單片機60s計時器程序,自動計時,無返回 求幫助
查看數(shù): 3005 | 評論數(shù): 8 | 收藏 0
發(fā)布時間: 2020-11-28 16:17
60s計時器,自動計時,無返回
ID:860490 發(fā)表于 2020-12-15 12:51
驗證過了,程序電路都沒有問題
ID:825693 發(fā)表于 2020-12-15 12:29
統(tǒng)一回復(fù)下,這是做的一個分享作品,不是求幫的
ID:535215 發(fā)表于 2020-11-28 18:28
#include<reg51.h>
unsigned char code discode1[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char code discode2[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char second;
unsigned int timer;
void main()
                TMOD = 0x01;
                EA=1;            //總中斷打開
                ET0=1;           //定時器中斷打開
                second=0;
                TR0=1;
                                   if(second<60)
                                   {P0=discode1[second/10];
                   P2=discode2[second%10];
                   else if(second==60)
                                   {second=0;}
void int_T0() interrupt 1 using 0
                TH0=0xee;
        TL0=0x00;
        timer ++;
        if(timer==200)
                timer = 0;
                second ++;
按照這個來 你試一試
ID:278840 發(fā)表于 2020-11-28 18:16
HAISONC 發(fā)表于 2020-11-28 18:10
//0-59自動計數(shù)器
//跳線設(shè)置:默認
#include
[code]
  //0-59自動計數(shù)器
//跳線設(shè)置:默認
#include<reg51.h>
unsigned int timer;
void main()
                TMOD = 0x01;
                EA=1;            //總中斷打開
                ET0=1;           //定時器中斷打開
                second=0;
                TR0=1;
                                   if(second<60)
                   else if(second==60)
                                   {second=0;}
                TH0=0xee;
        TL0=0x00;
        timer ++;
        if(timer==200)
                timer = 0;
                second ++;
}//這個是循環(huán)計時我驗證過了
ID:838732 發(fā)表于 2020-11-28 18:10
  //0-59自動計數(shù)器
//跳線設(shè)置:默認
#include<reg51.h>
unsigned int timer;
void main()
                TMOD = 0x01;
                EA=1;            //總中斷打開
                ET0=1;           //定時器中斷打開
                second=0;
                TR0=1;
                                   if(second<60)
                                   {P0=~discode1[second/10];
                   P2=~discode2[second%10];
                   else if(second==60)
                                   {second=0;}
                TH0=0xee;
        TL0=0x00;
        timer ++;
        if(timer==200)
                timer = 0;
                second ++;
我改了下程序,我的電路是共陽的,所以取反,測試時可行的,你試試
ID:278840 發(fā)表于 2020-11-28 17:50
  1. //0-59自動計數(shù)器
  2. //跳線設(shè)置:默認
  3. #include<reg51.h>
  4. unsigned char code discode1[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  5. unsigned char code discode2[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  6. unsigned char timer=0;
  7. unsigned char second;
  8. bit back;
  9. main()
  10. {
  11.                 TMOD = 0x01;
  12.                 EA=1;            //總中斷打開
  13.                 ET0=1;           //定時器中斷打開
  14.                 second=0;
  15.                 TR0=1;
  16.                 P0=discode1[second/10];
  17.                 P2=discode2[second%10];
  18.                 while(1)
  19.                 {
  20.
  21.                 }
  22. }
  23. void int_T0() interrupt 1 using 0
  24. {
  25.         TR0=0;
  26.         TH0=0xee;
  27.         TL0=0x00;
  28.         timer ++;
  29.                 TR0 = 1;
  30.         if(timer==200)
  31.         {
  32.                 timer = 0;
  33.                                 if(second==0)
  34.                                 {
  35.                         back = 0;
  36.                                 }
  37.                                 if(second==60)
  38.                                 {
  39.                                         back = 1;
  40.                                 }
  41.                                 if(back==0)
  42.                                 {
  43.                                         second++;
  44.                                 }
  45.                                 else
  46.                                 {
  47.                                         second--;
  48.                                 }
  49.                 P0=discode1[second/10];
  50.                 P2=discode2[second%10];
  51.
  52.         }
  53.
  54. }
  55. 帶返回的
參與人數(shù) 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎勵!
ID:278840 發(fā)表于 2020-11-28 17:42
驗證過了,程序電路都沒有問題
ID:278840 發(fā)表于 2020-11-28 17:39
你是有問題,還是叫人幫你寫啊?樓主
