數(shù)碼管顯示異常怎么修改單片機代碼?
查看數(shù): 3413 | 評論數(shù): 5 | 收藏 0
發(fā)布時間: 2019-4-2 10:02
#include <reg52.h>   #define uchar unsigned char #define uint  unsigned int #include <intrins.h> uchar a_a; uchar code smg_du[]={0x28,0xee,0x32,0xa2,0xe4,0xa1,0x2 ...
ID:481641 發(fā)表于 2019-4-3 16:31
改數(shù)組
ID:96682 發(fā)表于 2019-4-3 15:40
明顯原理圖與程序不匹配,樓主得提供電路圖才好修改
ID:213173 發(fā)表于 2019-4-3 13:28
改為:
uchar code smg_du[]={//共陽數(shù)碼管段碼"0~f"
                0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
                0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
uchar dis_smg[4];//顯示數(shù)字緩存
ID:501901 發(fā)表于 2019-4-2 22:24
是共陰的還是共陽的不要搞反
ID:67356 發(fā)表于 2019-4-2 22:18
uchar code smg_du[]={0x28,0xee,0x32,0xa2,0xe4,0xa1,0x21,0xea,0x20,0xa0,
                       0x60,0x25,0x39,0x26,0x31,0x71,0xff};
把這里改一下
