74HC595輸出接按鍵,單片機(jī)怎么讀取鍵碼?
查看數(shù): 2402 | 評論數(shù): 7 | 收藏 0
發(fā)布時(shí)間: 2022-12-14 23:24
ID:961242 發(fā)表于 2022-12-26 16:56
wulin 發(fā)表于 2022-12-15 09:24
仿真沒有什么問題,實(shí)際運(yùn)用要考慮按鍵消抖問題。
有沒有STM32的案例程序?
ID:1034262 發(fā)表于 2022-12-15 12:21
595會(huì)輪流輸出高或低,沒掃描一個(gè),就讀一次KEY即可。
ID:213173 發(fā)表于 2022-12-15 09:24
  1. #include <reg51.H>
  2. #define uint unsigned int
  4. sbit P_HC595_SER   = P2^0;
  5. sbit P_HC595_SRCLK = P2^1;
  6. sbit P_HC595_RCLK  = P2^2;
  7. sbit KEY=P2^3;
  8. unsigned char code table[]={0x70,0x79,0xee};//KEY.
  9. unsigned char code display[]={//0~f-.
  10.         0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
  11.         0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x40,0x80};
  12. unsigned char code wela[]={
  13.         0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
  14. /**************** 向HC595發(fā)送一個(gè)字節(jié)函數(shù) ******************/
  15. void Send_595(uchar dat)
  16. {
  17.         uchar i;
  18.         for(i=0;i<8;i++)
  19.         {
  20.                 dat <<= 1;
  21.                 P_HC595_SER  = CY; //溢出位賦值數(shù)據(jù)輸出端
  22.                 P_HC595_SRCLK = 1; //移位時(shí)鐘
  23.                 P_HC595_SRCLK = 0;
  24.         }
  25. }
  26. /**************** 向HC595發(fā)送2個(gè)字節(jié)驅(qū)動(dòng)碼 ******************/
  27. void DisplayScan()
  28. {
  29.         static uchar i,j;
  30.         Send_595(wela[i]);//向HC595發(fā)送位碼
  31. /**********根據(jù)位碼識別按鍵********/
  32.         if(!KEY)
  33.         {
  34.                 switch(i)
  35.                 {
  36.                         case 0: j= 4; break;
  37.                         case 1: j= 1; break;
  38.                         case 2: j= 2; break;
  39.                         case 3: j= 3; break;
  40.                 }
  41.         }
  42. /******************************/
  43.         if(i==3)
  44.                 Send_595(display[j]);//向HC595發(fā)送段碼顯示鍵值
  45.         else
  46.                 Send_595(table[i]);  //向HC595發(fā)送段碼顯示KEY.
  47.         P_HC595_RCLK = 1;       //鎖存輸出數(shù)據(jù)
  48.         P_HC595_RCLK = 0;
  49.         i++;
  50.         i%=4;
  51. }
  52. void main()
  53. {
  54.         P_HC595_SRCLK = 0;//初始化移位時(shí)鐘端
  55.         P_HC595_RCLK  = 0;//初始化鎖存輸出端
  56.         while(1)
  57.         {
  58.                 DisplayScan();
  59.         }
  60. }
ID:161164 發(fā)表于 2022-12-15 09:01
若用共陰數(shù)碼管,KEY引腳要設(shè)為上拉
當(dāng)KEY收到下降沿信號時(shí)
位輸出595的數(shù)值(0xFE,0xFD,0xFB,0xF7)就是鍵值
若用共陽數(shù)碼管,KEY引腳要設(shè)為下拉
當(dāng)KEY收到上升沿信號時(shí)
位輸出595的數(shù)值(0x01,0x02,0x04,0x08)就是鍵值
ID:69038 發(fā)表于 2022-12-15 08:52
595在這電路中和按鍵沒有0.5元錢的關(guān)系,595在這邊只是個(gè)擴(kuò)口器件而已!!
ID:94031 發(fā)表于 2022-12-15 07:00
按下按鍵時(shí)讀KEY點(diǎn)值,看和Q0-Q3那一路同步就知道是那個(gè)鍵按下。
ID:213173 發(fā)表于 2022-12-15 05:59
74HC595是串入并出的單向器件,不具有做輸入的功能,輸出一般是不能簡單接按鍵的,需要軟件配合。圖示的運(yùn)用也不是通過595讀取鍵值,而是利用595輸出的數(shù)碼管有規(guī)律的位碼驅(qū)動(dòng)電平,經(jīng)KEY端返回單片機(jī)識別鍵值,以達(dá)到節(jié)省IO口的目的。雙向器件可以了解下74HC165。
