LCD動態(tài)顯示漢字
單片機LCD12864驅動源程序如下:
- #include <reg51.h>
- #include <intrins.h>
- #define Dataport P0 //LCD數(shù)據(jù)線
- sbit RS=P2^2; // 數(shù)據(jù)\指令 選擇
- sbit RW=P2^1; // 讀\寫 選擇
- sbit EN=P2^0; // 讀\寫使能
- sbit cs1=P2^4; // 片選1
- sbit cs2=P2^3; // 片選2
- #define uint unsigned int
- #define uchar unsigned uchar
- /* 定義中文字庫 */
- unsigned char code Hzk[]={
- /*-- 文字: 中 --*/
- /*-- 宋體12; 此字體下對應的點陣為:寬x高=16x16 --*/
- 0x00,0x00,0xFC,0x08,0x08,0x08,0x08,0xFF,0x08,0x08,0x08,0x08,0xFC,0x08,0x00,0x00,
- 0x00,0x00,0x07,0x02,0x02,0x02,0x02,0xFF,0x02,0x02,0x02,0x02,0x07,0x00,0x00,0x00,
- /*-- 文字: 國 --*/
- 0x00,0xFE,0x02,0x0A,0x8A,0x8A,0x8A,0xFA,0x8A,0x8A,0x8A,0x0A,0x02,0xFE,0x00,0x00,
- 0x00,0xFF,0x40,0x48,0x48,0x48,0x48,0x4F,0x48,0x49,0x4E,0x48,0x40,0xFF,0x00,0x00,
- /*-- 文字: 人 --*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x3F,0xC2,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x40,0x20,0x10,0x0C,0x03,0x00,0x00,0x01,0x06,0x0C,0x18,0x30,0x60,0x20,0x00,
- /*-- 文字: 民 --*/
- 0x00,0x00,0xFE,0x92,0x92,0x92,0x92,0xF2,0x92,0x92,0x92,0x9E,0x80,0x80,0x00,0x00,
- 0x00,0x00,0xFF,0x40,0x20,0x10,0x00,0x00,0x03,0x0C,0x10,0x20,0x40,0xF0,0x00,0x00,
- /*-- 文字: 解 --*/
- 0x08,0xF4,0x57,0x54,0xFC,0x54,0xF0,0x42,0xA2,0x1E,0x02,0xA2,0x62,0x3E,0x00,0x00,
- 0x80,0x7F,0x02,0x02,0x5F,0x82,0x7F,0x0A,0x09,0x09,0x09,0xFF,0x09,0x09,0x09,0x00,
- /*-- 文字: 放 --*/
- 0x08,0x08,0xF8,0x49,0x4E,0xC8,0x88,0x40,0x38,0xCF,0x0A,0x08,0x88,0x78,0x08,0x00,
- 0x40,0x30,0x0F,0x40,0x80,0x7F,0x00,0x40,0x20,0x10,0x0B,0x0E,0x31,0x60,0x20,0x00,
- /*-- 文字: 軍 --*/
- 0x00,0x18,0x26,0x22,0xA2,0x72,0x2E,0xAA,0x22,0x22,0x22,0x32,0x22,0x0A,0x06,0x00,
- 0x00,0x10,0x10,0x12,0x13,0x12,0x12,0xFF,0x12,0x12,0x12,0x13,0x12,0x18,0x10,0x00,
- /*-- 文字: 第 --*/
- 0x10,0x08,0x04,0xD3,0x56,0x5A,0x52,0x5A,0xF4,0x53,0x56,0x5A,0x72,0x02,0x02,0x00,
- 0x00,0x20,0x20,0x23,0x12,0x12,0x0A,0x06,0xFF,0x02,0x02,0x12,0x22,0x1E,0x00,0x00,
- /*-- 文字: 三 --*/
- 0x00,0x04,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x04,0x00,0x00,
- 0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
- /*-- 文字: 三 --*/
- /*-- 文字: 零 --*/
- 0x00,0x0C,0x04,0x55,0x55,0x55,0x85,0x7F,0x85,0x55,0x55,0x55,0x05,0x0C,0x04,0x00,
- 0x04,0x04,0x04,0x0A,0x0A,0x09,0x2A,0xCC,0x28,0x19,0x09,0x02,0x06,0x02,0x02,0x00,
- /*-- 文字: 三 --*/
- /*-- 文字: 工 --*/
- 0x00,0x00,0x02,0x02,0x02,0x02,0x02,0xFE,0x02,0x02,0x02,0x02,0x02,0x02,0x00,0x00,
- 0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
- /*-- 文字: 廠 --*/
- 0x00,0x00,0xFE,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x00,
- 0x40,0x30,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- /*-- 文字: 導 --*/
- 0x00,0x00,0x00,0x3E,0x4A,0x4A,0x4A,0x4A,0x4A,0x4A,0xCA,0x4E,0x40,0x70,0x00,0x00,
- 0x02,0x02,0x02,0x02,0x06,0x3A,0x12,0x02,0x42,0x82,0x7F,0x02,0x02,0x02,0x02,0x00,
- /*-- 文字: 彈 --*/
- 0x02,0xF2,0x12,0x12,0x1E,0x00,0xF9,0x2A,0x2C,0xF8,0x28,0x2C,0x2B,0xFA,0x00,0x00,
- 0x01,0x43,0x81,0x41,0x3F,0x08,0x0B,0x09,0x09,0xFF,0x09,0x09,0x09,0x0B,0x08,0x00,
- /*-- 文字: 中 --*/
- /*-- 文字: 心 --*/
- 0x00,0x80,0x00,0x00,0xF0,0x00,0x01,0x02,0x1C,0x08,0x00,0x40,0x80,0x00,0x00,0x00,
- 0x04,0x03,0x00,0x00,0x3F,0x40,0x40,0x40,0x40,0x40,0x40,0x78,0x00,0x07,0x02,0x00,
- /*-- 文字: 胡 --*/
- 0x08,0x88,0x88,0x88,0xFF,0x88,0x88,0x08,0x00,0xFE,0x12,0x12,0x12,0xFE,0x00,0x00,
- 0x00,0x3F,0x10,0x10,0x10,0x10,0x7F,0x80,0x40,0x3F,0x01,0x41,0x81,0x7F,0x00,0x00,
- /*-- 文字: 國 --*/
- /*-- 文字: 平 --*/
- 0x00,0x01,0x05,0x09,0x71,0x21,0x01,0xFF,0x01,0x41,0x21,0x1D,0x09,0x01,0x00,0x00,
- 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0xFF,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x00,
- /*-- 文字: --*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- /*-- 文字: --*/
- /*-- 文字: --*/
- /* 定義ASCII字庫8列*16行 */
- unsigned char code Ezk[]={
- /*-- 文字: Q --*/
- /*-- 宋體12; 此字體下對應的點陣為:寬x高=8x16 --*/
- 0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x18,0x24,0x24,0x38,0x50,0x4F,0x00,
- /*-- 文字: Q --*/
- /*-- 文字: 1 --*/
- 0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,
- /*-- 文字: 3 --*/
- 0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,
- /*-- 文字: 0 --*/
- 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,
- /*-- 文字: 8 --*/
- 0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,
- /*-- 文字: 1 --*/
- /*-- 文字: 3 --*/
- /*-- 文字: 0 --*/
- /*-- 文字: 4 --*/
- 0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,
- /*-- 文字: --*/
- /*-- 文字: --*/
- /*-- 文字: --*/
- /*-- 文字: --*/
- /*-- 文字: --*/
- /*-- 文字: --*/
- void CheckState() //狀態(tài)檢查,LCD是否忙?
- unsigned char dat;
- RS=0;
- RW=1;
- do{
- Dataport=0x00;
- EN=1;
- dat=Dataport;
- EN=0;
- dat=0x80 & dat; //僅當?shù)?位為0時才可操作(判別busy信號)
- }while(!(dat==0x00));
- SendCommandToLCD(unsigned char command) //寫命令到LCD中
- CheckState();
- RS=0; //向LCD發(fā)送命令
- RW=0;
- Dataport=command; //command :命令
- EN=1;
- EN=0;
- void SetLine(unsigned char page) //設置頁 0xb8是頁的首地址
- page=0xb8|page; //1011 1xxx 0<=page<=7 設定頁地址--X 0-7,8行為一頁64/8=8,共8頁
- SendCommandToLCD(page);
- void SetStartLine(unsigned char startline) //設定顯示開始行,0xc0是行的首地址
- startline=0xc0|startline; //1100 0000
- SendCommandToLCD(startline); //設置從哪行開始:0--63,一般從0 行開始顯示
- void SetColumn(unsigned char column) //設定列地址--Y 0-63 ,0x40是列的首地址
- column=column &0x3f; //column最大值為64,越出 0=<column<=63
- column= 0x40|column; //01xx xxxx
- SendCommandToLCD(column);
- void SetOnOff(unsigned char onoff) //開關顯示,0x3f是開顯示,0x3e是關顯示
- onoff=0x3e|onoff; //0011 111x,onoff只能為0或者1
- SendCommandToLCD(onoff);
- void WriteByte(unsigned char dat) //寫顯示數(shù)據(jù)
- CheckState();
- RS=1;
- RW=0;
- Dataport=dat;//dat:顯示數(shù)據(jù)
- EN=1;
- EN=0;
- void SelectScreen(unsigned char screen) //選擇屏幕screen: 0-全屏,1-左屏,2-右屏
- switch(screen)
- { case 0: cs1=0;//全屏
- _nop_(); _nop_(); _nop_();
- cs2=0;
- break;
- case 1: cs1=0;//左屏
- cs2=1;
- break;
- case 2: cs1=1;//右屏
- cs2=0;
- break;
- void ClearScreen(unsigned char screen) //清屏screen: 0-全屏,1-左屏,2-右
- unsigned char i,j;
- SelectScreen(screen);
- for(i=0;i<8;i++) //控制頁數(shù)0-7,共8頁
- SetLine(i);
- SetColumn(0);
- for(j=0;j<64;j++) //控制列數(shù)0-63,共64列
- WriteByte(0x00); //寫點內容,列地址自動加1
- void delay(uint nms) //延時程序
- uint i;
- for(; nms > 0; nms--)
- for(i = 0; i < 500; i++);
- void lcd_rol() //向上滾屏
- uint i;
- for(i = 0; i < 64; i++)
- cs1=0; // 片選1
- SendCommandToLCD(0xc0+i);
- cs1=1;
- cs2=0;// 片選2
- SendCommandToLCD(0xc0+62-i);
- cs2=0; // 片選2
- delay(6);
- void InitLCD( ) //初始化LCD
- CheckState();
- SelectScreen(0);
- SetOnOff(0); //關顯示
- SelectScreen(0);
- SetOnOff(1); //開顯示
- SelectScreen(0);
- ClearScreen(0);//清屏
- SetStartLine(0); //開始行:0
- //顯示全角漢字
- void Display(unsigned char ss,unsigned char page,unsigned char column,unsigned char number)
- int i; //選屏參數(shù),pagr選頁參數(shù),column選列參數(shù),number選第幾漢字輸出
- SelectScreen(ss);
- column=column&0x3f;
- SetLine(page); //寫上半頁
- SetColumn(column); //控制列
- for(i=0;i<16;i++) //控制16列的數(shù)據(jù)輸出
- WriteByte(Hzk[i+32*number]); //i+32*number漢字的前16個數(shù)據(jù)輸出
- SetLine(page+1); //寫下半頁
- WriteByte(Hzk[i+32*number+16]); //i+32*number+16漢字的后16個數(shù)據(jù)輸出
- //顯示半角漢字和數(shù)字和字母
- void Displayen(unsigned char ss,unsigned char page,unsigned char column,unsigned char number)
- SelectScreen(ss);
復制代碼
LCD動態(tài)顯示漢字.rar
(92.13 KB, 下載次數(shù): 259)
2017-12-2 21:27 上傳
點擊文件名下載附件
LCD動態(tài)顯示漢字
