有人會(huì)五電平的代碼?單相五電平正弦脈寬調(diào)制波產(chǎn)生
查看數(shù): 2384 | 評(píng)論數(shù): 8 | 收藏 2
發(fā)布時(shí)間: 2023-5-29 16:49
有人會(huì)用32或者的水平28335寫??
ID:1073043 發(fā)表于 2023-6-8 23:44
書到用時(shí)發(fā)現(xiàn)學(xué)的太少了,虛心求解
ID:1079046 發(fā)表于 2023-5-30 14:02
angmall 發(fā)表于 2023-5-30 10:03
以下是使用STM32單片機(jī)(例如STM32F4系列)編寫的五電平代碼示例:
#include "stm32f4xx.h"
優(yōu)秀 連dsp的示例都有
ID:155507 發(fā)表于 2023-5-30 11:42
chen_天天來 發(fā)表于 2023-5-30 10:15
什么是5電平?看著怎么像是LCD驅(qū)動(dòng)的偏壓波形1/3vcc,1/5vcc
一種基于嵌入式目標(biāo)代碼生成工具的中性點(diǎn)箝位(NPC)單相五電平正弦脈寬調(diào)制波產(chǎn)生方法
5電平級(jí)聯(lián)H橋多電平逆變器
ID:1006076 發(fā)表于 2023-5-30 10:15
ID:155507 發(fā)表于 2023-5-30 10:03
// 定義GPIO引腳
#define PWM_PIN_A GPIO_Pin_9
#define PWM_PIN_B GPIO_Pin_10
#define PWM_PIN_C GPIO_Pin_11
#define PWM_PORT GPIOA
// 定義PWM參數(shù)
#define PWM_PERIOD 1000
#define PWM_DUTY_CYCLE_1 200
#define PWM_DUTY_CYCLE_2 400
#define PWM_DUTY_CYCLE_3 600
#define PWM_DUTY_CYCLE_4 800
// 初始化PWM
void PWM_Init(void)
    GPIO_InitTypeDef GPIO_InitStruct;
    TIM_TimeBaseInitTypeDef TIM_InitStruct;
    TIM_OCInitTypeDef TIM_OC_InitStruct;
    // 使能GPIO時(shí)鐘
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
    // 配置GPIO引腳為復(fù)用功能
    GPIO_InitStruct.GPIO_Pin = PWM_PIN_A | PWM_PIN_B | PWM_PIN_C;
    GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
    GPIO_Init(PWM_PORT, &GPIO_InitStruct);
    // 配置GPIO引腳的復(fù)用功能
    GPIO_PinAFConfig(PWM_PORT, GPIO_PinSource9, GPIO_AF_TIM1);
    GPIO_PinAFConfig(PWM_PORT, GPIO_PinSource10, GPIO_AF_TIM1);
    GPIO_PinAFConfig(PWM_PORT, GPIO_PinSource11, GPIO_AF_TIM1);
    // 使能TIM1時(shí)鐘
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
    // 配置TIM1基本參數(shù)
    TIM_InitStruct.TIM_Period = PWM_PERIOD - 1;
    TIM_InitStruct.TIM_Prescaler = 0;
    TIM_InitStruct.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_InitStruct.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_InitStruct.TIM_RepetitionCounter = 0;
    TIM_TimeBaseInit(TIM1, &TIM_InitStruct);
    // 配置TIM1通道1為PWM模式
    TIM_OC_InitStruct.TIM_OCMode = TIM_OCMode_PWM1;
    TIM_OC_InitStruct.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OC_InitStruct.TIM_OCPolarity = TIM_OCPolarity_High;
    TIM_OC_InitStruct.TIM_Pulse = PWM_DUTY_CYCLE_1 - 1;
    TIM_OC1Init(TIM1, &TIM_OC_InitStruct);
    // 配置TIM1通道2為PWM模式
    TIM_OC_InitStruct.TIM_Pulse = PWM_DUTY_CYCLE_2 - 1;
    TIM_OC2Init(TIM1, &TIM_OC_InitStruct);
    // 配置TIM1通道3為PWM模式
    TIM_OC_InitStruct.TIM_Pulse = PWM_DUTY_CYCLE_3 - 1;
    TIM_OC3Init(TIM1, &TIM_OC_InitStruct);
    // 啟動(dòng)TIM1
    TIM_Cmd(TIM1, ENABLE);
int main(void)
    // 初始化PWM
    PWM_Init();
    while (1)
        // 在此處添加其他代碼或邏輯
這個(gè)示例代碼演示了如何使用STM32單片機(jī)(例如STM32F4系列)編寫五電平PWM控制代碼。你可以根據(jù)具體需求修改PWM參數(shù)和添加其他邏輯代碼。請(qǐng)根據(jù)實(shí)際情況進(jìn)行適當(dāng)?shù)呐渲煤托薷摹?br />
以下是使用TMS320F28335(基于C2000系列)編寫的五電平代碼示例:
#include "DSP2833x_Device.h"
// 定義PWM參數(shù)
void InitEPwm1Gpio(void)
    EALLOW;
    GpioCtrlRegs.GPAMUX1.bit.GPIO0 = 1;
    GpioCtrlRegs.GPAMUX1.bit.GPIO1 = 1;
    GpioCtrlRegs.GPAMUX1.bit.GPIO2 = 1;
    EDIS;
void InitEPwm1Module(void)
    EPwm1Regs.TBPRD = PWM_PERIOD;         // 設(shè)置周期
    EPwm1Regs.TBPHS.half.TBPHS = 0x0000;  // 不使用相位補(bǔ)償
    EPwm1Regs.TBCTR = 0x0000;             // 清除計(jì)數(shù)器
    EPwm1Regs.CMPA.half.CMPA = PWM_DUTY_CYCLE_1;  // 設(shè)置占空比
    // 配置事件生成
    EPwm1Regs.ETSEL.bit.SOCAEN = 1;       // 使能SOCA
    EPwm1Regs.ETSEL.bit.SOCASEL = 1;      // 當(dāng)計(jì)數(shù)器達(dá)到零時(shí)生成SOCA事件
    EPwm1Regs.ETPS.bit.SOCAPRD = 1;       // SOCA事件產(chǎn)生時(shí),每個(gè)周期產(chǎn)生一個(gè)事件
    EPwm1Regs.TBCTL.bit.CTRMODE = 0;      // 上升計(jì)數(shù)模式
    EPwm1Regs.TBCTL.bit.PHSEN = 0;        // 不使用相位補(bǔ)償
    EPwm1Regs.TBCTL.bit.HSPCLKDIV = 0;    // 不分頻
    EPwm1Regs.TBCTL.bit.CLKDIV = 0;       // 不分頻
    // 啟動(dòng)PWM模塊
    EPwm1Regs.TBCTL.bit.FREE_SOFT = 2;    // 配置FREE/SOFT位,允許PWM停止計(jì)數(shù)器和同步
    EPwm1Regs.TBCTL.bit.SWFSYNC = 1;      // 同步PWM計(jì)數(shù)器
    EPwm1Regs.TBCTL.bit.PRDLD = 0;        // 立即加載周期寄存器
    EPwm1Regs.TBCTL.bit.PHSDIR = 0;       // 相位補(bǔ)償方向:減小
void main(void)
    // 初始化系統(tǒng)控制
    InitSysCtrl();
    // 初始化GPIO
    InitEPwm1Gpio();
    // 初始化PWM模塊
    InitEPwm1Module();
    // 允許中斷
    EINT;
    // 啟動(dòng)PWM模塊
    CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 1;
    // 主循環(huán)
    while (1)
        // 在此處添加其他代碼或邏輯
這個(gè)示例代碼演示了如何使用TMS320F28335(基于C2000系列)編寫五電平PWM控制代碼。你可以根據(jù)具體需求修改PWM參數(shù)和添加其他邏輯代碼。請(qǐng)根據(jù)實(shí)際情況進(jìn)行適當(dāng)?shù)呐渲煤托薷摹?br />
ID:712097 發(fā)表于 2023-5-30 09:40
活到老,學(xué)到老。坐等大神答疑解惑。
ID:123289 發(fā)表于 2023-5-30 09:11
看上去高深的樣子。
ID:996773 發(fā)表于 2023-5-30 08:54
遇到這樣的問題,我意識(shí)到自己還是個(gè)小白,留個(gè)腳印,等大師出現(xiàn)看看這是啥東東
