altium designer 原理圖復(fù)制出錯問題 InvalidParameter at AdvSch.dll, Base Addre...
查看數(shù): 62971 | 評論數(shù): 26 | 收藏 2
發(fā)布時間: 2014-12-25 01:10
InvalidParameter at 2510219C. AdvSch.dll, Base Address: 24C80000. Exception Occurred In Copy 使用AD14在復(fù)制的時候偶爾會出現(xiàn)這樣的一個問題 然后會出先復(fù)制出錯的情況,也有人說這是破解版的一 ...
ID:247810 發(fā)表于 2019-7-17 21:55
謝謝 分享
ID:475783 發(fā)表于 2019-7-7 10:36
牛人,這都可以
ID:529775 發(fā)表于 2019-7-7 10:27
感謝,復(fù)制沒問題了
ID:575820 發(fā)表于 2019-7-1 17:05
ming759053364 發(fā)表于 2015-6-19 20:44
**** 作者被禁止或刪除 內(nèi)容自動屏蔽 ****
牛逼啊兄嘚
ID:34556 發(fā)表于 2019-3-13 10:06
非常給力
ID:339180 發(fā)表于 2019-2-26 13:49
大神,解決了,謝謝
ID:382973 發(fā)表于 2018-11-13 11:19
liuyufengdq 發(fā)表于 2015-4-16 11:03
牛逼  贊贊啊
ID:389771 發(fā)表于 2018-8-24 20:33
萬分感謝,已解決
ID:198323 發(fā)表于 2018-6-27 09:06
我安裝了 怎么不行,是還需要其他操作嗎
ID:169623 發(fā)表于 2017-3-10 13:55
感謝大神  弄好了
ID:143559 發(fā)表于 2017-1-19 10:17
O(∩_∩)O謝謝
ID:152226 發(fā)表于 2016-12-5 10:09
我也 要
ID:150909 發(fā)表于 2016-11-29 09:20
我也遇到過
ID:149871 發(fā)表于 2016-11-24 09:18
謝謝啊  好人一生平安
ID:123002 發(fā)表于 2016-5-24 22:47
謝謝分享。
ID:113663 發(fā)表于 2016-4-12 10:04
太感謝樓主了,現(xiàn)在好啦
ID:87879 發(fā)表于 2015-8-7 20:04
為什么會出現(xiàn)這種問題呢?是不是清理軟件搞的鬼
ID:87339 發(fā)表于 2015-7-31 13:34
我也出現(xiàn)了這個問題,我先試試上面的方法
ID:85199 發(fā)表于 2015-7-9 15:02
下載一個虛擬打印機,給個網(wǎng)址可以下載http://www.cr173.com/soft/32263.html
牛人,照你的方法下了打印機安裝上就好了
ID:85181 發(fā)表于 2015-7-9 11:32
I had this issue with AD13 and AD14 after reinstalling and in SAFE MODE just in case it was some other program interfering. Well it turn out that this issue was related to the spooler service being turned off. I have a habit of turning off features on my computer that i do not use, and since i dont have a printer attached to my machine... i stoped the spooler service. So make sure that it is running first before you run altium.
go to start -> run -> type "cmd"
in the command prompt window type:
net start spooler
You should see this:
The Print Spooler service is starting.
The Print Spooler service was started successfully.
Re-open Altium and you should be good.
Why in the world AD needs the spooler service turned on to do a simple copy paste operation is beyond me.
ID:83463 發(fā)表于 2015-6-19 20:44
參與人數(shù) 1黑幣 +5 收起 理由
tangquan + 5 很給力!
ID:77133 發(fā)表于 2015-4-16 11:03
剛剛解決這個問題:
先看看能不能添加本地打印機,要是無法添加打印機,在桌面選中“我的電腦”,鼠標(biāo)右鍵選擇“管理”;
在“管理”窗口中,選取“服務(wù)和應(yīng)用程序”擴展項目下的“服務(wù)”選項,在右側(cè)出現(xiàn)系統(tǒng)服務(wù)列表中找到“Print Spooler”服務(wù),雙擊進入“Print Spooler”服務(wù)設(shè)置;
在“Print Spooler”服務(wù)設(shè)置窗口中,將“啟動類型”設(shè)置為“自動”,點擊“啟動”按鈕;
此時系統(tǒng)會嘗試啟動該服務(wù);
當(dāng)服務(wù)啟動成功后,“服務(wù)狀態(tài)”會顯示為“已啟動”,重新進行添加或是使用打印機的其它操作。
如果復(fù)制還出錯:
添加本地打印機:開始》》設(shè)備和打印機》》添加打印機》》創(chuàng)建新端口》》下一步》》輸入test》》廠商選Microsoft,打印機選Microsoft XPS Document Writer
        轉(zhuǎn)載來自百度altuim吧   慶州123
ID:76631 發(fā)表于 2015-4-10 22:15
我也出現(xiàn)這樣的問題,怎么解決?
ID:75918 發(fā)表于 2015-4-1 21:25
這個問題難道就無解了嗎
ID:74817 發(fā)表于 2015-3-18 22:59
出現(xiàn)上述怎樣解決
ID:73167 發(fā)表于 2015-2-2 20:45
同問
