各位大俠幫忙看一下問題出在那兒,秒表開始后按了設(shè)定了好的按鍵不會停止,想實(shí)現(xiàn)的功能是按下key2=5的按鍵開始,再按下停止以此循環(huán)查了一下似乎if(key2==5)下面的語句進(jìn)不去TR0一直都是1,按鍵編碼檢查了沒有問題,還望指點(diǎn)迷津
#include <reg52.h>
#include<intrins.h>
sbit wei=P2^6;
sbit duan=P2^7;
uchar code table_tube[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar code a[]={0xFE,0xFD,0xFB,0xF7};
uint xms,temp,key1,key2;
uchar num,bai,shi,ge,tt0;
void delay(uint);
void display(uchar,uchar,uchar);
void init();
uchar keynum();
uchar coding(uchar);
init();
key1=keynum();
key2=coding(key1);
if(key2==5)
key2=0;
TR0=~TR0;
void init()
TMOD=0x11;
TH0=(65535-10000)/256;
TL0=(65535-10000)%256;
TH1=(65535-1000)/256;
TL1=(65535-1000)%256;
EA=1;ET0=1;TR0=1;
ET1=1;TR1=1;
P1=0xff;
wei=1;
P0=0xf8;
wei=0;
duan=1;
P0=table_tube[0];
duan=0;
void display(uchar bai,uchar shi,uchar ge)
wei=1;
P0=0xfe;
wei=0;
duan=1;
P0=table_tube[bai]+0x80;
duan=0;
delay(1);
wei=1;
P0=0xfd;
wei=0;
duan=1;
P0=table_tube[shi];
duan=0;
delay(1);
wei=1;
P0=0xfb;
wei=0;
duan=1;
P0=table_tube[ge];
duan=0;
delay(1);
uchar coding(uchar m)
uchar k;
switch(m)
case (0xee): k=0;break;
case (0xde): k=1;break;
case (0xbe): k=2;break;
case (0x7e): k=3;break;
case (0xed): k=4;break;
case (0xdd): k=5;break;
case (0xbd): k=6;break;
case (0x7d): k=7;break;
case (0xeb): k=8;break;
case (0xdb): k=9;break;
case (0xbb): k=10;break;
case (0x7b): k=11;break;
case (0xe7): k=12;break;
case (0xd7): k=13;break;
case (0xb7): k=14;break;
case (0x77): k=15;break;
return k;
uchar keynum()
uchar i,k;
P1=0xf0; //¿éòÔÖ±½óìá衸ßËÄλ±è½Ï£¬èôÎT¼ü°′Ï£¬¸ßËÄλ±Ø¶¨êÇ1111£¬±è½ÏP1&0xf0oí0xf0êÇ·ñÏàí¬¼′¿é
if((P1&0xf0)!=0xf0)
delay(5);
if((P1&0xf0)!=0xf0)
i=0;
P1=a[i];
while(i<4)
if((P1&0xf0)!=0xf0) //¿éòÔÖ±½óìá衸ßËÄ룬±è½ÏP1&0xf0oí0xf0
k=P1;
break;
i++;
P1=a[i];
// while((P1&0xf0)!=0xf0);
return k;
return 0;
void delay(uint xms)
uint x,y;
for(x=xms;x>0;x--)
for(y=110;y>0;y--);
void timer0()interrupt 1
temp++;
if(temp==1000)
temp=0;
bai=temp/100;
shi=temp%100/10;
ge=temp%100%10;
void timer1()interrupt 3
display(bai,shi,ge);
