發(fā)布時(shí)間: 2020-4-30 18:53
正文摘要:樓主用51單片機(jī)做的串口通信,通信正常,但是主機(jī)的lcd無法顯示發(fā)送的數(shù)據(jù)代碼在這里,請(qǐng)大佬幫忙看看 ORG 0000H JMP START ORG 0100H START: ACALL INIT MAIN: MOV P2,#0F0H MOV A,P2 XRL A,#0F0H JZ M ... |
已經(jīng)解決了。。。 發(fā)送端 ORG 0000H JMP START ORG 0100H START: ACALL INIT MAIN: MOV P2,#0F0H MOV A,P2 XRL A,#0F0H JZ MAIN ACALL KEYSCAN MOV A,30H MOV DPTR,#TABLE2 MOVC A,@A+DPTR MOV R2,A CJNE A,#79H,SHOW MOV A,#0C0H MOV P1,A ACALL ENABLE MOV P1,R2 SETB P0.5 CLR P0.4 CLR P0.3 ACALL DELAY2 SETB P0.3 ACALL DELAY ALOOP1: MOV 40H,R2 MOV SBUF,#0E1H JNB TI,$;·¢ËíÖD¶Ï CLR TI JNB RI,$;½óêÕÖD¶Ï CLR RI MOV A,SBUF;¶toÅ»úó|′eDÅoÅ XRL A,#0E2H;òì»òÅD¶¨êÇ·ñ×¼±¸íê±Ï£¨ÅD¶Ï·¢ËíÏûÏ¢êÇ·ñÎa#0E2£© JNZ ALOOP1;¿aê¼·¢Ëíêy¾Yê±¶¨òå3õê¼μØÖ·,Õa¸öμØÖ·àïÃæ′æ′¢òa·¢ËíμÄêy¾Y MOV R0,#40H MOV R6,#00H;D£Ñéoí ALOOP2: MOV SBUF,@R0 MOV A,R6 ADD A,@R0 MOV R6,A JNB TI,$ CLR TI MOV SBUF,R6 JNB TI,$;·¢ËíÖD¶Ï CLR TI JNB RI,$;½óêÕó|′eÖD¶Ï CLR RI MOV A,SBUF XRL A,#00H JNZ ALOOP2 JMP MAIN SHOW: MOV P1,A SETB P0.5 CLR P0.4 CLR P0.3 ACALL DELAY2 SETB P0.3 ACALL DELAY JMP ALOOP1 INIT: MOV A,#00000001B MOV P1,A ACALL ENABLE MOV A,#00111000B MOV P1,A ACALL ENABLE MOV A,#00001111B MOV P1,A ACALL ENABLE MOV A,#00000110B MOV P1,A ACALL ENABLE MOV A,#00H MOV P1,A ACALL ENABLE CLR EA MOV TMOD,#20H MOV TH1,#0F4H MOV TL1,#0F4H MOV PCON,#00H SETB TR1 MOV SCON,#50H KEYSCAN:MOV P2,#0F0H;Ïè¶ááDÔù¶áDD MOV A,P2 ANL A,#0F0H MOV R3,A MOV P2,#0FH MOV A,P2 ANL A,#0FH ORL A,R3 CJNE A,#0FFH,KEYPRO;¼ì2a¼üÖμêÇ·ñ3é1|¶áèë RET KEYPRO: MOV R3,A MOV DPTR,#KEYVALUE MOV R4,#0FFH;′æ¼üÖμ±íμ½¼üÂë±íμÄÆ«òÆá¿ KEY1: INC R4 ;é¨Ãè¼üÂë±íàïÃæμÄêyÖμ MOV A,R4 MOVC A,@A+DPTR CJNE A,03H,KEY1 MOV A,R4 MOV 30H,A DELAY1: MOV R6,#60H;Ñóê±3ìDò DE2: MOV R7,#90H DJNZ R7,$ DJNZ R6,DE2 RET ENABLE: CLR P0.5;D′Ãüáî CLR P0.4 CLR P0.3 ACALL DELAY2 SETB P0.3 RET DELAY2: MOV P1,#0FFH CLR P0.5 SETB P0.4 CLR P0.3 NOP SETB P0.3 JB P1.7,DELAY2 RET DELAY: MOV R5,#10H;Ñóê±3ìDò D1: MOV R6,#30H D2: MOV R7,#90H DJNZ R7,$ DJNZ R6,D2 DJNZ R5,D1 RET KEYVALUE:DB 0E7H,0D7H,0B7H,077H,0EBH,0DBH,0BBH,07BH,0EDH,0DDH,0BDH,07DH,0EEH,0DEH,0BEH,07EH;¼üÂë¾ØÕó TABLE2: DB 30H,31H,33H,38H,64H,69H,61H,6EH,6BH,65H,79H,74H,67H,3CH,5FH,3EH END 接收端 ORG 0000H JMP START ORG 0100H START: ACALL INIT JMP BLOOP1 BLOOP1: JNB RI,$ CLR RI MOV A,SBUF XRL A,#0E1H JNZ BLOOP1 MOV SBUF,#0E2H JNB TI,$ CLR TI MOV R0,#40H MOV R6,#00H BLOOP2: JNB RI,$ CLR RI MOV A,SBUF MOV @R0,A ADD A,R6 MOV R6,A JNB RI,$ CLR RI MOV A,SBUF XRL A,R6 JZ END1 MOV SBUF,#0FFH JNB TI,$ CLR TI SJMP BLOOP1 END1: MOV SBUF,#00H JNB TI,$ CLR TI CJNE @R0,#79H,SHOW MOV A,#0C0H MOV P2,A ACALL ENABLE MOV P2,@R0 SETB RS CLR RW CLR E ACALL DELAY SETB E ACALL DELAY1 JMP BLOOP1 SHOW: MOV P2,@R0 SETB P1.4 CLR P1.3 CLR P1.2 ACALL DELAY SETB P1.2 ACALL DELAY1 JMP BLOOP1 INIT: RS EQU P1.4 RW EQU P1.3 E EQU P1.2 MOV P2,#00000001B ACALL ENABLE MOV P2,#00111000B ACALL ENABLE MOV P2,#00001111B ACALL ENABLE MOV P2,#00000110B ACALL ENABLE MOV P2,#00H ACALL ENABLE CLR EA MOV TMOD,#20H MOV TH1,#0F4H MOV TL1,#0F4H MOV PCON,#00H SETB TR1 MOV SCON ,#50H RET ENABLE: CLR RS CLR RW CLR E ACALL DELAY SETB E RET DELAY: MOV P2,#0FFH CLR RS SETB RW CLR E NOP SETB E JB P2.7,DELAY RET DELAY1: MOV R5,#10H;Ñóê±3ìDò D1: MOV R6,#30H D2: MOV R7,#90H DJNZ R7,$ DJNZ R6,D2 DJNZ R5,D1 RET END |
不知道是什么問題,lcd的輸入口沒有電平變化,是因?yàn)槲业难訒r(shí)程序的問題嗎 |
同樣的程序?yàn)槭裁礇]有串口通信模塊就可以正常顯示數(shù)據(jù)呢 |
