#include "reg51.h"
typedef unsigned char uint;
typedef unsigned char uchar;
unsigned char code disptab[] =
{0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,
0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xFF};
unsigned char code bittab[] =
{0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F};
unsigned char hour=24,min=0,sec=0;//時分秒
unsigned int count;//計數(shù)次數(shù)
unsigned char num=0;//數(shù)碼管序號
unsigned char s=1;
sbit sw1 = P3^1;
sbit sw2 = P3^2;
void delay(uchar i)
uint j;
while(i--)
for(j= 0; j<114 ; j++);
void disp(uchar sec) //顯示函數(shù)
num++;
num=(num%8);
P2=0xff; //數(shù)碼管消影
P0=0xff;
P2=bittab[num];
switch(num)
case 0:P0=disptab[sec%10]; break;//秒個位
case 1:P0=disptab[sec/10]; break;//秒十位
case 2:P0=disptab[0xff]; break;//
case 3:P0=disptab[min%10]; break;//分個位
case 4:P0=disptab[min/10]; break;//分十位
case 5:P0=disptab[0xff]; break;//
case 6:P0=disptab[hour%10]; break;//時個位
case 7:P0=disptab[hour/10]; break;//時十位
default:;
void disp1( uchar min) //顯示函數(shù)
num++;
num=(num%8);
P0=0xff;
P2=bittab[num];
switch(num)
default:;
void disp2( uchar hour) //顯示函數(shù)
num++;
num=(num%8);
P0=0xff;
P2=bittab[num];
switch(num)
default:;
//if(num==2||num==4)P0=P0&0x7f;
void t0() interrupt 1 //T0中斷函數(shù)
TL0=0x6c;//賦初值,重新定時1ms
TH0=0xfc;
count++;
if(count==1000)
int c=0,v;
if(!sw2)
{int v;
v=c+1;
c++;
count=0;
sec=sec+1;
if(sec==60) {sec=0;min++;}
delay (10);
count=0;
//TR0 = 0;
//sw2&&TR0==(min=min+1);
if(min==60) {min=0;hour++;}
disp1((sw2&&s));
sw1&&(hour=hour+v)&&count;
if(hour==24) {hour=0;}
s=0;
disp(sec);disp1(min);disp2(hour);
//disp(sec,min&&sw2,hour&&sw1);
void main() //主函數(shù)
TMOD=0x11; //T0工作方式1,定時
TH0=0xfc; //定時1ms,賦初值
TL0=0x6c;
ET0=1;
EA=1;
TR0=1;
while(1);
