初學(xué)者,一個(gè)簡(jiǎn)單的51數(shù)碼管顯示仿真
查看數(shù): 2909 | 評(píng)論數(shù): 1 | 收藏 2
發(fā)布時(shí)間: 2016-12-5 16:03
Protues仿真的51單片機(jī)控制8個(gè)數(shù)碼管進(jìn)行顯示
ID:1 發(fā)表于 2016-12-5 16:08
樓主的源碼:
  1. #include<reg51.h>
  2. #include<intrins.h>
  3. #define uint unsigned int
  4. #define uchar unsigned char
  5. sbit DTData=P2^6;
  6. sbit DTCtrl=P2^7;
  7. //共陰管8根數(shù)據(jù)線,8個(gè)管
  8. //高電平控制管子的選擇,低電平控制亮滅
  9. uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
  10. 0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,
  11. 0x40};
  12. uchar code position[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f,0xff};
  13. void delayms(uint xms)
  14. {
  15.         uint i,j;
  16.         for(i=xms;i>0;i--)
  17.                 for(j=110;j>0;j--)
  18.                 {;}
  19. }
  20. void dtshow(uchar digit,uchar dat)
  21. {
  22.         uchar dat1=dat;
  23.         P0=0;
  24.         P0=position[digit];
  25.         DTCtrl=1;
  26.         DTCtrl=0;
  27.         P0=0x0;
  28.         P0=table[dat1];
  29.         DTData=1;
  30.         DTData=0;
  31.         DTData=0;
  32.         delayms(1);
  33. }
  34. void dtshowstring(uchar datstring[])
  35. {
  36.         uchar k=8;
  37.         uchar temp;
  38.         for(k=0;k<8;k++)
  39.         {
  40.                 temp=datstring[k];
  41.                 dtshow(k,temp);
  42.                 delayms(1);
  43.         }
  44. }
  45. void main()
  46. {
  47.         uchar num=0;
  48.         uint tnum=0;
  49.         uchar numstring[]={1,2,16,4,5,16,7,8,9,3};
  50.         while(1)
  51.         {
  52.                 for(tnum=50;tnum>0;tnum--)
  53.                 {
  54.                         for(num=0;num<8;num++)
  55.                         {
  56.                                 dtshowstring(numstring);
  57.                         }
  58.                 }
  59.                 delayms(500);
  60.         }
  61. }
