查看: 1946|回復(fù): 0
單片機(jī)實(shí)時(shí)時(shí)鐘源程序
ID:256768 發(fā)表于 2017-12-3 14:15 | 顯示全部樓層 |閱讀模式
里面的-初始時(shí)間是我定的,你可以根據(jù)你的-實(shí)際-情況修改
  1. #include<reg52.h>
  2. #include<intrins.h>
  3. typedef unsigned char uchar;
  4. typedef unsigned int  uint;
  5. uchar  DB8;
  6. uchar Wen_Zi[8][8] = {
  7.                                                 {0x10,0x1f,0x10,0x0f,0x0a,0x1f,0x02,0x02},
  8.                                                 {0x0f,0x09,0x0f,0x09,0x09,0x0f,0x09,0x13},
  9.                                                 {0x1f,0x11,0x11,0x1f,0x1f,0x11,0x11,0x1f},
  10.                                                 {0x01,0x01,0x07,0x19,0x1d,0x1b,0x19,0x03},
  11.                                                 {0x0a,0x11,0x00,0x1f,0x05,0x05,0x09,0x13},
  12.                                                 {0x04,0x04,0x0c,0x15,0x05,0x02,0x04,0x08},
  13.                                                 {0x1f,0x15,0x1f,0x15,0x1f,0x11,0x15,0x13},
  14.                                                 {0x1c,0x14,0x18,0x06,0x09,0x08,0x08,0x07},
  15.                                          };
  16. uchar bdata DS_Shu;
  17. sbit DS8 = DS_Shu^7;
  18. sbit LEDl602_RS =  P2^6;
  19. sbit LEDl602_WR = P2^5;
  20. sbit LEDl602_OE = P2^7;
  21. sbit DS_IO = P3^4;
  22. sbit DS_CE = P3^5;
  23. sbit DS_SCLK = P3^6;
  24. void Yan_Shims(uint i)
  25. {
  26.         for(i=i*83;i>0;i--);
  27. }
  28. void Yan_Shius()
  29. {
  30.    _nop_();
  31. }
  32. bit Mang_Lu()
  33. {
  34.         bit i;
  35.         LEDl602_OE = 0;
  36.         LEDl602_RS = 0;
  37.         LEDl602_WR = 1;
  38.         LEDl602_OE = 1;
  39.         Yan_Shius();
  40.         DB8 = P0;
  41.         i = (bit)(DB8&0x80);
  42.         LEDl602_OE = 0;
  43.         return(i);
  44. }
  45. void Zhi_Ling(uchar NUM,uchar DATA)
  46. {
  47.         uchar a=0x01;
  48.     a =_crol_(a,(NUM - 1));
  49.         DATA = DATA +a;
  50.         while(Mang_Lu() != 0);
  51.                 LEDl602_OE = 0;
  52.                 LEDl602_RS = 0;
  53.                 LEDl602_WR = 0;
  54.                 Yan_Shius();
  55.                 P0 = DATA;
  56.                 Yan_Shius();
  57.                 LEDl602_OE = 1;
  58.                 Yan_Shius();
  59.                 LEDl602_OE = 0;
  60. }
  61. void Xie_DATA(uchar DATA)
  62. {
  63.         while(Mang_Lu() != 0);
  64.                 LEDl602_OE = 0;
  65.                 LEDl602_RS = 1;
  66.                 LEDl602_WR = 0;
  67.                 Yan_Shius();
  68.                 P0 = DATA;
  69.                 Yan_Shius();
  70.                 LEDl602_OE = 1;
  71.                 Yan_Shius();
  72.                 LEDl602_OE = 0;
  73. }
  74. void lad_rili()
  75. {
  76.         uchar i,t;
  77.         for(i=0;i<8;i++)
  78.         {
  79.                 for(t=0;t<8;t++)
  80.                 {
  81.                         Zhi_Ling(7,i*8+t);
  82.                         Yan_Shius();
  83.                         Xie_DATA(Wen_Zi[i][t]);
  84.                         Yan_Shius();
  85.                 }
  86.         }
  87. }
  88.
  89.   void DS_DiZhi(uchar Di_Zhi)
  90. {
  91.         uchar x;
  92.         for(x=0;x<8;x++)
  93.         {
  94.             DS_IO = Di_Zhi&0x01;
  95.                 Yan_Shims(1);
  96.                 DS_SCLK = 1;
  97.                 Yan_Shims(1);
  98.                 DS_SCLK = 0;
  99.                 Di_Zhi = Di_Zhi>>1;
  100.         }
  101. }
  102. void DS_Xie(uchar Di_Zhi,uchar Shu_Ju)
  103. {
  104.     DS_SCLK = 0;
  105.         DS_CE = 1;
  106.         Yan_Shius();
  107.         DS_DiZhi(Di_Zhi);
  108.         Yan_Shius();
  109.         DS_DiZhi(Shu_Ju);
  110.         Yan_Shims(1);
  111.         DS_CE = 0;
  112. }
  113. uchar DS_Du(uchar y)
  114. {
  115.         uchar i,x=0;
  116.         DS_Xie(0x8e,0x00);
  117.         DS_SCLK = 0;
  118.         DS_CE = 1;
  119.         DS_DiZhi(y);
  120.         DS_IO=1;
  121.         for(i=0;i<8;i++)
  122.         {
  123.             DS_Shu=DS_Shu>>1;
  124.                 Yan_Shius();
  125.                 DS8=DS_IO;
  126.                 Yan_Shius();
  127.                 DS_IO=1;
  128.                 DS_SCLK = 1;
  129.                 Yan_Shius();
  130.                 DS_SCLK = 0;
  131.         }
  132.         Yan_Shius();
  133.         DS_CE = 0;
  134.         return DS_Shu;
  135. }
  136.
  137. void Clock_ChuShi()
  138. {
  139.         Zhi_Ling(6,0x18);
  140.         Yan_Shius();
  141.         Zhi_Ling(4,0x04);
  142.         Yan_Shius();
  143.         Zhi_Ling(3,0x02);
  144.         Yan_Shius();
  145.         Zhi_Ling(1,0x00);
  146.         Yan_Shims(10);
  147.         lad_rili();
  148.         Yan_Shims(3);
  149.
  150.         DS_CE = 0;
  151.         DS_SCLK = 0;
  152.         DS_Xie(0x8e,0x00);
  153.         DS_Xie(0x8c,0x17);
  154.         DS_Xie(0x8a,0x02);
  155.         DS_Xie(0x88,0x09);
  156.         DS_Xie(0x86,0x26);
  157.         DS_Xie(0x84,0x23);
  158.         DS_Xie(0x82,0x35);
  159.         DS_Xie(0x80,0x00);
  160. }
  161. void main()
  162. {
  163.    Clock_ChuShi();
  164.    while(1)
  165.    {
  166.         Zhi_Ling(8,0x00);
  167.                 Xie_DATA('2');
  168.                 Xie_DATA('0');
  169.                 DS_Du(0x8d);
  170.                 Xie_DATA((DS_Shu/16+48));
  171.                 Xie_DATA((DS_Shu%16+48));
  172.                 Xie_DATA(0x00);
  173.                 Zhi_Ling(5,0x04);
  174.
  175.                    DS_Du(0x89);
  176.                 Xie_DATA((DS_Shu/16+48));
  177.                 Xie_DATA((DS_Shu%16+48));
  178.                 Xie_DATA(0x01);
  179.                 Zhi_Ling(5,0x04);
  180.
  181.                 DS_Du(0x87);
  182.                 Xie_DATA((DS_Shu/16+48));
  183.                 Xie_DATA((DS_Shu%16+48));
  184.                 Xie_DATA(0x02);
  185.                 Zhi_Ling(5,0x04);
  186.                 Xie_DATA(0x06);
  187.                 DS_Du(0x8b);
  188.                 Xie_DATA((DS_Shu%16+48));
  189.                 Zhi_Ling(5,0x04);
  190. ……………………
  191. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
實(shí)時(shí)時(shí)鐘.rar (27.56 KB, 下載次數(shù): 5)
