超聲波測距顯示和避障
- #include <reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit K1=P1^0; //P1.0到P1.4為尋線檢測端
- sbit K2=P1^1;
- sbit K3=P1^2;
- sbit K4=P1^3;
- sbit K5=P1^4;
- sbit KIN1=P1^5; //P1.5 P1.6是避障檢測端
- sbit KIN2=P1^6;
- sbit out1 = P2^0 ; //P2.0到P2.3是電機(jī)驅(qū)動(dòng)輸出控制端
- sbit out2 = P2^1 ;
- sbit out3 = P2^2 ;
- sbit out4 = P2^3 ;
- sbit Trig = P3^3; //產(chǎn)生脈沖引腳
- sbit Echo = P3^2; //回波引腳
- sbit beem= P3^7; //蜂鳴器控制引腳
- sbit PWM=P1^7; //舵機(jī)pwm//
- sbit SET1=P2^4 ;
- sbit SET2 =P2^5;
- sbit SET3 =P2^6;
- sbit SET4 =P2^7;
- uchar code seg7code[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- uint distance[4]; //測距接收緩沖區(qū)
- uint distance1;
- uchar ge,shi,bai,temp,flag,outcomeH,outcomeL,PDATA; //自定義寄存器
- bit succeed_flag; //測量成功標(biāo)志
- unsigned long xdata rec_code;
- unsigned long xdata time_us;
- unsigned char xdata rec_cnt;
- unsigned char xdata kbuf;
- uchar sdata,flag; //sdata是紅外遙控接收鍵值變量 flag是啟動(dòng)小車 或停止小車變量
- uint j,a;
- uchar pro;
- bit rec_b;
- bit key_save;
- bit keyp;
- void chaoshengbo();
- void conversion(uint temp_data);
- void delay_20us();
- void delay_ms(uint x);
- void display ();
- void Init() //初始化
- flag=0;
- Trig=0;
- TMOD = 0x11; //T/C1采用16位定時(shí)器/計(jì)數(shù)器
- ET1 = 1; //定時(shí)器1開中斷
- ET0 = 1;
- TH0 = 0x00;
- TL0 = 0x00;
- TH1 = 0xff;
- TL1 = 0xce;
- TR1=0;
- TR0 = 0;
- //定時(shí)計(jì)數(shù)器啟動(dòng)計(jì)數(shù)
- EX0 = 1; //外部中斷0關(guān)中斷
- PX0 = 1;
- PT1 = 1;
- EA = 1; //CPU開中斷
- //-------超聲波測距----------------------------
- uint distance_data;
- display ();
- EA=0;
- Trig=1;
- delay_20us();
- Trig=0; //產(chǎn)生一個(gè)20us的脈沖,在Trig引腳
- while(Echo==0); //等待Echo回波引腳變高電平
- succeed_flag=0; //清測量成功標(biāo)志
- TH0=0; //定時(shí)器1清零
- TL0=0; //定時(shí)器1清零
- EX0=1; //打開外部中斷
- TR0=1; //啟動(dòng)定時(shí)器1
- EA=1;
- display ();
- display ();
- display ();
- display ();
- display ();
- EX0=0; //打開外部中斷
- TR0=0;
- if(succeed_flag==1)
- distance_data=outcomeH; //測量結(jié)果的高8位
- distance_data<<=8; //放入16位的高8位
- distance_data=distance_data|outcomeL;//與低8位合并成為16位結(jié)果數(shù)據(jù)
- distance_data=(distance_data/25)*43/100+1;
- a=distance_data; //超聲波測距 距離
- distance1=a;
- display ();
- display (); display ();
- void delay_us(uint x) //演示程序
- do {
- x--;
- while(x>1);
- while(x!=0)
- delay_us(500);
- x--;
- void baidong() //舵機(jī)轉(zhuǎn)動(dòng)
- TR1=1;
- pro=30; //90°
- delay_ms(100);
- pro=10; //小于10°
- delay_ms(100);
- pro=50; //大于160°
- delay_ms(100);
- pro=25; //90°
- delay_ms(100);
- TR1=0;
- void timer0() interrupt 3//定時(shí)0.1ms
- EX0=0;
- TH1=0xff;
- TL1=0xce;
- j++;
- if(j<=pro)
- PWM=1;
- else
- PWM=0;
- if(j==400) //周期20ms
- j=0;
- PWM=~PWM;
- //左轉(zhuǎn)
- void comeleft()
- out1=0;
- out2=1;
- out3=1;
- out4=0;
- delay_ms(40);
- //右轉(zhuǎn)
- void comeright ()
- out1=1;
- out2=0;
- out3=0;
- out4=1;
- delay_ms(40);
- //前進(jìn)加速;
- void comeon()
- { out2=1;
- delay_us(440);
- out2=0;
- out4=0;
- out1=1;
- out3=1;
- //后退;
- void back()
- { out2=1;
- out4=1;
- out1=0;
- out3=0;
- delay_ms(200);
- void stop() //停止
- out1=0;
- out2=0;
- out3=0;
- out4=0;
- //避障
- void shunback()
- { uint DATA1,DATA2,i;
- chaoshengbo();
- display ();
- if(distance1<12) //當(dāng)超聲波測距距離小于8則
- stop(); //小車停止運(yùn)動(dòng)
- beem=0;
- for(i=0;i<200;i++){display ();}
- beem=1;
- beem=0 ;
- beem=1;
- EX0=0; //關(guān)閉外部中斷
- TR0=0;
- TR1=1;
- pro=10; //舵機(jī)轉(zhuǎn)動(dòng)到0°
- delay_ms(50);
- TR1=0;
- PWM=1;
- delay_ms(10);
- chaoshengbo(); //檢測0°方向 障礙物距離
- DATA1= distance1;
- distance1=0;
- TR0=0;
- TR1=1;
- pro=50; //舵機(jī)轉(zhuǎn)動(dòng)到180°
- delay_ms(50);
- TR1=0;
- PWM=1;
- delay_ms(10);
- chaoshengbo(); //檢測180°方向障礙物距離
- DATA2= distance1;
- distance1=0;
- TR0=0;
- TR1=1;
- pro=25; //舵機(jī)返回90°方向
- delay_ms(50);
- TR1=0;
- delay_ms(10);
- if(DATA1>=12 && DATA1>DATA2){comeright ();comeon(); }//當(dāng)0度方向大于 8cm 并大于180度方向 則右轉(zhuǎn) 前進(jìn)
- else if (DATA2>=12 && DATA2>=DATA1){comeleft(); comeon(); } //當(dāng)180度方向大于 8cm 并大于0度方向 則左轉(zhuǎn) 前進(jìn)
- else if (DATA2<12 && DATA1<8) {back(); comeleft();comeon(); }//當(dāng)180度方向和0度方向都小于8cm 則小車后退一定距離 左轉(zhuǎn) 前進(jìn)
- else{ comeon(); }//否則小車直走
- void display ()
- P2=P2|0XF0;
- P0=~seg7code[0];
- SET1=0;
- delay_us(20);
- P2=P2|0XF0;
- P0=~seg7code[distance1/100];
- SET2=0;
- delay_us(20);
- P2=P2|0XF0;
- P0=~seg7code[(distance1%100)/10];
- SET3=0;
- delay_us(20);
- P2=P2|0XF0;
- P0=~seg7code[distance1%10];
- SET4=0;
- delay_us(20);
- P2=P2|0XF0;
- void main(void)
- P1=0XFF;
- P2=0XFF;
- P3=0XFF;
- P0=0XFF;
- Init(); //初始化
- baidong();
- while(1)
- shunback();
超聲波測距顯示并避障.rar
(33.77 KB, 下載次數(shù): 10)
2017-11-30 22:15 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
