基于單片機(jī)的酒精濃度測(cè)試儀的設(shè)計(jì)
查看數(shù): 4813 | 評(píng)論數(shù): 8 | 收藏 3
發(fā)布時(shí)間: 2019-6-12 15:02
設(shè)計(jì)的是一種以酒精濃度傳感器、AT89C51單片機(jī)和A/D轉(zhuǎn)換器為主的,檢測(cè)駕駛員呼出氣體的酒精濃度的,而且還帶有聲光報(bào)警功能的酒精濃度檢測(cè)儀。這種檢測(cè)儀不僅可以檢測(cè)出空氣環(huán)境中酒精濃度值,還可以由不同的環(huán)境來(lái) ...
ID:782510 發(fā)表于 2020-12-8 23:43
有仿真圖嗎
ID:659880 發(fā)表于 2020-6-15 10:22
這個(gè)原理圖不清晰呀,還有beep的端口是干啥用的呀
ID:553887 發(fā)表于 2019-6-20 22:14
gagalonghun 發(fā)表于 2019-6-18 15:18
是這個(gè),這個(gè)是正確的
#include
#include
樓主負(fù)責(zé)又細(xì)心
ID:519003 發(fā)表于 2019-6-18 15:18
是這個(gè),這個(gè)是正確的
#include <reg51.h>
#include <intrins.h>
#include <stdio.h>
#define uint unsigned int
#define uchar unsigned char
/**********************定義全局變量***************/
//unsigned char dat=0x00 ;  //AD值
unsigned char count = 0x00;  //定時(shí)器計(jì)數(shù)
unsigned char channel;   //通道變量
//ADC0832的引腳
sbit ADCS =P1^2;  //ADC0832 chip seclect
sbit ADDI =P1^1;  //ADC0832 k in
sbit ADDO =P1^1;  //ADC0832 k out
sbit ADCLK =P1^0;  //ADC0832 clock signal
unsigned char dispbuf[3];
uint temp;
uint alc;//酒精濃度
uchar dat; //獲取ADC轉(zhuǎn)換回來(lái)的值
uchar *aa="M=T.TTmg/L";
uchar *cc="alarm";
uchar *dd=" ";
uint sheding=60;
uchar bb[16]={'A','l','c','o','h','o','l','=',' ','.',' ',' ','m','g','/','L'};
sbit RS = P2^0;   //定義端口
sbit RW = P2^1;
sbit EN = P2^2;
sbit beep=P3^7;
sbit k1=P1^3;//+鍵
sbit k2=P1^4;//-鍵
#define RS_CLR RS=0
#define RS_SET RS=1
#define RW_CLR RW=0
#define RW_SET RW=1
#define EN_CLR EN=0
#define EN_SET EN=1
void DelayUs2x(unsigned char t);
void DelayMs(unsigned char t);
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s);
void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data);
void init();
void write_com(unsigned char com);
void write_data(unsigned char date);
while(--t);
while(t--)
//大致延時(shí)1mS
DelayUs2x(245);
         DelayUs2x(245);
/*********************************lcd1602各子函數(shù)**************************************/
void write_com(unsigned char com) //寫(xiě)命令
        RS_CLR;
        RW_CLR;
        P0=com;
        DelayMs(5);
        EN_SET;
        DelayMs(5);
        EN_CLR;
void write_data(unsigned char date)         //寫(xiě)一個(gè)字符
        RS_SET;
        RW_CLR;
        P0=date;
        DelayMs(5);
        EN_SET;
        DelayMs(5);
        EN_CLR;
void initlcd()                        //初始化
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
  寫(xiě)入字符串函數(shù)
if (y == 0)
         write_com(0x80 + x);
else
        write_com(0xC0 + x);
while (*s)
write_data( *s);
s ++;
  寫(xiě)入字符函數(shù)
if (y == 0)
else
write_data(Data);
函數(shù)功能:AD轉(zhuǎn)換子程序
入口參數(shù):CH
出口參數(shù):dat
//采集并返回
unsigned char Adc0832(unsigned char channel) //AD轉(zhuǎn)換,返回結(jié)果
uchar i=0;
uchar j;
uchar dat=0;
uchar ndat=0;
if(channel==0)channel=2;
if(channel==1)channel=3;
ADDI=1;
_nop_();
_nop_();
ADCS=0;//拉低CS端
_nop_();
_nop_();
ADCLK=1;//拉高CLK端
_nop_();
_nop_();
ADCLK=0;//拉低CLK端,形成下降沿1
_nop_();
_nop_();
ADCLK=1;//拉高CLK端
ADDI=channel&0x1;
_nop_();
_nop_();
ADCLK=0;//拉低CLK端,形成下降沿2
_nop_();
_nop_();
ADCLK=1;//拉高CLK端
ADDI=(channel>>1)&0x1;
_nop_();
_nop_();
ADCLK=0;//拉低CLK端,形成下降沿3
ADDI=1;//控制命令結(jié)束
_nop_();
_nop_();
dat=0;
for(i=0;i<8;i++)
dat|=ADDO;//收數(shù)據(jù)
ADCLK=1;
_nop_();
_nop_();
ADCLK=0;//形成一次時(shí)鐘脈沖
_nop_();
_nop_();
dat<<=1;
if(i==7)dat|=ADDO;
for(i=0;i<8;i++)
j=0;
j=j|ADDO;//收數(shù)據(jù)
ADCLK=1;
_nop_();
_nop_();
_nop_();
_nop_();
j=j<<7;
ndat=ndat|j;
if(i<7)ndat>>=1;
ADCS=1;//拉低CS端
ADCLK=0;//拉低CLK端
ADDO=1;//拉高數(shù)據(jù)端,回到初始狀態(tài)
dat<<=8;
dat|=ndat;
return(dat);//return ad k
函數(shù)功能:定時(shí)器中斷延時(shí)程序 這一段的作用時(shí)隔一段時(shí)間抽樣一次 否側(cè)顯示的最后一位會(huì)不穩(wěn)定
入口參數(shù):
出口參數(shù):
void timer0(void) interrupt 1
   TMOD = 0x01;
   TH0 = 0x00;
   TL0 = 0x00;
   IE = 0x82;
   TR0 = 01;
   count++;
  if (count == 0x0A)
   count = 0x00;
   dat= Adc0832(channel);
/*void format_data(uint dat)
  uint change_dat=dat;
  uchar ptr[3];
  change_dat=(change_dat<<8)+(change_dat<<7)+(change_dat<<6)+(change_dat<<5)+(change_dat<<4)+(change_dat<<2);//乘500
  change_dat=change_dat>>8;//除以256
  ptr[0]=change_dat/100;   //得到個(gè)位數(shù)字
  ptr[1]=(change_dat-(100*ptr[0]))/10; //得到十分位數(shù)字
  ptr[2]=change_dat-(100*ptr[0])-(10*ptr[1]); //得到百分位數(shù)字
void keyscan()
   if(!k1)
  DelayMs(5);
                 if(!k1)
                        while(!k1);
                        sheding+=5;
LCD_Write_Char(2,1,sheding/100+'0');
                        LCD_Write_Char(4,1,sheding%100/10+'0');
                        LCD_Write_Char(5,1,sheding%10+'0');
   if(!k2)
          DelayMs(5);
                 if(!k2)
                        while(!k2);
                        sheding-=5;
函數(shù)功能:主程序
入口參數(shù):
出口參數(shù):
void main(void)
  uchar i;
  P2=0xff;   //端口初始化
  P0=0xff;
  P3=0xff;
  channel=0x00;  //channel=0
  TMOD = 0x01;
  TH0 = 0x00;
  TL0 = 0x00;
  IE = 0x82;
  TR0 = 01;
  initlcd();
  LCD_Write_String(0,0,bb);
  LCD_Write_String(0,1,aa);
  //LCD_Write_String(11,1,cc);
   temp=dat*1.0/255*500;  //電壓值轉(zhuǎn)換,5V做為參考電壓,分成256份。
   if(temp<187)
         alc=100*(temp-8)/895;
   else
alc=100*(temp-133)/272;
          dispbuf[0]=alc%10+'0';         //個(gè)位
          dispbuf[1]=alc/10%10+'0'; //十位
          dispbuf[2]=alc/100%10+'0'; //百位
          //dispbuf[0]=temp%10+'0';         //個(gè)位
          //dispbuf[1]=temp/10%10+'0'; //十位
          //dispbuf[2]=temp/100%10+'0'; //百位
          LCD_Write_Char(8,0,dispbuf[2]);
          LCD_Write_Char(10,0,dispbuf[1]);
          LCD_Write_Char(11,0,dispbuf[0]);
          keyscan();
          if(alc>sheding)
        //beep=0;
                for(i=0;i<10;i--)
                         beep=0;
                         DelayMs(1);
                         beep=1;
          else
        LCD_Write_String(11,1,dd);
ID:519003 發(fā)表于 2019-6-18 15:17
錯(cuò)誤較多,我發(fā)源碼給你
#include<reg51.h>
#include"delay.h"
#include"lcd602.h"
#include"ds18b20.h"
//**************端口定義*******************
sbit LED = P1^0;
sbit k1 = P1^4;
sbit k2 = P1^5;
sbit k3 = P1^6;
//**************數(shù)組定義*******************
uchar code tab2[]={"Temp:     "}; //5
uchar code tab3[]={" H     "}; //3
uchar code tab4[]={"L     "}; //8
//**************變量定義*******************
int temp1 = 400;   //上限
int temp3 = 100;         //下限
bit flag = 0;         //上下限選擇標(biāo)志
int temp4; //當(dāng)上限減到負(fù)數(shù)時(shí)
uchar temp5 = 0;
/*******************按鍵********************/
void key()
     if(flag == 0) //上限
                 write_zifu(2,0,'*');
                 write_zifu(2,8,' ');
             if(k1 == 0)
                    delayxms(5);
                        while(k1 == 0);
                        temp1 += 10;
                 if(k2 == 0)
                    delayxms(5);
                        while(k2 == 0);
                        temp1 -= 10;
         if(flag == 1)        //下限
                 write_zifu(2,0,' ');
                 write_zifu(2,8,'*');
             if(k1 == 0)
                    delayxms(5);
                        while(k1 == 0);
                        temp3 += 10;
                 if(k2 == 0)
                    delayxms(5);
                        while(k2 == 0);
                        temp3 -= 10;
         if(k3 == 0) //上下限選擇標(biāo)志
            delayxms(5);
                while(k3 == 0);
                flag = ~flag;
/*******************定時(shí)器T1初始化********************/
void T1_init()
          TMOD = TMOD | 0x10;            //設(shè)T1為方式1
          TH1 = (65535-20000)/256;       //計(jì)數(shù)20000個(gè)
          TL1 = (65535-20000)%256;
          EA = 1;                        //開(kāi)啟總中斷
          ET1 = 1;                       //允許T1中斷
          TR1 = 1;                       //啟動(dòng)
/*******************主函數(shù)********************/
void main()
            chushihua();//lcd1602初始化
          write_string(1,0,tab2);
          write_string(2,0,tab3);
          write_string(2,9,tab4);
          T1_init();
                          key();
                          ds1820disp();
                          /*溫度上限*/
                      if(temp1 < 0)
                                   write_zifu(2,2,'-');
                                   temp4 = temp1;
                                   temp4 = ~temp4;
                                   temp4 += 1;
                                     write_num3(2,3,temp4);
                                   write_zifu(2,7,' ');
                          else
                                     write_zifu(2,2,'+');
                                   if(temp1>=1000)
                                              write_num4(2,3,temp1);
                                   else
                                              write_num3(2,3,temp1);
                          /*溫度下限*/
                      if(temp3 < 0)
                                   write_zifu(2,10,'-');
                                     write_num3(2,11,-(temp3));
                                   write_zifu(2,15,' ');
                          else
                                     write_zifu(2,10,'+');
                                   if(temp3>=1000)
                                   {write_num4(2,11,temp3);}
                                   else
                                   {write_num3(2,11,temp3);}
                          /*報(bào)警*/
                          if(flag_temp == 1) //溫度小于零
                              if((-t)>temp1 || (-t)<temp3) {LED = 0;}
                              else {LED = 1;}
                          else //溫度大于零
                              if(t>temp1 || t<temp3) {LED = 0;}
                              else {LED = 1;}
/**************************定時(shí)器T1中斷服務(wù)函數(shù)************************************/
void T1_time() interrupt 3
          temp5 += 1;
          if(temp5 >= 25)
             temp5 = 0;
                 TR1 = 0;
                 ReadTemperature();
                 TR1 = 1;
ID:519003 發(fā)表于 2019-6-18 15:14
第15行的unsigned chardispbuf[3];改為unsigned char dispbuf[3];//char后打一個(gè)空格就行了
ID:553887 發(fā)表于 2019-6-12 22:11
怎么改呢
ID:553887 發(fā)表于 2019-6-12 22:10
MAIN.C(16): error C129: missing ';' before 'temp'
