立即注冊 登錄
返回首頁
uid:71870的個人空間
日志
簡易上位機程序
已有 997 次閱讀2015-1-18 08:45 | 程序
Private iFlow As Integer, iTempEcho As Boolean
Sub LoadPropertySettings()
Dim i As Integer, Settings As String, Offset As Integer
' Load Port Settings
For i = 1 To 16
    cboPort.AddItem "Com" & Trim$(Str$(i))
Next i
' Load Speed Settings
cboSpeed.AddItem "110"
cboSpeed.AddItem "300"
cboSpeed.AddItem "600"
cboSpeed.AddItem "1200"
cboSpeed.AddItem "2400"
cboSpeed.AddItem "4800"
cboSpeed.AddItem "9600"
cboSpeed.AddItem "14400"
cboSpeed.AddItem "19200"
cboSpeed.AddItem "28800"
cboSpeed.AddItem "38400"
cboSpeed.AddItem "56000"
cboSpeed.AddItem "57600"
cboSpeed.AddItem "115200"
cboSpeed.AddItem "128000"
cboSpeed.AddItem "256000"
' Load Data Bit Settings
cboDataBits.AddItem "4"
cboDataBits.AddItem "5"
cboDataBits.AddItem "6"
cboDataBits.AddItem "7"
cboDataBits.AddItem "8"
' Load Parity Settings
cboParity.AddItem "Even"
cboParity.AddItem "Odd"
cboParity.AddItem "None"
cboParity.AddItem "Mark"
cboParity.AddItem "Space"
' Load Stop Bit Settings
cboStopBits.AddItem "1"
cboStopBits.AddItem "1.5"
cboStopBits.AddItem "2"
' Set Default Settings
Settings = Form1.MSComm1.Settings
' In all cases the right most part of Settings will be 1 character
' except when there are 1.5 stop bits.
If InStr(Settings, ".") > 0 Then
    Offset = 2
Else
    Offset = 0
End If
cboSpeed.Text = Left$(Settings, Len(Settings) - 6 - Offset)
Select Case Mid$(Settings, Len(Settings) - 4 - Offset, 1)
Case "e"
    cboParity.ListIndex = 0
Case "m"
    cboParity.ListIndex = 1
Case "n"
    cboParity.ListIndex = 2
Case "o"
    cboParity.ListIndex = 3
Case "s"
    cboParity.ListIndex = 4
End Select
cboDataBits.Text = Mid$(Settings, Len(Settings) - 2 - Offset, 1)
cboStopBits.Text = Right$(Settings, 1 + Offset)
cboPort.ListIndex = Form1.MSComm1.CommPort - 1
optFlow(Form1.MSComm1.Handshaking).Value = True
If Echo Then
    optEcho(1).Value = True
Else
    optEcho(0).Value = True
End If
End Sub
Private Sub cmdCancel_Click()
Unload Me
End Sub
Private Sub cmdOK_Click()
Dim OldPort As Integer, ReOpen As Boolean
On Error Resume Next
Echo = iTempEcho
OldPort = Form1.MSComm1.CommPort
NewPort = cboPort.ListIndex + 1
If NewPort <> OldPort Then                   ' If the port number changes, close the old port.
    If Form1.MSComm1.PortOpen Then
           Form1.MSComm1.PortOpen = False
           ReOpen = True
    End If
    Form1.MSComm1.CommPort = NewPort          ' Set the new port number.
    If Err = 0 Then
        If ReOpen Then
            Form1.MSComm1.PortOpen = True
        End If
    End If
    If Err Then
        MsgBox Error$, 48
        Form1.MSComm1.CommPort = OldPort
        Exit Sub
    End If
End If
Form1.MSComm1.Settings = Trim$(cboSpeed.Text) & "," & Left$(cboParity.Text, 1) _
    & "," & Trim$(cboDataBits.Text) & "," & Trim$(cboStopBits.Text)
If Err Then
    MsgBox Error$, 48
    Exit Sub
End If
Form1.MSComm1.Handshaking = iFlow
If Err Then
    MsgBox Error$, 48
    Exit Sub
End If
SaveSetting App.Title, "Properties", "Settings", Form1.MSComm1.Settings
SaveSetting App.Title, "Properties", "CommPort", Form1.MSComm1.CommPort
SaveSetting App.Title, "Properties", "Handshaking", Form1.MSComm1.Handshaking
Form1.Label2 = Form1.MSComm1.Settings
Form1.Label4 = Form1.MSComm1.CommPort
Form1.Label6 = Form1.MSComm1.Handshaking
Unload Me
End Sub
Private Sub Form_Load()
' Set the form's size
Me.Left = (Screen.Width - Me.Width) / 2
Me.Top = (Screen.Height - Me.Height) / 2
' Make sure the frame is the top most control
fraSettings.ZOrder
' Load current property settings
End Sub
Private Sub optEcho_Click(Index As Integer)
If Index = 1 Then
    iTempEcho = True
Else
    iTempEcho = False
End If
End Sub
Private Sub optFlow_Click(Index As Integer)
iFlow = Index
End Sub
路過
雞蛋
鮮花
握手
雷人
評論 (0 個評論)
返回頂部
