Proteus仿真51單片機(jī)驅(qū)動(dòng)DHT11并用12864顯示 液晶顯示屏無(wú)現(xiàn)象,同時(shí)引腳不閃爍
查看數(shù): 1661 | 評(píng)論數(shù): 1 | 收藏 1
發(fā)布時(shí)間: 2023-2-9 17:23
液晶顯示屏無(wú)現(xiàn)象,同時(shí)引腳不閃爍,沒有數(shù)據(jù)被輸入 12864在其他代碼中可正常運(yùn)行 單片機(jī)代碼如下,已經(jīng)改了兩天了真的不知道是哪里的問題了 #include <REG51.H> #include <Intrins.h> #define pin ...
ID:155507 發(fā)表于 2023-3-7 20:21
給你改了,對(duì)比一下就知道哪里錯(cuò)了。
  1. #include <reg51.h>
  2. #include <stdio.h>
  3. #include <Intrins.h>
  4. #define pin P0
  5. sbit RS=P2^2;
  6. sbit RW=P2^3;
  7. sbit E=P2^4;
  8. sbit CS1 = P2^0;
  9. sbit CS2 = P2^1;
  10. sbit dat = P2^7;
  11. unsigned char arr[8]={0,0,0,0,0,0,0,0};
  12. unsigned char code ch1[]=
  13. {
  14. /*--  文字:  0  --*/
  15. /*--  宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=8x16   --*/
  16. 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,
  17. /*--  文字:  1  --*/
  18. /*--  宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=8x16   --*/
  19. 0x00,0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,
  20. /*--  文字:  2  --*/
  21. /*--  宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=8x16   --*/
  22. 0x00,0x70,0x08,0x08,0x08,0x08,0xF0,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,
  23. /*--  文字:  3  --*/
  24. /*--  宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=8x16   --*/
  25. 0x00,0x30,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x18,0x20,0x21,0x21,0x22,0x1C,0x00,
  26. /*--  文字:  4  --*/
  27. /*--  宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=8x16   --*/
  28. 0x00,0x00,0x80,0x40,0x30,0xF8,0x00,0x00,0x00,0x06,0x05,0x24,0x24,0x3F,0x24,0x24,
  29. /*--  文字:  5  --*/
  30. /*--  宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=8x16   --*/
  31. 0x00,0xF8,0x88,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x20,0x20,0x20,0x11,0x0E,0x00,
  32. /*--  文字:  6  --*/
  33. /*--  宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=8x16   --*/
  34. 0x00,0xE0,0x10,0x88,0x88,0x90,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x20,0x1F,0x00,
  35. /*--  文字:  7  --*/
  36. /*--  宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=8x16   --*/
  37. 0x00,0x18,0x08,0x08,0x88,0x68,0x18,0x00,0x00,0x00,0x00,0x3E,0x01,0x00,0x00,0x00,
  38. /*--  文字:  8  --*/
  39. /*--  宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=8x16   --*/
  40. 0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,
  41. /*--  文字:  9  --*/
  42. /*--  宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=8x16   --*/
  43. 0x00,0xF0,0x08,0x08,0x08,0x10,0xE0,0x00,0x00,0x01,0x12,0x22,0x22,0x11,0x0F,0x00,
  44. /*--  文字:  .  --*/
  45. /*--  宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=8x16   --*/
  46. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,
  47.         /*--  文字:  溫  --*/
  48. /*--  宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
  49. 0x10,0x60,0x02,0x8C,0x00,0x00,0xFE,0x92,0x92,0x92,0x92,0x92,0xFE,0x00,0x00,0x00,
  50. 0x04,0x04,0x7E,0x01,0x40,0x7E,0x42,0x42,0x7E,0x42,0x7E,0x42,0x42,0x7E,0x40,0x00,
  51. /*--  文字:  度  --*/
  52. /*--  宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
  53. 0x00,0x00,0xFC,0x24,0x24,0x24,0xFC,0x25,0x26,0x24,0xFC,0x24,0x24,0x24,0x04,0x00,
  54. 0x40,0x30,0x8F,0x80,0x84,0x4C,0x55,0x25,0x25,0x25,0x55,0x4C,0x80,0x80,0x80,0x00,
  55. /*--  文字:  濕  --*/
  56. /*--  宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
  57. 0x10,0x60,0x02,0x8C,0x00,0xFE,0x92,0x92,0x92,0x92,0x92,0x92,0xFE,0x00,0x00,0x00,
  58. 0x04,0x04,0x7E,0x01,0x44,0x48,0x50,0x7F,0x40,0x40,0x7F,0x50,0x48,0x44,0x40,0x00,
  59. /*--  文字:  度  --*/
  60. /*--  宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
  61. 0x00,0x00,0xFC,0x24,0x24,0x24,0xFC,0x25,0x26,0x24,0xFC,0x24,0x24,0x24,0x04,0x00,
  62. 0x40,0x30,0x8F,0x80,0x84,0x4C,0x55,0x25,0x25,0x25,0x55,0x4C,0x80,0x80,0x80,0x00,
  63. /*--  文字:  :  --*/
  64. /*--  宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
  65. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  66. 0x00,0x00,0x36,0x36,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  67. };
  68. void wr_command(unsigned char wrcommand) //寫指令
  69. {
  70.          RS=0;
  71.          RW=0;
  72.          E=1;
  73.          pin=wrcommand;
  74.          E=0;
  75. }
  76. void wr_data(unsigned char wrdata)  //寫數(shù)據(jù)
  77. {
  78.          RS=1;
  79.          RW=0;
  80.          E=1;
  81.          pin=wrdata;
  82.          E=0;
  83. }
  84. void set_page(unsigned char page)//起始頁(yè)
  85. {
  86.         page = 0xB8 | page;
  87.         wr_command(page);
  88. }
  89. void set_line(unsigned char line)//起始行
  90. {
  91.         line = 0xC0 | line;
  92.         wr_command(line);
  93. }
  94. void set_column(unsigned char column)//起始列
  95. {
  96.         column = column | 0x40;
  97.         wr_command(column);
  98. }
  99. void chose_screen(unsigned char screen)        //選擇屏幕
  100. {
  101.         switch(screen)
  102.         {
  103.                 case 0:CS1 = 0;CS2 = 0;break;//全
  104.                 case 1:CS1 = 0;CS2 = 1;break;//左
  105.                 case 2:CS1 = 1;CS2 = 0;break;//右
  106.                 default:break;
  107.         }
  108. }
  109. void clear_screen(unsigned char screen) //清屏
  110. {
  111.         unsigned char i,j;
  112.         chose_screen(screen);
  113.         for(i=0;i<8;i++)
  114.         {
  115.                 set_page(i);
  116.                 set_column(0);
  117.                 for(j=0;j<64;j++)
  118.                 {
  119.                         wr_data(0x00);
  120.                 }
  121.         }
  122. }
  123. void LCD_init()
  124. {
  125.        REST=0;
  126.        REST=1;
  127.         chose_screen(0);
  128.         clear_screen(0);
  129. }
  130. void show_ch(unsigned char screen,unsigned char page,unsigned char column,unsigned char *p)//顯示字符
  131. {
  132.         unsigned char i;
  133.         chose_screen(screen);
  134.         set_page(page);
  135.         set_column(column);
  136.         for(i=0;i<8;i++)
  137.         {
  138.                 wr_data(p[i]); //[/i][i]
  139.         }
  140.         set_page(page+1);
  141.         set_column(column);
  142.         for(i=0;i<8;i++)
  143.         {
  144.                 wr_data(p[i+8]);
  145.         }
  146. }
  147. void show_ch1(unsigned char screen,unsigned char page,unsigned char column,unsigned char *p)//顯示漢字
  148. {
  149.         unsigned char i;
  150.         chose_screen(screen);
  151.         set_page(page);
  152.         set_column(column);
  153.         for(i=0;i<16;i++)
  154.         {
  155.                 wr_data(p[i]);  //[/i][i]
  156.         }
  157.         set_page(page+1);
  158.         set_column(column);
  159.         for(i=0;i<16;i++)
  160.         {
  161.                 wr_data(p[i+16]);
  162.         }
  163. }
  164. void delayus(unsigned char i){
  165.
  166.     while(i--);
  167.
  168. }
  169. void delayms(unsigned char x)
  170. {
  171.     unsigned char i, j;
  172.     while(--x){
  173.         _nop_();
  174.         i = 2;
  175.         j = 199;
  176.         do
  177.         {
  178.             while (--j);
  179.         } while (--i);
  180.     }
  181. }
  182. void Delay30us()                //@11.0592MHz
  183. {
  184.         unsigned char i;
  185.         i = 11;
  186.         while (--i);
  187. }
  188. void dht11_init(){
  189.     //while(1){   //<--------?????? 這里不可以用
  190.     unsigned char high = 0,low = 1;
  191.     dat = 1;
  192.     dat = 0;
  193.     delayms(20);
  194.     dat = 1;
  195.     delayus(6);
  196.     while(!dat);
  197.     while(dat);
  198.   //}
  199. }
  200. //讀數(shù)據(jù)的邏輯也不太對(duì),應(yīng)改為
  201. unsigned char read_byte(){
  202.     unsigned char byte=0, i;
  203.     for(i=0;i<8;i++){
  204.             while(!dat);
  205.             Delay30us();
  206.             byte<<=1;   //<-------------
  207.             if(dat == 1){
  208.                 byte = byte | 0x01;
  209.                 while(dat);
  210.             }
  211.   }
  212.         return byte;
  213. }
  214. unsigned char ste0,ste1,ste2,ste3;
  215. void dht11_receive(){
  216.     unsigned char byte1,byte2,byte3,byte4,byte5;
  217.     dht11_init();
  218.     byte1 = read_byte();
  219.     byte2 = read_byte();
  220.     byte3 = read_byte();
  221.     byte4 = read_byte();
  222.     byte5 = read_byte();
  223.     dat = 0;
  224.     delayus(7);
  225.     dat = 1;
  226.     if((byte1+byte2+byte3+byte4) == byte5){
  227.         ste0 = byte1;
  228.         ste1 = byte2;
  229.         ste2 = byte3;
  230.         ste3 = byte4;
  231.     }
  232. }
  233. void dht11_show(){
  234.     dht11_receive();
  235.     arr[0] = ste0 / 10;//濕度
  236.     arr[1] = ste0 % 10;
  237.     arr[2] = ste1 / 10;
  238.     arr[3] = ste1 % 10;
  239.     arr[4] = ste2 / 10;//溫度
  240.     arr[5] = ste2 % 10;
  241.     arr[6] = ste3 / 10;
  242.     show_ch(1,0,0*16,ch1+16*arr[0]);
  243.     show_ch(1,0,1*16,ch1+16*arr[1]);
  244.     //show_ch(1,0,2*16,ch1+16*arr[2]);
  245.     //show_ch(1,0,3*16,ch1+16*arr[3]);
  246.     show_ch(2,32,0*16,ch1+16*arr[4]);
  247.     show_ch(2,32,1*16,ch1+16*arr[5]);
  248.     //show_ch(2,32,2*16,ch1+16*arr[6]);
  249. }
  250. void main(){
  251.         char i;
  252.         LCD_init();
  253.         delayms(1000);
  254.         while(1){
  255.                 delayms(100);
  256.                 //dht11_receive();
  257.                 dht11_show();
  258.         }
  259. }
