查看: 2896|回復(fù): 0
TLC1543的驅(qū)動(dòng)程序 非常好用 本程序在項(xiàng)目上實(shí)踐過得
ID:144296 發(fā)表于 2017-12-3 12:58 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#include "intrins.h"
#include <stdio.h>
#include "lcd1602.h"
sbit CLOCK=P2^3;//時(shí)鐘
sbit D_IN=P2^2;//地址
sbit D_OUT=P2^1;//數(shù)據(jù)輸出
sbit _CS=P2^0;//片選
typedef unsigned char BYTE;
typedef unsigned int WORD;
BYTE flag,aa;
void init()
  TMOD=0X20;
TH1=0XFD;
TL1=0XFD;
TR1=1;
SM0=0;
SM1=1;
REN=1;
EA=1;
ES=1;
RI=0;
TI=0;
void comm(char *pp)
{  ES=0;
   do
     SBUF=*pp++;
  while(!TI);
  TI=0;
   }while(*pp);
     ES=1;
void ser()interrupt 4
  ES=0;
  while(!RI);
  RI=0;
  aa=SBUF;
  flag=1;
    ES=1;
WORD read1543(BYTE port)
   WORD data ad;
  WORD data i;
   BYTE data al=0,ah=0;
   CLOCK=0;
   _CS=0;
    port<<=4;
  for (i=0;i<4;i++) //
  D_IN=(bit)(port&0x80);CLOCK=1;CLOCK=0;
  port<<=1;
   for (i=0;i<6;i++) //??6?CLOCK
    CLOCK=1;CLOCK=0;
   _CS=1;
  _nop_();_nop_();
  _CS=0; //
   for (i=0;i<2;i++) //
      D_OUT=1;
      CLOCK=1;
      ah<<=1;
     if (D_OUT) ah|=0x01;
       CLOCK=0;
   for (i=0;i<8;i++) //D7--D0
  D_OUT=1;
  CLOCK=1;
al<<=1;
if (D_OUT) al|=0x01;
CLOCK=0;
   _CS=1;
   ad=(WORD)ah;ad<<=8;ad|=al; //AD?
     return (ad);
float count(BYTE ch)
  float temp;
   temp=read1543(ch)*5.00;//5.00為參考電壓  1024為10位adc的
  temp=temp/1023;
  return temp;
void Delay500ms()  [url=]//@11.0592MHz[/url]
unsigned char i, j, k;
_nop_();
_nop_();
i = 22;
j = 3;
k = 227;
do
  do
   while (--k);
  } while (--j);
} while (--i);
  float val;
BYTE buff[5];
  init();
lcd_init();
     val=count(0);
  sprintf(buff,"%.2f",val);
  comm(buff);
  comm("\n");
//    zifu_disp(0,0,buff);
   Delay500ms();
