- #include<reg52.h>
- #include"stdio.h"
- typedef unsigned char uint8;
- typedef unsigned int uint16;
- sbit RS =P2^6; //LCD1602的數(shù)據(jù)命令選擇
- sbit RW = P2^5;
- sbit EN_LCD =P2^7; //LCD1602的使能信號(hào)
- sbit BUZZER = P1^5;
- sbit K1 = P3^0; //右
- sbit K2 = P3^1; //加
- sbit K3 = P3^2; //減
- /****************DS18B20引腳**********************/
- sbit DS18B20 = P3^7; //DS18B20數(shù)據(jù)端
- void delay(uint16 time); // 延時(shí)函數(shù)(6us單位)
- void lcd_ini(); // LCD1602的初始化
- void lcd_order(uint8 date); // 向LCD1602的寫(xiě)1個(gè)指令
- void lcd_data(uint8 date); // 向LCD1602的寫(xiě)1個(gè)指令
- void xie1602(uint8 add,uint8 daa); //寫(xiě)數(shù)據(jù)
- void xianshi1();//顯示溫度
- uint8 ds18_ini(); //ds18B20初使化函數(shù)
- void ds18_write(uint8 date); //功能向DS18B20中寫(xiě)入一個(gè)數(shù)據(jù)
- uint8 ds18_read(); //功能從DS18B20中讀出一個(gè)數(shù)據(jù)并返回。
- void ds18_check(); //起動(dòng)DS18B20行進(jìn)溫度采集,并返回當(dāng)前溫度(tmp)
- void xiugai(); //修改報(bào)警范圍
- long tmp=0; //儲(chǔ)存溫度值
- long t_h=37, t_l=10; // 溫度的上限和下限
- bit tmp_hb = 0; tmp_lb = 0; //溫度上下限調(diào)節(jié)指示變量
- void panduan(); //判斷報(bào)警
- uint8 hodometer[]= " H:00 L: 00 ";
- uint8 temp[]= " wendu:00.00 ";
- uint16 ji = 0;
- uint8 ku=0; //biaozhiwei
- void main()
- lcd_ini();
- ds18_ini(); //ds18B20初使化
- ds18_write(0xcc); //跳過(guò)序列號(hào)
- ds18_write(0x44); //啟動(dòng)溫度轉(zhuǎn)換
- xie1602(4,t_h);
- xie1602(12,t_l);
- while(1)
- ds18_check(); //從DS18B20中讀出溫度
- xianshi1();
- xiugai();
- panduan();
- lcd_order(0x80+add);
- lcd_data(0x30+daa/10);
- lcd_data(0x30+daa%10);
- //判斷是否在報(bào)警范圍內(nèi)
- void panduan()
- if(tmp<(t_l*1000)||tmp>(t_h*1000)&&t_l>=0)
- BUZZER = 0;
- delay(10);
- else if(t_l<0&&tmp>(t_h*1000))
- BUZZER = 1;
- else
- BUZZER = 1;
- //選擇修改的內(nèi)容
- void xiugai()
- { uint8 jj;
- uint8 i = 0;
- BUZZER = 1;
- if(K1==0)
- while(!K1);
- while(1)
- lcd_order(0x0f); //開(kāi)啟光標(biāo)顯示
- lcd_order(0x80+5);//光標(biāo)顯示位置
- if(K2 == 0) //判斷加按鍵按下
- while(K2 == 0); //等待按鍵釋放
- t_h++; //溫度上限加1
- xie1602(4,t_h); //將溫度上限顯示出來(lái)
- if(K3 == 0) //判斷減按鍵按下
- while(K3 == 0); //等待按鍵釋放
- if(t_h>t_l) //判斷 溫度上限大于溫度下限
- t_h--;
- if(K1 == 0) //后面的注釋類(lèi)似
- while(K1 == 0);
- while(1)
- lcd_order(0x0f);
- lcd_order(0x80+13);
- if(K2 == 0)
- while(K2 == 0);
- if(t_l<t_h&&t_l>=0)
- lcd_order(0x80+11);
- lcd_data(' ');
- t_l++;
- xie1602(12,t_l);
- else {
- t_l++;
- jj = ~t_l;
- xie1602(12,jj);
- if(K3 == 0)
- while(K3 == 0);
- if(t_l>(-50))
- t_l--;
- if(t_l<0)
- jj = ~t_l;
- if(t_l>=0)
- lcd_data(' ');
- xie1602(12,t_l);
- if(t_l<0)
- xie1602(12,jj);
- lcd_data('-');
- if(K1 == 0)
- while(K1 == 0);
- goto loop;
- loop:BUZZER = 1;
- 函數(shù)名:delay
- 行參 :time 延時(shí)基數(shù)
- 功能 :用while延時(shí)
- // 延時(shí)函數(shù)(1ms單位)
- while(time--);
- 函數(shù)名:lcd_ini
- 功能 :LCD1602的初始化
- void lcd_ini()
- uint8 i;
- RW = 0;
- lcd_order(0x38); //設(shè)置1602的顯示光標(biāo)功能
- delay(100);
- lcd_order(0x0e); //顯示開(kāi)及光標(biāo)設(shè)置
- delay(100);
- lcd_order(0x06); //顯示光標(biāo)移動(dòng)設(shè)置
- delay(100);
- lcd_order(0x01); //顯示清屏
- delay(100);
- lcd_order(0x80);
- for(i = 0;i<16;i++)
- lcd_data(hodometer[i]);
- 函數(shù)名:lcd_order
- 行參 :date 要定入的指令
- 功能 :向LCD1602的寫(xiě)1個(gè)指令
- RS=0; //選擇寫(xiě)指令
- EN_LCD=0; //使能初使化
- P0=date; //發(fā)送指令
- EN_LCD=1; //開(kāi)使能
- delay(100); //延時(shí)
- EN_LCD=0; //關(guān)使能
- 行參 :date 要定入的指令
- RS=1; //選擇寫(xiě)數(shù)據(jù)
- EN_LCD=0; //使能初使化
- DS18B20
- 函數(shù)名: ds18_ini
- 功能: 對(duì)DS18B20進(jìn)行初使化,
- 若DS18B20是好的則返回1
- 若DS18B20是環(huán)的則返回0
- //ds18B20初使化函數(shù),可根據(jù)資料上的時(shí)序來(lái)寫(xiě)
- uint8 ds18_ini()
- uint8 ans;
- DS18B20 = 1;
- delay(1);
- DS18B20 = 0;
- delay(100);
- DS18B20 = 1;
- delay(6);
- ans = DS18B20;
- delay(100);
- if(!ans)
- return 1;
- else
- return 0;
- 函數(shù)名: ds18_write
- 函數(shù)行參: date(向ds18b20寫(xiě)入的數(shù)據(jù))
- 功能: 功能向DS18B20中寫(xiě)入一個(gè)數(shù)據(jù)
- uint8 i;
- DS18B20=1;
- delay(1);
- for(i=0;i<8;i++) //根據(jù)時(shí)序?qū)?shù)據(jù)從低到高一位一位發(fā)送出來(lái)
- DS18B20 = 0;
- if(date&0x01) //從低到高取出數(shù)據(jù)的每位
- DS18B20 = 1;
- else
- DS18B20 = 0;
- delay(10);
- DS18B20 = 1;
- date>>=1;
- delay(1);
- 函數(shù)名: ds18_read
- 函數(shù)返回值:rate(從ds18b20中讀出的數(shù)據(jù))
- 功能: 功能從DS18B20中讀出一個(gè)數(shù)據(jù)并返回。
- uint8 ds18_read()
- uint8 i,date = 0;
- DS18B20 = 1; //釋放總線
- delay(1);
- for(i = 0;i < 8;i ++) //根據(jù)時(shí)序?qū)?shù)據(jù)從低到高一位一位接收
- DS18B20 = 0;
- date >>= 1;
- DS18B20 = 1;
- if(DS18B20)
- date |= 0x80; //將date的一位置1
- delay(8);
- DS18B20 = 1;
- delay(1);
- return date; //返回讀出的數(shù)
- 函數(shù)名: ds18_check
- 函數(shù)返回值: tmp(當(dāng)前溫度)
- 功能: 起動(dòng)DS18B20行進(jìn)溫度采集,并返回當(dāng)前溫度(tmp)
- void ds18_check()
- uint8 date1,date2;
- float ta;
- if(ds18_ini())
- ds18_write(0x44); // 啟動(dòng)溫度轉(zhuǎn)換
- ds18_ini(); // 復(fù)位
- ds18_write(0xbe); // 啟動(dòng)讀取溫度
- date1 = ds18_read(); //讀取兩個(gè)溫度字節(jié)
- date2 = ds18_read();
- tmp=date2;
- tmp<<=8;
- tmp=tmp|date1;
- ta=tmp*0.0625;
- tmp=ta*1000;
- void xianshi1()
- uint8 i;
- temp[8]=0x30+tmp/10000;
- temp[9]=0x30+tmp/1000%100;
- temp[11]=0x30+tmp/100%100;
- temp[12]=0x30+tmp/10%100;
- temp[13]=0x30+tmp%10;
- lcd_order(0x80+0x40);
- lcd_data(temp[i]);
這是網(wǎng)友的程序 求解 |
