樓主的源程序如下:
- /* 智能秒表(使用內(nèi)部EEPROM) */
- /**(1)啟動(dòng)/停止功能 **/
- /**(2)復(fù)位/間隔功能 **/
- /**(3)兩種工作模式 **/
- /**(4)查看數(shù)據(jù)功能 **/
- /**(5)斷電記憶功能 **/
- #include <reg52.h>
- #include <intrins.h>
- #define uint unsigned int
- #define uchar unsigned char
- #define RdCommand 0x01 //定義內(nèi)部EEPROM存儲(chǔ)器部分
- #define PrgCommand 0x02
- #define EraseCommand 0x03
- #define Error 1
- #define Ok 0
- #define WaitTime 0x01
- sfr ISP_DATA=0xe2;
- sfr ISP_ADDRH=0xe3;
- sfr ISP_ADDRL=0xe4;
- sfr ISP_CMD=0xe5;
- sfr ISP_TRIG=0xe6;
- sfr ISP_CONTR=0xe7;
- sbit key1=P2^0; //定義"啟動(dòng)/暫停"按鈕
- sbit key2=P2^1; //定義"復(fù)位"按鈕
- sbit key3=P2^2; //定義"模式"按鈕
- sbit key4=P2^3; //定義"查看"按鈕
- sbit key5=P1^5; //定義"清除"按鈕
- sbit wei1=P2^4; //定義位選
- sbit wei2=P2^5;
- sbit wei3=P2^6;
- sbit wei4=P2^7;
- bit flag_start,flag_mode,flag_2sec,flag_CLR;
- uchar temp,temp1,aa,aa1,shi,ge,shifen,baifen,num,i=0;
- uchar time_data1[11],time_data2[11];
- uchar code table[]={ //共陰極數(shù)碼管編碼
- 0x3f,0x06,0x5b,0x4f,
- 0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,
- 0x39,0x5e,0x79,0x71,0x40};
- void display(uchar shi,uchar ge,uchar shifen,uchar baifen); //聲明顯示子函數(shù)
- void delay(uint z); //聲明延時(shí)子函數(shù)
- void init(); //聲明初始化函數(shù)
- void key(); //聲明鍵掃描函數(shù)
- void display_process(); //聲明顯示處理函數(shù)
- void delayus(); //聲明延時(shí)微秒函數(shù)
- void data_read(); //聲明內(nèi)部EEPROM數(shù)據(jù)讀出函數(shù)
- void clear(); //聲明清除EEPROM數(shù)據(jù)函數(shù)
- void ISP_IAP_enable(void); //聲明EEPROM操作函數(shù)
- void ISP_IAP_disable(void);
- void ISPgoon(void);
- uchar byte_read(uint byte_addr);
- void SectorErase(uint sector_addr);
- void byte_write(uint byte_addr, uchar original_data);
- void memory_read(); //聲明EEPROM讀函數(shù)
- void memory_write(); //聲明EEPROM寫函數(shù)
- void main() //主函數(shù)
- init(); //調(diào)用初始化子程序
- while(1)
- key(); //調(diào)用按鍵掃描函數(shù)
- if(num==0&&i!=0) //如果一開機(jī)就按查看鍵
- memory_read(); //調(diào)用EEPROM數(shù)據(jù)讀出函數(shù)
- if(flag_CLR==1) //如果按了清除鍵
- clear(); //調(diào)用清除EEPROM數(shù)據(jù)函數(shù)
- display_process(); //調(diào)用顯示處理函數(shù)
- display(shi,ge,shifen,baifen); //調(diào)用顯示函數(shù)
- void delay(uint z) //延時(shí)毫秒函數(shù)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void display(uchar shi,uchar ge,uchar shifen,uchar baifen) //顯示程序
- P0=table[shi]; //使用動(dòng)態(tài)掃描的方法實(shí)現(xiàn)數(shù)碼管顯示
- wei1=0;
- delay(1);
- wei1=1;
- if(flag_CLR==0) //正常顯示時(shí),第二位顯示小數(shù)點(diǎn)
- P0=table[ge]|0x80;
- else //按清除鍵時(shí),不顯示小數(shù)點(diǎn)
- P0=table[ge];
- wei2=0;
- delay(1);
- wei2=1;
- P0=table[shifen]; //使用動(dòng)態(tài)掃描的方法實(shí)現(xiàn)數(shù)碼管顯示
- wei3=0;
- delay(1);
- wei3=1;
- P0=table[baifen];
- wei4=0;
- delay(1);
- wei4=1;
- void init() //初始化子程序
- temp=0;
- TMOD=0x01; //使用定時(shí)器T0的方式1
- TH0=(65536-10000)/256;
- TL0=(65536-10000)%256; //定時(shí)10ms中斷一次
- EA=1; //中斷總允許
- ET0=1; //允許定時(shí)器T0中斷
- void key() //按鍵掃描函數(shù)
- uchar j;
- if(key1==0) //檢測"啟動(dòng)"按鈕是否按下
- delay(5); //延時(shí)去抖動(dòng)
- if(key1==0) //再次檢測"啟動(dòng)"按鈕是否按下
- while(!key1) //松手檢測(按下時(shí)數(shù)碼管不滅)
- flag_start=~flag_start;
- if(flag_start==1)
- TR0=1; //啟動(dòng)定時(shí)器開始工作
- else
- TR0=0;
- if(key2==0) //檢測"間隔"按鈕是否按下
- delay(5);
- if(key2==0)
- while(!key2) //松手檢測
- if(flag_mode==0||i!=0)
- shi=0;
- ge=0;
- shifen=0;
- baifen=0;
- aa=0;
- temp=0;
- TR0=0;
- i=0;
- num=0;
- for(j=0;j<=10;j++)
- time_data1[j]=0;
- time_data2[j]=0;
- else
- num++;
- if(num==11)
- num=1;
- memory_write();
- if(key3==0)
- delay(5);
- if(key3==0)
- while(!key3) //松手檢測
- flag_mode=~flag_mode;
- if(key4==0)
- delay(5);
- if(key4==0)
- while(!key4) //松手檢測
- TR0=0;
- i++;
- if(i==11)
- i=1;
- data_read();
- if(key5==0)
- delay(5);
- if(key5==0)
- while(!key5) //松手檢測
- flag_CLR=~flag_CLR;
- void display_process() //顯示處理函數(shù)
- shifen=aa%100/10; //正常走秒的處理
- baifen=aa%10;
- shi=temp%100/10;
- ge=temp%10;
- if(flag_mode==1&&num!=0&&flag_2sec==0) //間隔2秒停頓的處理
- shi=time_data2[num]/10;
- ge=time_data2[num]%10;
- shifen=time_data1[num]/10;
- baifen=time_data1[num]%10;
- if(temp-time_data2[num]==2)
- flag_2sec=~flag_2sec;
- if(i!=0) //查看存儲(chǔ)數(shù)據(jù)的處理
- shi=time_data2[i]/10;
- ge=time_data2[i]%10;
- shifen=time_data1[i]/10;
- baifen=time_data1[i]%10;
- void timer0() interrupt 1 //定時(shí)器T0中斷服務(wù)函數(shù)
- TH0=(65536-10000)/256; //重新賦初值
- aa++; //中斷一次10ms變量aa的值加1
- if(aa==100) //中斷100次后,定時(shí)時(shí)間100*10ms=1000ms=1s,變量temp的值加1
- aa=0;
- temp++;
- if(temp==100) //秒表到達(dá)100s后回零
- temp=0;
- /* EEPROM存儲(chǔ)器操作函數(shù) */
- EA = 0;
- ISP_CONTR = ISP_CONTR & 0x18;
- ISP_CONTR = ISP_CONTR | WaitTime;
- ISP_CONTR = ISP_CONTR | 0x80;
- ISP_CONTR=ISP_CONTR&0x7f;
- ISP_TRIG=0x00;
- EA=1;
- ISP_IAP_enable();
- ISP_TRIG = 0x46;
- ISP_TRIG = 0xb9;
- _nop_();
- ISP_ADDRH = (uchar)(byte_addr >> 8);
- ISP_ADDRL = (uchar)(byte_addr & 0x00ff);
- ISP_CMD = ISP_CMD & 0xf8;
- ISP_CMD = ISP_CMD | RdCommand;
- ISPgoon();
- ISP_IAP_disable();
- return (ISP_DATA);
- uint iSectorAddr;
- iSectorAddr = (sector_addr & 0xfe00);
- ISP_ADDRH = (uchar)(iSectorAddr >> 8);
- ISP_ADDRL = 0x00;
- ISP_CMD = ISP_CMD | EraseCommand;
- ISPgoon();
- ISP_CMD = ISP_CMD | PrgCommand;
- ISP_DATA = original_data;
- ISPgoon();
- void data_read() //讀數(shù)組數(shù)據(jù)函數(shù)
- aa=time_data1[i];
- temp=time_data2[i];
- void memory_write() //寫EEPROM數(shù)據(jù)函數(shù)
- aa1=aa;
- temp1=temp;
- time_data1[num]=aa1;
- time_data2[num]=temp1;
- if(num==1)
- SectorErase(0x2000); //擦除扇區(qū)
- byte_write(0x2000+num,aa1); //重新寫入數(shù)據(jù)
- byte_write(0x2000+num+10,temp1); //重新寫入數(shù)據(jù)
- flag_2sec=0;
- void memory_read() //讀出EEPROM數(shù)據(jù)函數(shù)
- time_data1[i]=byte_read(0x2000+i);
- time_data2[i]=byte_read(0x2000+i+10);
- void clear() //清除EEPROM數(shù)據(jù)函數(shù)
- uchar j,k;
- for(k=0;k<21;k++)
- byte_write(0x2000+k,0x00);
- display(16,16,16,16);
- time_data1[j]=0;
- time_data2[j]=0;
復(fù)制代碼 |
