uid:265598 日志
超聲波測距LCD1602顯示
已有 1177 次閱讀2018-12-2 19:57 |個人分類:程序
SMC1602A(16*2)模擬口線接線方式
連接線圖:
       |LCM-----51   | LCM-----51   | LCM------51      |
       |DB0-----P1.0 | DB4-----P1.4 | RW-------P3.4    |
       |DB1-----P1.1 | DB5-----P1.5 | RS-------P3.3    |
       |DB2-----P1.2 | DB6-----P1.6 | E--------P3.5    |
       |DB3-----P1.3 | DB7-----P1.7 | VLCD接1K電阻到GND|
接線:模塊TRIG接 P3.7  ECH0 接P3.6
[注:stc89c52使用12M或11.0592M晶振,實測使用11.0592M]
#include <AT89x51.H>
//#include<12C5A60S2.H>
//器件配置文件
#include <intrins.h>
#define  RX  P3_6
#define  TX  P3_7
#define LCM_RW  P2_5 //定義LCD引腳
#define LCM_RS  P2_6
#define LCM_E   P2_7
#define LCM_Data  P0
#define Key_Data P3_3 //定義Keyboard引腳
#define Key_CLK  P3_2
#define Busy    0x80 //用于檢測LCM狀態(tài)字中的Busy標(biāo)識
void delay21us(void);
void LCMInit(void);
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
void delay_50us(unsigned int t);
void Decode(unsigned char ScanCode);
void WriteDataLCM(unsigned char WDLCM);
void WriteCommandLCM(unsigned char WCLCM,BuysC);
unsigned char ReadDataLCM(void);
unsigned char ReadStatusLCM(void);
unsigned char code mcustudio[] ={"==Range Finder=="};
unsigned char code email[] =    {"heyaodz@163.com "};
unsigned char code Cls[] =      {"                "};
unsigned char code ASCII[15] =    {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
static unsigned char DisNum = 0; //顯示用指針
       unsigned int  time=0;
   unsigned long S=0;
   bit      flag =0;
   unsigned char disbuff[4]    ={ 0,0,0,0,};
//寫數(shù)據(jù)
ReadStatusLCM(); //檢測忙
LCM_Data = WDLCM;
LCM_RS = 1;
LCM_RW = 0;
LCM_E = 0; //若晶振速度太高可以在這后加小的延時
LCM_E = 0; //延時
LCM_E = 1;
//寫指令
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC為0時忽略忙檢測
if (BuysC) ReadStatusLCM(); //根據(jù)需要檢測忙
LCM_Data = WCLCM;
LCM_RS = 0;
LCM_RW = 0;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
//讀數(shù)據(jù)
LCM_RS = 1;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
return(LCM_Data);
//讀狀態(tài)
LCM_Data = 0xFF;
LCM_RS = 0;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
while (LCM_Data & Busy); //檢測忙信號
return(LCM_Data);
void LCMInit(void) //LCM初始化
LCM_Data = 0;
WriteCommandLCM(0x38,0); //三次顯示模式設(shè)置,不檢測忙信號
    delay_50us(1000);
    delay_50us(1000);
    delay_50us(1000);
WriteCommandLCM(0x38,1); //顯示模式設(shè)置,開始要求每次檢測忙信號
WriteCommandLCM(0x08,1); //關(guān)閉顯示
WriteCommandLCM(0x01,1); //顯示清屏
WriteCommandLCM(0x06,1); // 顯示光標(biāo)移動設(shè)置
WriteCommandLCM(0x0F,1); // 顯示開及光標(biāo)設(shè)置
          //按指定位置顯示一個字符
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //當(dāng)要顯示第二行時地址碼+0x40;
X |= 0x80; //算出指令碼
WriteCommandLCM(X, 1); //發(fā)命令字
WriteDataLCM(DData); //發(fā)數(shù)據(jù)
//按指定位置顯示一串字符
unsigned char ListLength;
  ListLength = 0;
Y &= 0x1;
while (DData[ListLength]>0x19) //若到達字串尾則退出
if (X <= 0xF) //X坐標(biāo)應(yīng)小于0xF
DisplayOneChar(X, Y, DData[ListLength]); //顯示單個字符
ListLength++;
X++;
unsigned char j;
for(;t>0;t--)
for(j=19;j>0;j--);
    void Conut(void)
time=TH0*256+TL0;
TH0=0;
TL0=0;
S=(time*1.8)/10;     //算出來是MM
if((S>=7000)||flag==1) //超出測量范圍顯示“-”
  flag=0;
  DisplayOneChar(0, 1, ASCII[11]);
  DisplayOneChar(1, 1, ASCII[10]); //顯示點
  DisplayOneChar(2, 1, ASCII[11]);
  DisplayOneChar(3, 1, ASCII[11]);
  DisplayOneChar(4, 1, ASCII[11]);
  DisplayOneChar(5, 1, ASCII[12]); //顯示M
  disbuff[0]=S/1000;
  disbuff[1]=S/100%10;
  disbuff[2]=S/10%10;
  disbuff[3]=S%10;
  DisplayOneChar(0, 1, ASCII[disbuff[0]]);
  DisplayOneChar(2, 1, ASCII[disbuff[1]]);
  DisplayOneChar(3, 1, ASCII[disbuff[2]]);
  DisplayOneChar(4, 1, ASCII[disbuff[3]]);
     void zd0() interrupt 1 //T0中斷用來計數(shù)器溢出,超過測距范圍
    flag=1; //中斷溢出標(biāo)志
RX=0;
     void  StartModule()          //啟動模塊
  TX=1;
 delay21us();                       //啟動一次模塊
  TX=0;
void Timer_Count(void)
TR0=1;     //開啟計數(shù)
     while(RX); //當(dāng)RX為1計數(shù)并等待
     TR0=0; //關(guān)閉計數(shù)
         Conut(); //計算
void main(void)
    unsigned int valA;
unsigned char TempCyc;
    delay_50us(80000);//啟動等待,等LCM講入工作狀態(tài)
LCMInit();//LCM初始化
    delay_50us(5000);
DisplayListChar(0, 0, mcustudio);
DisplayListChar(0, 1, email);
ReadDataLCM();//測試用句無意義
for (TempCyc=0; TempCyc<10; TempCyc++)
    delay_50us(80000);
DisplayListChar(0, 1, Cls);
TMOD=0x01;    //設(shè)T0為方式1,GATE=1;
TH0=0;
TL0=0;
ET0=1;             //允許T0中斷
EA=1;    //開啟總中斷
delay_50us(80000);
RX=1;
    StartModule();
        for(valA=7510;valA>0;valA--)
       if(RX==1)
           Timer_Count();
void delay21us(void)   //誤差 -0.021990740741us
    unsigned char a,b;
    for(b=1;b>0;b--)
        for(a=55;a>0;a--);
路過
雞蛋
鮮花
握手
雷人
評論 (0 個評論)
返回頂部
