Proteus 里沒有ads1115模型但有一個ads1015.區(qū)別就是前者為16比特,后者為12比特![]() $regfile = "m16def.dat" ' specify the used micro $crystal = 8000000 ' used crystal frequency '$baud = 19200 ' use baud rate $hwstack = 32 ' default use 32 for the hardware stack $swstack = 32 ' default use 10 for the SW stack $framesize = 64 ' default use 40 for the frame space Declare Function Get_adc(byval Ain_x As Byte) As Integer Config Lcdpin = Pin , Db4 = Portd.4 , Db5 = Portd.5 , Db6 = Portd.6 , Db7 = Portd.7 , Rs = Portb.0 , E = Portb.1 Config Lcd = 16 * 2 '配置液晶屏 Cursor Off Noblink Dim Myinteger As Integer Dim Voltage As Single Dim Vol_str As String * 8 '采樣接口引腳配置 Dim Channel(8) As Byte 'AIN0-AIN1 'AIN0-AIN3 'AIN1-AIN3 'AIN2-AIN3 Channel(5) = &B00000000 : Channel(6) = &B00010000 : Channel(7) = &B00100000 : Channel(8) = &B00110000 'AIN0-GND 'AIN1-GND 'AIN2-GND 'AIN3-GND Channel(1) = &B01000000 : Channel(2) = &B01010000 : Channel(3) = &B01100000 : Channel(4) = &B01110000 '配置引腳以用于I2C總線 Config Scl = PortC.0 '是串行時鐘SCL Config Sda = PortC.1 '是串行數(shù)據(jù)SDA I2cinit '************************************************************************************* Cls Do Myinteger = Get_adc(2) 'Cls Locate 1 , 1 Lcd Hex(myinteger) Voltage = Myinteger / 32768 Voltage = Voltage * 4096 Myinteger = Round(voltage) Vol_str = Str(myinteger) Vol_str = Format(vol_str , "0.000") Locate 2 , 1 Lcd Vol_str Waitms 600 Loop End '************************************************************************************* Function Get_adc(byval Ain_x As Byte) As Integer Local Config_high As Byte Local Config_low As Byte 'addr_pin接地 '寫入ads1115的地址 'W_addr = &H90 '從ads1115讀取的地址 'R_addr = &H91 Config_high = &B10000000 Config_high = Config_high + Channel(2) Config_high = Config_high + &B00000010 ' Pga(2) ±4.096V 'Config_high = Config_high + &B00000100 ' Pga(3) ±2.048V Config_low = &B10000000 ' 128SPS '初始化I2C I2cstart I2cwbyte &H90 ' W_地址 I2cwbyte &B00000001 ' 指向Config寄存器 I2cwbyte Config_high I2cwbyte Config_low I2cstop '讀_ad I2cstart ' 生成起始碼 I2cwbyte &H90 ' W_addr發(fā)送地址 I2cwbyte &B00000000 ' 指向轉(zhuǎn)換寄存器 I2cstart ' 起動條件 I2cwbyte &H91 ' 讀_addr的從機地址 I2crbyte Config_high , Ack I2crbyte Config_low , Nack I2cstop Get_adc = Makeint(config_low , Config_high) '將兩個字節(jié)壓縮成一個字或整數(shù)。等效代碼是:VARN=(256*MSB)+LSB End Function |
你好,我能請教你一些問題嗎?我參照了您的那個帖子ADS1110的,但是我使用的是mega16,但是讀取不出來數(shù)據(jù),想請教一下您 |
你不妨用ADS1015代替ADS1115在Proteus 仿真調(diào)試驗證一下。 |
