完美的平衡車程序,完整的代碼,有卡爾曼濾波和PID
單片機源程序如下:
- 標(biāo)題: mian.c
- 日期: 2013/12/27
- 版本:v1.0
- MDK-ARM 版本: v4.12
- ST 庫版本:v3.50
- 功能: 自平衡小車平衡及控制
- 說明:可結(jié)合上位機校正六軸的補償值,使用藍牙或者NRF24L01控制
- #include "stm32f10x.h"
- #include "iic.h"
- #include "timer.h"
- #include "usart.h"
- #include "24l01.h"
- #include "mpu3050.h"
- #include "adxl345.h"
- #include "filter.h"
- #include "calculate.h"
- #include "usb_lib.h"
- #include "usb_desc.h"
- #include "usb_istr.h"
- #include "hw_config.h"
- #include "usb_pwr.h"
- #include <stdio.h>
- #include <math.h>
- u8 receive_data;
- u8 flg_get_senor_data;
- u8 out[35] ={0x5f, 0x60, 0};
- static float angle, angle_dot, f_angle, f_angle_dot;
- s16 temp;
- s16 gx, gy, gz, ax ,ay, az, temperature;
- s16 gx_offset, ax_offset, ay_offset, az_offset;
- u8 tmp[2]={0};
- #define USB
- #define FILTER_COUNT 32
- s16 gx_buf[FILTER_COUNT], ax_buf[FILTER_COUNT], ay_buf[FILTER_COUNT],az_buf[FILTER_COUNT];
- void delay(u32 count) //延時函數(shù)
- for(; count != 0; count--);
- 名稱:void acc_filter(void)
- 功能:加速度計數(shù)據(jù)濾波
- 輸入?yún)?shù):據(jù)濾波后的數(shù)據(jù)
- 輸出參數(shù):無
- 返回值: 無
- void acc_filter(void)
- u8 i;
- s32 ax_sum = 0, ay_sum = 0, az_sum = 0;
- for(i = 1 ; i < FILTER_COUNT; i++)
- ax_buf[i - 1] = ax_buf[i];
- ay_buf[i - 1] = ay_buf[i];
- az_buf[i - 1] = az_buf[i];
- ax_buf[FILTER_COUNT - 1] = ax;
- ay_buf[FILTER_COUNT - 1] = ay;
- az_buf[FILTER_COUNT - 1] = az;
- for(i = 0 ; i < FILTER_COUNT; i++)
- ax_sum += ax_buf[i];
- ay_sum += ay_buf[i];
- az_sum += az_buf[i];
- ax = (s16)(ax_sum / FILTER_COUNT);
- ay = (s16)(ay_sum / FILTER_COUNT);
- az = (s16)(az_sum / FILTER_COUNT);
- int main(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- #ifdef USB //usb接入
- NVIC_InitTypeDef NVIC_InitStructure;
- #endif
- u8 j, i=0;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- GPIO_SetBits(GPIOA,GPIO_Pin_5); //blue led
- #ifdef USB
- usb_system_init();
- #endif
- //初始化
- usart_init();
- iic_init();
- timer_init();
- NRF24L01_Init(); //初始化NRF24L01
- mpu3050_init();
- adxl345_init();
- motor_init();
- LED2OFF;//確認(rèn)關(guān)閉LED2
- while(NRF24L01_Check())//檢測不到24L01
- delay(3000);
- LED2ON; //LED2常亮
- RX_Mode(); //24L01接收模式
- LED1ON;
- while (1)
- if(flg_get_senor_data) //TIM3觸發(fā)
- flg_get_senor_data = 0;
- #ifdef USB
- NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelCmd = DISABLE; //USB通訊關(guān)閉
- NVIC_Init(&NVIC_InitStructure);
- #endif
- //獲取六軸的原始值
- mpu3050_get_data(&gx, &gy, &gz, &temperature);
- adxl345_get_data(&ax, &ay ,&az);
- #ifdef USB
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //USB通訊啟動
- #endif
- acc_filter();
- gx -= gx_offset; //gx補償校正
- ax -= ax_offset; //ax補償校正
- ay -= ay_offset; //ay補償校正
- az -= az_offset; //az補償校正
- angle_dot = gx * GYRO_SCALE; //+-2000 0.060975 °/LSB
- angle = atan(ay / sqrt(ax * ax + az * az ));
- angle = angle * 57.295780; //180/pi
- kalman_filter(angle, angle_dot, &f_angle, &f_angle_dot);//卡爾曼濾波函數(shù)
- if(tmp[0]==0){ receive_parameter(receive_data);}//藍牙控制
- if(NRF24L01_RxPacket(tmp)==0) //24L01控制
- receive_parameter(tmp[1]);
- LED1OFF;
- pid(f_angle, f_angle_dot); //PID調(diào)節(jié)
- #ifdef USB //USB上位機數(shù)據(jù)處理
- temp = (s16)(f_angle * 100);
- out[2] = (u8)(gx >> 8);
- out[3] = (u8)(gx);
- out[4] = (u8)(gy >> 8);
- out[5] = (u8)(gy);
- out[6] = (u8)(gz >> 8);
- out[7] = (u8)(gz);
- out[8] = (u8)(ax >> 8);
- out[9] = (u8)(ax);
- out[10] = (u8)(ay >> 8);
- out[11] = (u8)(ay);
- out[12] = (u8)(az >> 8);
- out[13] = (u8)(az);
- out[14] = (u8)(temp >> 8);
- out[15] = (u8)(temp);
代碼.7z
(698.94 KB, 下載次數(shù): 119)
2022-12-13 04:14 上傳
點擊文件名下載附件
