發(fā)布時(shí)間: 2020-11-22 15:37
正文摘要:顯示屏12864 用89C52點(diǎn)亮,下一步準(zhǔn)備把DS12887搞一起再做一個(gè)電子時(shí)鐘。顯示屏要加大。 |
顯示畫面切換的速度太快了,拍照正好拍到這個(gè)切換的畫面的時(shí)間點(diǎn)上了,就是上面這個(gè)結(jié)果,我用到現(xiàn)在平是沒問題。 |
樓主的屏有問題啊,顯示濃淡不一,如果不是硬件故障那就是初始化代碼設(shè)置有錯(cuò)誤,比如分壓比等參數(shù) |
本帖最后由 mengsiu 于 2021-10-17 22:09 編輯 正常點(diǎn)亮 ![]() |
留個(gè)記號(hào)。我好像有一個(gè)6963的。 |
#include <regx52.h> #define DataPort P2 sbit Wr=P1^0; sbit Rd=P1^1; sbit CD=P1^2; sbit CS=P1^3; sbit RST=P1^4; //unsigned char void t(unsigned char para) {for(;para;para--);} void delay(unsigned int para) { unsigned int wdtime=0xffff; for(;para;para--) for(;wdtime;wdtime--); } void InstruWrite(unsigned char param) { RST=1;CS=1;Wr=1;Rd=1;CD=1; CS=0;Wr=1;Rd=1;CD=1; Wr=0;//CD=1; t(5); DataPort=param; t(6); CS=0;Wr=1;CD=1; RST=1;CS=1;Wr=1;Rd=1;CD=1; } void DataWrite(unsigned char param) { RST=1;CS=1;Wr=1;Rd=1;CD=1; CS=0;Wr=1;Rd=1;CD=0; Wr=0;//CD=0; t(5); DataPort=param; t(6); CS=0;Wr=1;CD=1; RST=1;CS=1;Wr=1;Rd=1;CD=1; } void AutoWrite(void) { InstruWrite(0xb0); } void AutoEnd(void) { InstruWrite(0xb2); } void TextHomeSet(unsigned char paraH,unsigned char paraL) { DataWrite(paraL); DataWrite(paraH); InstruWrite(0x40); } void TextAreaSet(unsigned char columns) { DataWrite(columns);DataWrite(0x00); InstruWrite(0x41); } void GraphicHomeSet(unsigned char paraH,unsigned char paraL) { DataWrite(paraL);DataWrite(paraH); InstruWrite(0x42); } void GraphicAreaSet(unsigned char columns) { DataWrite(columns);DataWrite(0x00); InstruWrite(0x43); } /* void CursorSet(unsigned char para) { InstruWrite(para); } */ void AddressSet(unsigned char paraH,unsigned char paraL) { DataWrite(paraL); DataWrite(paraH); InstruWrite(0x24); } void ModeSet(unsigned char para) { InstruWrite(para); } void InitLcd(void) { TextHomeSet(0x00,0x00); TextAreaSet(22); GraphicHomeSet(0x00,0xb0); GraphicAreaSet(22); ModeSet(0x80); } /* void Printf(unsigned char position,unsigned char leng,unsigned char ptr) { InstruWrite(0x97); AddressSet(0x00,position); InstruWrite(0xa7); AutoWrite(); for(;leng;leng--) { DataWrite(ptr++); if(ptr>0x80)ptr=0x00; } AutoEnd(); } */ void Character(void) { unsigned char x,y,d=0x00; InstruWrite(0x97); //text mode AddressSet(0x00,0x00); InstruWrite(0xa7); AutoWrite(); for(x=0x00;x<22;x++) { for(y=0x00;y<16;y++) { DataWrite(d++); if(d>0x80) d=0x00; //7f } } AutoEnd(); } void Bar(void) { unsigned char x,y; InstruWrite(0x98); AddressSet(0x00,0xb0); AutoWrite(); for(y=0;y<64;y++) for(x=0;x<11;x++) { if(y+6*x>=64) DataWrite(0xff); else DataWrite(0x00); DataWrite(0x00); } AutoEnd(); } void ET(void) { unsigned char x,y; InstruWrite(0x97); AddressSet(0x00,0x00); AutoWrite(); for(y=0;y<8;y++) for(x=0;x<22;x++) { DataWrite(0x25);DataWrite(0x34); } AutoEnd(); } void Boundary(void) { unsigned char x,y; InstruWrite(0x98); AddressSet(0x00,0xb0); AutoWrite(); for(y=0;y<64;y++) for(x=0;x<22;x++) { if(y==0||y==63) DataWrite(0xff); else { if(x==0) DataWrite(0x20); else { if(x==21) DataWrite(0x10); else DataWrite(0x00); } } } AutoEnd(); } void CheckBoard(unsigned char paraA,unsigned char paraB) { unsigned char i,j; InstruWrite(0x98); //graghic mode AddressSet(0x00,0xb0); AutoWrite(); for(i=0;i<32;i++) { for(j=0;j<22;j++) DataWrite(paraA); for(j=0;j<22;j++) DataWrite(paraB); } AutoEnd(); } void main(void) { unsigned char i=0; InitLcd(); for(;1;i++,i%=8) { switch(i) { case 0: Character(); break; case 1: Boundary(); break; case 2: Bar(); break; case 3: CheckBoard(0xff,0xff);break; case 4: CheckBoard(0x00,0x00);break; case 5: CheckBoard(0xaa,0x55);break; case 6: CheckBoard(0x55,0xaa);break; case 7: ET(); break; } delay(0x5fff); //while(1); } } |
![]() | + 40 | 回帖助人的獎(jiǎng)勵(lì)! |
