意外刪除INTRINS.h頭文件,只能重裝系統(tǒng)(怕意外,重裝是最徹底的)現(xiàn)導(dǎo)出文件
查看數(shù): 3032 | 評論數(shù): 5 | 收藏 0
發(fā)布時間: 2021-1-31 19:41
意外刪除INTRINS文件,只能重裝系統(tǒng),(怕意外,重裝是最徹底的)現(xiàn)導(dǎo)出文件給需要人。網(wǎng)上找了好久無法解決! 底層文件,解決大問題!
ID:820891 發(fā)表于 2021-2-7 11:54
嘩眾取寵有意義嗎
  1. INTRINS.H
  2. Intrinsic functions for C51.
  3. Copyright (c) 1988-2010 Keil Elektronik GmbH and ARM Germany GmbH
  4. All rights reserved.
  5. --------------------------------------------------------------------------*/
  6. #ifndef __INTRINS_H__
  7. #define __INTRINS_H__
  8. #pragma SAVE
  9. #if defined (__CX2__)
  10. #pragma FUNCTIONS(STATIC)
  11. /* intrinsic functions are reentrant, but need static attribute */
  12. #endif
  13. extern void          _nop_     (void);
  14. extern bit           _testbit_ (bit);
  15. extern unsigned char _cror_    (unsigned char, unsigned char);
  16. extern unsigned int  _iror_    (unsigned int,  unsigned char);
  17. extern unsigned long _lror_    (unsigned long, unsigned char);
  18. extern unsigned char _crol_    (unsigned char, unsigned char);
  19. extern unsigned int  _irol_    (unsigned int,  unsigned char);
  20. extern unsigned long _lrol_    (unsigned long, unsigned char);
  21. extern unsigned char _chkfloat_(float);
  22. #if defined (__CX2__)
  23. extern int           abs       (int);
  24. extern void          _illop_   (void);
  25. #endif
  26. #if !defined (__CX2__)
  27. extern void          _push_    (unsigned char _sfr);
  28. extern void          _pop_     (unsigned char _sfr);
  29. #endif
  30. #pragma RESTORE
  31. #endif
ID:701852 發(fā)表于 2021-2-6 13:40
zuiqf1978 發(fā)表于 2021-2-1 14:35
網(wǎng)上沒找到,又不想做伸手黨
keil刪了重裝
ID:413986 發(fā)表于 2021-2-5 14:33
沒了頭文件,自己再寫個不就是了
ID:366464 發(fā)表于 2021-2-1 14:35
wjcxy3166 發(fā)表于 2021-2-1 10:43
這個文件缺了不至于需要重新系統(tǒng)吧!嚴(yán)重了
網(wǎng)上沒找到,又不想做伸手黨
ID:288629 發(fā)表于 2021-2-1 10:43
