發(fā)布時(shí)間: 2021-12-25 21:52
正文摘要:按照教學(xué)視頻編寫(xiě)的程序,輸入進(jìn)去不顯示,只藍(lán)屏,孩子弄一天了,到底怎么回事。 |
第一接線套路,二程序套路 |
多看幾遍12864的說(shuō)明書(shū)DATASHEET,將引腳功能、數(shù)據(jù)、控制 代碼記熟,先排除硬件問(wèn)題。再仔細(xì)校對(duì)控制時(shí)序。 static void lcd12864_write_command(uint8 cmd)/*寫(xiě)命令*/ { while(lcd12864_chek_busy()); LCD12864_RS = 0; LCD12864_RW = 0; LCD12864_EN = 0; delay1us(); LCD12864_DATA = cmd; delay50us(); LCD12864_EN = 1; delay50us(); LCD12864_EN = 0; return temp1; } // 描述: lcd12864寫(xiě)數(shù)據(jù) // 參數(shù): dat:寫(xiě)入的數(shù)據(jù). // 返回: none. //======================================================================== static void lcd12864_write_data(uint8 dat) { while(lcd12864_chek_busy()); LCD12864_RS = 1; LCD12864_RW = 0; LCD12864_EN = 0; LCD12864_DATA = dat; delay50us(); LCD12864_EN = 1; delay50us(); LCD12864_EN = 0; } //======================================================================== // 描述: lcd12864初始化 // 參數(shù): none. // 返回: none. //======================================================================== void lcd12864_init() { //引腳配置 LCD12864_RS_OUT; LCD12864_RW_OUT; LCD12864_E_OUT; LCD12864_RST_OUT; LCD12864_DATA_OUT; LCD12864_RST = 1; LCD12864_RST = 0; LCD12864_RST = 1; //復(fù)位RST=1 lcd12864_write_command(0x34); //34H--擴(kuò)充指令操作 delay5us(); lcd12864_write_command(0x30); //功能設(shè)置,一次送8位數(shù)據(jù),基本指令集 delay5us(); lcd12864_write_command(0x0C); //顯示狀態(tài)開(kāi)關(guān):整體顯示開(kāi),光標(biāo)顯示關(guān),光標(biāo)顯示反白關(guān) delay5us(); lcd12864_write_command(0x01); //清DDRAM delay5us(); lcd12864_write_command(0x02); //DDRAM地址歸位 delay5us(); lcd12864_write_command(0x80); //設(shè)定DDRAM 7位地址000,0000到地址計(jì)數(shù)器AC delay5us(); } //======================================================================== // 描述: lcd12864設(shè)定顯示位置 // 參數(shù): X,Y:坐標(biāo). // 返回: none. //======================================================================== void lcd12864_display_pos(uint8 X,uint8 Y) { uint8 pos; if (Y==0) {Y=0x80;} else if (Y==1) {Y=0x90;} else if (Y==2) {Y=0x88;} else if (Y==3) {Y=0x98;} pos = X+Y ; lcd12864_write_command(pos); //顯示地址 } //======================================================================== // 描述: lcd12864清屏 // 參數(shù): none. // 返回: none. //======================================================================== void lcd12864_clear() { lcd12864_write_command(0x30);// lcd12864_write_command(0x01);//清除顯示 delay(1); } //======================================================================== // 描述: lcd12864寫(xiě)單個(gè)字符 // 參數(shù): X,Y;坐標(biāo); sig:要顯示的字符. // 返回: none. //======================================================================== void lcd12864_show_char(uint8 X,uint8 Y,uint8 sig) { lcd12864_display_pos(X,Y); lcd12864_write_data(sig); //輸出單個(gè)字符 } //======================================================================== // 描述: lcd12864寫(xiě)字符串 // 參數(shù): X(0~3)行,Y(0~7)個(gè)字符; str:要顯示的字符串; // 返回: none. //======================================================================== void lcd12864_show_string(uint8 X,uint8 Y,uint8 *str) { uint8 i = 0; lcd12864_display_pos(X,Y); while(str[i] != '\0') { lcd12864_write_data(str[i]); i++; } } //======================================================================== // 描述: lcd12864寫(xiě)數(shù)字() // 參數(shù): X(0~3)行,Y(0~7)個(gè)字符; num:要顯示的數(shù)字; // 返回: none. //======================================================================== void lcd12864_show_num(uint8 x,uint8 y,int num) { char men[8]; char *str = men; sprintf(str,"%d",num); lcd12864_show_string(x,y,str); } //======================================================================== // 描述: lcd12864顯示圖像 // 參數(shù): p:要顯示的圖像. // 返回: none. //======================================================================== void lcd12864_show_image(uint8 *p) { int ygroup,x,y,i; int temp; int tmp; for(ygroup=0;ygroup<64;ygroup++) //寫(xiě)入液晶上半圖象部分 { //寫(xiě)入坐標(biāo) if(ygroup<32) { x=0x80; y=ygroup+0x80; }else { x=0x88; y=ygroup-32+0x80; } lcd12864_write_command(0x34); //寫(xiě)入擴(kuò)充指令命令 lcd12864_write_command(y); //寫(xiě)入y軸坐標(biāo) lcd12864_write_command(x); //寫(xiě)入x軸坐標(biāo) lcd12864_write_command(0x30); //寫(xiě)入基本指令命令 tmp=ygroup*16; for(i=0;i<16;i++) { temp=p[tmp++]; lcd12864_write_data(temp); } } lcd12864_write_command(0x34); //寫(xiě)入擴(kuò)充指令命令 lcd12864_write_command(0x36); //顯示圖象 } |
我退貨了,謝謝各位熱血的朋友,就不一一回復(fù)啦 |
這樣一般都是底層驅(qū)動(dòng)對(duì)不上 |
如果沒(méi)有老師實(shí)地指導(dǎo),建議買成品的試驗(yàn)套件,想省錢(qián)某魚(yú)就可以不用買全新。 套件一般都廠家有標(biāo)配的例程,先搞出花樣提高興趣并且先感覺(jué)一下,然后移置到自己DIY的板上。 如果有實(shí)地指導(dǎo)除外,否則不同器件的接線和編程都是不一樣的,對(duì)于你這種自制寶貝只能理論上點(diǎn)贊。 |
1.程序問(wèn)題——占大頭,所謂的教程程序一般都得修修改改才能用。 2.上面說(shuō)的對(duì)比度問(wèn)題 3.接線問(wèn)題 這些問(wèn)題都可以跟屏幕廠家溝通,都不是上面大問(wèn)題 至于屏幕損壞,只要是才買的這種幾率很小很小 |
應(yīng)該是對(duì)比度的問(wèn)題 |
middfat 發(fā)表于 2021-12-26 19:55 確實(shí)是,現(xiàn)在很難買到質(zhì)量好的杜邦線了。。。 |
我仿佛看到了曾經(jīng)的自己。首先,要在正常使用的開(kāi)發(fā)板上,用原廠點(diǎn)屏代碼測(cè)試,最好連引腳都不要?jiǎng),能成功點(diǎn)亮了再說(shuō)。然后,自己焊接的實(shí)驗(yàn)板,先實(shí)現(xiàn)正常的下載點(diǎn)燈都沒(méi)問(wèn)題了,再考慮修改移植代碼。這樣用杜邦線連接模塊最好只用于驗(yàn)證,實(shí)際使用最好是畫(huà)圖打板,反正現(xiàn)在打板也是免費(fèi),順便練習(xí)畫(huà)圖技能。現(xiàn)在萬(wàn)能寶上面的杜邦線質(zhì)量普遍不怎么樣,我已經(jīng)被坑過(guò)好幾次了,所以,有條件最好自己制作杜邦線,或者直接焊接。 |
有一個(gè)小經(jīng)驗(yàn):之前我玩這個(gè)12864的時(shí)候也是用的接線的方式,故障也是差不多:有背光,就是不顯示。 后來(lái)搞了很久,才發(fā)現(xiàn)是一根接線質(zhì)量差,是中間斷的。走了好多彎路才糾正過(guò)來(lái) ![]() |
Qiuhan 發(fā)表于 2021-12-26 16:59 一般都是用的LCD12864背部的可調(diào)電阻 如果想用第三個(gè)焊點(diǎn)VO來(lái)外接可調(diào)電阻的話需要把背部的通路斷掉 |
12864的第三個(gè)焊點(diǎn)旁邊有一個(gè)焊點(diǎn) 看看有沒(méi)有焊上 加一個(gè)調(diào)節(jié)屏幕的電阻試試 10K的可調(diào)電阻 |
比如,你貼出來(lái)的甚至連接線都看不清楚誰(shuí)跟誰(shuí)。起碼的液晶屏的型號(hào),與MCU連線,以及程序全部貼好,然后大家再根據(jù)具體情況幫助你判斷問(wèn)題的所在。這樣會(huì)更好些,不讓你讓大家浪費(fèi)時(shí)間在這猜想,這樣根本猜不出個(gè)所以然,因?yàn)閱?wèn)題太多了。 畢竟像貼圖這種情況只需要連接背光的AK兩個(gè)引腳即可。 |
這個(gè)如果不是某某開(kāi)發(fā)板的套件加配套程序的話很難說(shuō)明到底哪里除了問(wèn)題,12864問(wèn)題不比1602,要復(fù)雜的多,比如同一廠家的LCD12864只是后綴不同都需要不同的接線以及驅(qū)動(dòng)程序,而且不同的主控芯片需要不同的初始化程序。把問(wèn)題敘述的更清楚些也許更容易讓大家?guī)椭憬鉀Q問(wèn)題。 |
單片機(jī)+ lcd12864 只藍(lán)屏 要檢查: 1.硬件接線對(duì)嗎?(包括單片機(jī)有無(wú)正常工作 .. lcd12864接線有無(wú)問(wèn)題,程式中使用管腳與接線是否相符) 2.編寫(xiě)的程序適合這個(gè)LCD對(duì)嗎?(LCD 12864不只一總型號(hào)..不同的型號(hào)驅(qū)動(dòng)程是有差別) 3.編寫(xiě)的程序?qū)? 4.lcd 12864對(duì)比調(diào)整適當(dāng) 5.lcd損壞 .....(這種情形相當(dāng)少見(jiàn)) 只要不是lcd損壞 ...完成1 至 4 項(xiàng) 一定會(huì)顯示 |
