
- uchar i;
- for(i=0;i<200;i++);
- uchar Keys_Scan()
- uchar sCode,kCode,k;
- P1 = 0xf0;
- if((P1&0xf0)!=0xf0)
- Delay_key();
- sCode = 0xfe;
- for(k=0;k<4;k++)
- P1 = sCode;
- kCode = ~P1;
- if(kCode == KeyCodeTable[0]) return K_ONE;
- else if(kCode == KeyCodeTable[1]) return K_TWO;
- else if(kCode == KeyCodeTable[2]) return K_THREE;
- else if(kCode == KeyCodeTable[3]) return K_FOUR;
- else if(kCode == KeyCodeTable[4]) return K_FIVE;
- else if(kCode == KeyCodeTable[5]) return K_SIX;
- else if(kCode == KeyCodeTable[6]) return K_SEVEN;
- else if(kCode == KeyCodeTable[7]) return K_EIGHT;
- else if(kCode == KeyCodeTable[8]) return K_NINE;
- else if(kCode == KeyCodeTable[9]) return K_UP;
- else if(kCode == KeyCodeTable[10]) return K_DOWN;
- else if(kCode == KeyCodeTable[11]) return K_CLEAR;
- else if(kCode == KeyCodeTable[12]) return K_OK;
- else if(kCode == KeyCodeTable[13]) return K_ZERO;
- else if(kCode == KeyCodeTable[14]) return K_POINT;
- else if(kCode == KeyCodeTable[15]) return K_SET;
- else
- sCode = _crol_(sCode,1);
- return -1;
- void set_num()
- uchar key;
- if(sel==0)
- key = Keys_Scan();
- if(K_CLEAR == key)
- while(Keys_Scan() == K_CLEAR);
- set_Temp_Display_Buffer[8] =' ';
- set_Temp_Display_Buffer[9] =' ';
- set_Temp_Display_Buffer[10]=' ';
- set_Temp_Display_Buffer[11]=' '; // 48(0)49(1)50(2)51(3)52(4)53(5)54(6)55(7)56(8)57(9)
- M_Count=0;
- cold=0;
- warm=0;
- if(K_UP == key)
- while(Keys_Scan() == K_UP);
- if((set_Temp_Display_Buffer[11]>47)&&(set_Temp_Display_Buffer[11]<57))
- set_Temp_Display_Buffer[11]+=1;
- else if(set_Temp_Display_Buffer[11]==57)
- set_Temp_Display_Buffer[11]=48;
- if((set_Temp_Display_Buffer[9]>47)&&(set_Temp_Display_Buffer[9]<57))
- set_Temp_Display_Buffer[9]+=1;
- else if(set_Temp_Display_Buffer[9]==57)
- set_Temp_Display_Buffer[9]=48;
- if((set_Temp_Display_Buffer[8]>47)&&(set_Temp_Display_Buffer[8]<57))
- set_Temp_Display_Buffer[8]+=1;
- else if(set_Temp_Display_Buffer[8]==57)
- set_Temp_Display_Buffer[8]=48;
- if(K_DOWN == key) // 48(0)49(1)50(2)51(3)52(4)53(5)54(6)55(7)56(8)57(9)
- while(Keys_Scan() == K_DOWN);
- if((set_Temp_Display_Buffer[11]>48)&&(set_Temp_Display_Buffer[11]<58))
- set_Temp_Display_Buffer[11]-=1;
- else if(set_Temp_Display_Buffer[11]==48)
- set_Temp_Display_Buffer[11]=57;
- if((set_Temp_Display_Buffer[9]>48)&&(set_Temp_Display_Buffer[9]<58))
- set_Temp_Display_Buffer[9]-=1;
- else if(set_Temp_Display_Buffer[9]==48)
- set_Temp_Display_Buffer[9]=57;
- if((set_Temp_Display_Buffer[8]>48)&&(set_Temp_Display_Buffer[8]<58))
- set_Temp_Display_Buffer[8]-=1;
- else if(set_Temp_Display_Buffer[8]==48)
- set_Temp_Display_Buffer[8]=57;
- if(K_ONE == key)
- while(Keys_Scan() == K_ONE);
- set_Temp_Display_Buffer[11]='1';
- sel++;
- if(K_TWO == key)
- while(Keys_Scan() == K_TWO);
- set_Temp_Display_Buffer[11]='2';
- sel++;
- if(K_THREE == key)
- while(Keys_Scan() == K_THREE);
- set_Temp_Display_Buffer[11]='3';
- sel++;
- if(K_FOUR == key)
- while(Keys_Scan() == K_FOUR);
- set_Temp_Display_Buffer[11]='4';
- sel++;
- if(K_FIVE == key)
- while(Keys_Scan() == K_FIVE);
- set_Temp_Display_Buffer[11]='5';
- sel++;
- if(K_SIX == key)
- while(Keys_Scan() == K_SIX);
- set_Temp_Display_Buffer[11]='6';
- sel++;
- if(K_SEVEN == key)
- while(Keys_Scan() == K_SEVEN);
- set_Temp_Display_Buffer[11]='7';
- sel++;
- if(K_EIGHT == key)
- while(Keys_Scan() == K_EIGHT);
- set_Temp_Display_Buffer[11]='8';
- sel++;
- if(K_NINE == key)
- while(Keys_Scan() == K_NINE);
- set_Temp_Display_Buffer[11]='9';
- sel++;
- if(K_ZERO == key)
- while(Keys_Scan() == K_ZERO);
- set_Temp_Display_Buffer[11]='0';
- sel++;
- if(K_OK == key)
- while(Keys_Scan() == K_OK);
- TEMP_SET=(set_Temp_Display_Buffer[8]-48)*10+(set_Temp_Display_Buffer[9]-48)+(set_Temp_Display_Buffer[11]-48)*0.1;
- sel=0;
- M_Count=1;
- if(sel==1)
- M_Count=0;
- cold=0;
- warm=0;
- sel=0;
- if(K_ONE == key)
- set_Temp_Display_Buffer[10]=set_Temp_Display_Buffer[11] ;
- sel++;
- if(K_TWO == key)
- sel++;
- sel++;
- if(K_FOUR == key)
- sel++;
- if(K_FIVE == key)
- sel++;
- if(K_SIX == key)
- sel++;
- sel++;
- sel++;
- if(K_NINE == key)
- sel++;
- if(K_ZERO == key)
- sel++;
- if(sel==2)
- M_Count=0;
- cold=0;
- warm=0;
- sel=0;
- if(K_POINT == key)
- while(Keys_Scan() == K_POINT);
- set_Temp_Display_Buffer[9]=set_Temp_Display_Buffer[10] ;
- set_Temp_Display_Buffer[11]='.';
- sel++;
- if(sel==3)
- M_Count=0;
- cold=0;
- warm=0;
- sel=0;
- if(K_ONE == key)
- set_Temp_Display_Buffer[8]=set_Temp_Display_Buffer[9] ;
- sel++;
- if(K_TWO == key)
- sel++;
- sel++;
- if(K_FOUR == key)
- sel++;
- if(K_FIVE == key)
- sel++;
- if(K_SIX == key)
- sel++;
- sel++;
- sel++;
- if(K_NINE == key)
- sel++;
- if(K_ZERO == key)
- sel++;
- if(sel==4)
- M_Count=0;
- cold=0;
- warm=0;
- sel=0;
- if(K_OK == key)
- sel=0;
- M_Count=1;
- ////////////////////Ö÷3ìDò///////////////////////////////
- void main()
- init_lcd();
- Init_DS18B20();
- timer0_init();
- while(1)
- Print();
- set_num();
- Comparison();
- void Comparison()
- if(N_Count&&M_Count)
- if(TEMP_NOW<TEMP_SET)
- warm=1;
- cold=0;
- if(TEMP_NOW>TEMP_SET)
- cold=1;
- warm=0;
- if(TEMP_NOW==TEMP_SET)
- cold=0;
- warm=0;
復(fù)制代碼 |
