查看: 2123|回復: 0
低頻發(fā)生器
ID:254712 發(fā)表于 2017-12-4 19:55 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include <absacc.h>
#define DA0832 XBYTE[0xffff]
uchar code tab[13]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39};
uchar code num [93]={0,0,1,0,3,0,0,2,9,0,2,8,0,2,7,0,2,6,
0,2,5,0,2,4,0,2,3,0,2,2,0,2,1,0,2,0,0,1,9,0,1,8,0,1,7,0,1,6,0,1,5,0,1,4,0,1,3,
0,1,2,0,1,1,0,1,0,0,0,9,0,0,8,0,0,7,0,0,6,0,0,5,0,0,4,0,0,3,0,0,2,0,0,1};
uchar code tosin[256]={0x7F,0x82,0x85,0x88,0x8B,0x8F,0x92,0x95,0x98,0x9B,0x9E,0xA1,0xA4,0xA7,0xAA,0xAD
,0xB0,0xB3,0xB6,0xB8,0xBB,0xBE,0xC1,0xC3,0xC6,0xC8,0xCB,0xCD,0xD0,0xD2,0xD5,0xD7
,0xD9,0xDB,0xDD,0xE0,0xE2,0xE4,0xE5,0xE7,0xE9,0xEB,0xEC,0xEE,0xEF,0xF1,0xF2,0xF4
,0xF5,0xF6,0xF7,0xF8,0xF9,0xFA,0xFB,0xFB,0xFC,0xFD,0xFD,0xFE,0xFE,0xFE,0xFE,0xFE
,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFD,0xFD,0xFC,0xFB,0xFB,0xFA,0xF9,0xF8,0xF7,0xF6
,0xF5,0xF4,0xF2,0xF1,0xEF,0xEE,0xEC,0xEB,0xE9,0xE7,0xE5,0xE4,0xE2,0xE0,0xDD,0xDB
,0xD9,0xD7,0xD5,0xD2,0xD0,0xCD,0xCB,0xC8,0xC6,0xC3,0xC1,0xBE,0xBB,0xB8,0xB6,0xB3
,0xB0,0xAD,0xAA,0xA7,0xA4,0xA1,0x9E,0x9B,0x98,0x95,0x92,0x8F,0x8B,0x88,0x85,0x82
,0x7F,0x7C,0x79,0x76,0x73,0x6F,0x6C,0x69,0x66,0x63,0x60,0x5D,0x5A,0x57,0x54,0x51
,0x4E,0x4B,0x48,0x46,0x43,0x40,0x3D,0x3B,0x38,0x36,0x33,0x31,0x2E,0x2C,0x29,0x27
,0x25,0x23,0x21,0x1E,0x1C,0x1A,0x19,0x17,0x15,0x13,0x12,0x10,0x0F,0x0D,0x0C,0x0A
,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x03,0x02,0x01,0x01,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x02,0x03,0x03,0x04,0x05,0x06,0x07,0x08
,0x09,0x0A,0x0C,0x0D,0x0F,0x10,0x12,0x13,0x15,0x17,0x19,0x1A,0x1C,0x1E,0x21,0x23
,0x25,0x27,0x29,0x2C,0x2E,0x31,0x33,0x36,0x38,0x3B,0x3D,0x40,0x43,0x46,0x48,0x4B
,0x4E,0x51,0x54,0x57,0x5A,0x5D,0x60,0x63,0x66,0x69,0x6C,0x6F,0x73,0x76,0x79,0x7C};
uchar fun=1,b=0,c=0,d=0,e=0,tl,th,flag=0;
sbit  P3_0=P3^0;
sbit  P3_1=P3^1;
sbit  P3_2=P3^2;
sbit  P2_7=P2^7;
uchar de1,de2;
uchar A=3;
void key1(void);
void key2(void);
void key3(void);
void delay(uchar k);
void main(void)
TMOD=0X01;
th=0xff;
tl=0x1e;
TH0=th;
TL0=tl;
ET0=1;
EA=1;
EX1=1;
PX1=1;
IT1=1;
TR0=1;
P3_0=0; P3_1=1;  P3_2=0;
if(num[flag*3]!=0)
P1=tab[num[flag*3]];
delay(0.01);
else{
P1=0;
P3_0=1;
P3_1=0;
P3_2=0;
P1=tab[num[flag*3+1]];
delay(0.01);
P1=0;
P3_0=0; P3_1=0;  P3_2=0;
P1=tab[num[flag*3+2]];
delay(0.01);
P1=0;
P3_0=1; P3_1=1;  P3_2=0;
P1=tab[fun+9];
delay(0.01);
P1=0;
void  delay(uchar k)   //延時程序
for(de1=0;de1<10;de1++)
     for(de2=0;de2<k;de2++){;}
void key1(void)             //1鍵選擇發(fā)波類型,1為正弦波,2為三角波,3為方波
fun++;
if(fun==4)
        fun=0x01;
void key2(void)            //2鍵加大頻率
        tl+=0x00;
        if(tl>0x1e)
        tl=0x01;
        if(flag>0)
        flag--;
        flag=30;
void key3(void)           //3鍵減小頻率
        if(th>0x00)
                th-=0x1;
                if(flag<30)
                flag++;
                flag=0;
void time0_int(void) interrupt 1   //中斷服務程序
       TR0=0;
       if(fun==1)
               DA0832=tosin[b]/4*A;              //正弦波
                   delay(flag) ;
               b++;
       else if(fun==2)                   //三角波
               if(c<128)
                   DA0832=c*2/4*A;
                   delay(flag);
                   DA0832=(255-c)*2/4*A;
                   delay(flag);
                   c++;
       else if(fun==3)                   // 方波
               d++;
               if(d<=128)
                   DA0832=0x00;
                       delay(flag);
                    DA0832=0xff/4*A;
                          delay(flag);
                TH0=th;
                TL0=tl;
                TR0=1;
void  int1 (void) interrupt 2       //int1中斷服務程序
   if(P2!=0xff)
         delay(flag);
        if(P2==0xff)
        return;
   if(P2==0xef) key1();
   if(P2==0xdf) key2();
   if(P2==0xbf) key3();
admin + 50 共享資料的黑幣獎勵!
Powered by 單片機教程網
