- #include<REG52.H>
- #include<math.h>
- #include<stdio.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit DQ=P2^2 ;
- sbit RS=P3^5;
- sbit RW=P3^6 ;
- sbit EN=P3^4 ;
- sbit R=P2^ 7 ;
- sbit T=P2^6 ;
- unsigned int time=0;
- unsigned long S=0;
- bit flag =0;
- unsigned char disbuff[4] ={ 0,0,0,0,};
- unsigned char code str1[]={"range temp"}
- float RxBuf,disdata[5] ;
- uint tvalue;//溫度值
- uchar tflag;//溫度正負(fù)標(biāo)志
- unsigned char code ASCII [15]=
- {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
- uchar Tx,Ax;
- /*********1cd1602 程序*********/
- Void delay lms(unsigned int ms)//延時(shí)1毫秒(不夠精確的)
- unsigned int i,j;
- for(i=0;i > ms;i++);
- for(j=0;j > 100;j++);
- void wr_com(unsi gned char com)//寫指令//
- delaylms(1) ;
- RS=0;
- RW=0;
- EN=0;
- P0=com;
- delay1ms(1) ;
- EN=1;
- delay1ms(1);
- EN=0;
- void lcd_init 0//初始化設(shè)置//
- //BLK=0 ;
- delay1ms(15) ;
- wr_com(0x38) ;
- delaylms(5)
- wr_com(0x08) ;delay1ms(5) ;
- wr_com(0x01) ;delaylms(5) ;
- wr_com(0x06) ;delay1ms(5) ;
- wr_com(0x0c) ;delay1ms(5) ;
- void display(unsigned char *p)//顯示//
- while(*p!='\0')
- wr_dat (*p);
- p++;
- //delaylms(1) ;
- init_play()//初始化顯示
- lcd_initO ;
- wr_com(0x80)
- display(strl) ;
- /***************************ds18b20程序**************/
- void delay_18B20(unsigned int i)//延時(shí)1微秒
- while(i--);
- viod ds18b20rst()/*dx18b20復(fù)位*/
- unsigned char x=0;
- DQ = 1;
- delay_18B20(4);
- DQ=0;
- delay_18B20(100);
- DQ=1;
- delay_18B20(40);
- uchar ds1820rd()/*讀數(shù)據(jù)*/
- unsigned char i=0;
- unsigned char dat 中0:
- for (i=8;i>0;i--)
- DQ = 0; //給脈沖信號(hào)
- dat>>=1;
- DQ = 1; //給脈沖信號(hào)
- if(DQ)
- dat |=0x80;
- delay_18B20(10) ;
- return(dat);
- void ds1820wr(uchar wdata)/*寫數(shù)據(jù)*/
- for (i=8; i>0;i--)
- DQ = 0;
- DQ = wdata&0x01;
- delay_18B20(10) ;
- DQ = 1;
- wdata>>=1;
- read_temp ()/*讀取溫度值并轉(zhuǎn)換*/
- uchar a,b;
- ds1820rst () ;
- ds1820wr(0xcc) ;//*跳過讀序列號(hào)*/
- ds1820wr(0x44) ;//*啟動(dòng)溫度轉(zhuǎn)換*/
- ds1820rst () ;
- ds1820wr (0xcc) ;//*跳過讀序列號(hào)*/
- ds1820wr (0xbe) ;//*讀取溫度*/
- a=ds1820rd();
- b=ds1820rd();
- tvalue=b ;
- tvalue<<=8;
- tvalue=tvalue|a;
- if(tvalue<0xOfff)
- tflag=0;
- else
- tvalue=~tvalue+1;
- tflag=1;
- tvalue=tvalue*(0.625) ;//溫度值擴(kuò)大10 倍,精確到1位小?
- tvalue=tvalue-15;
- return(tvalue);
- /***************************水****水*水水米*水***********/
- void show()//溫度值顯示
- uchar flagdat;
- time=TH0*256+TLO;
- THO=0;
- TL0=0;
- S=(time*1.7)/100;
- disdata[0]=tvalue/1000+0x30; //百位數(shù)
- disdata[1]=tvalue%1000/100+0x30;// 十位數(shù)
- disdata[2]=tvalue%100/10+0x30;//個(gè)位數(shù)
- disdata[3]=tvalue%10+0x30;//小數(shù)位
- disdata [4 ]=0x00 ;
- if(tflag==0)
- flagdat=0x20;//正溫度不顯示符號(hào)
- else
- flagdat=0x2d;//負(fù)溫度顯示負(fù)號(hào):-
- if(disdata[0]==0x30)
- disdata[0]=0x20;//如果百位為0,不顯示
- if(disdata[1]=0x30)
- disdata[11=0x20;//如果百位為0,十位為0 也不顯示
- disbuff[0]=S%1000/100;
- disbuff[1]=S%1000%100/10;
- disbuff[2]=S%1000%100%10;
- disbuff[3]=S%10000%1000 %100;
- wr_com (0xcO) ;
- wr_dat (ASCII [disbuff[O]]) ;//顯示百位
- wr_com(Oxc1) ;
- wr_dat(ASCII [10]) ;
- wr_com(0 x c2) ;
- wr_dat (ASCII[disbuff[1]]) ;
- wr_com(0xc3)
- wr_dat(ASCII [disbuff[2]]) ;
- wr_com(0xc4) ;
- wr_dat(ASCII[12]) :
- wr_com (0xc8)
- wr_dat(flagdat) ;//顯示符號(hào)?
- wr_com (0xc9) ;
- wr_dat disdata[0]) ;//顯示百位
- wr_com (Oxca) :
- wr_dat(disdata[1]) ;//顯示十位
- wr_com(0xcb) ;
- wr_dat (disdata[2]) ;//顯示個(gè)位
- wr_com (0xcc) ;
- wr_dat (0x2e) ;//顯示小數(shù)點(diǎn)
- wr_com (Oxcd) ;
- wr_dat(disdata[3]) ;//顯示小數(shù)位
- void StartModule()//啟動(dòng)模塊
- T=1; //啟動(dòng)一次模塊
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- T=0;
- void UART_Init (void) //串口初始化
- PCON = 0x00;
- SCON = 0x50; //串口工作方式為1,允許接收.
- TMOD = 0x21; // T1定時(shí)方式2 C
- THI = 0xfd;//波特率9600bps @ fosc = 11.0592MHz
- TLI = Oxfd;//啟動(dòng)T1
- THO =0;
- TLO =0;
- ES = 1;//開串中斷.
- ETO =1;
- TR1=1;//開總中斷。
- EA = 1;
- void Send (uchar dat)
- SBUF = dat; //待發(fā)送的數(shù)據(jù)寫心緩沖區(qū)
- while(!TI); //等待發(fā)送完成
- TI = 0; //清等發(fā)送標(biāo)志位
- /************* 主程序********************/
- void main()
- UART_Init();
- init_play() ;//初始化顯示
- while(l)
- read_tempO);//讀取溫度
- StartModule();
- while(R) ;//當(dāng)RX 為零時(shí)等待
- TRO=1;//開啟計(jì)數(shù)
- while(R) ;//當(dāng)RX 為1計(jì)數(shù)并等待
- TRO=0;//關(guān)閉計(jì)數(shù)
- show() ;//顯示
- delaylms(80) ;//80M
- if(Tx==1)
- Send('t');
- Send('e');
- Send('m');
- Send('p');
- Send('=');
- Send(disdata[1]) ;
- Send(disdata[2]) ;
- Send(C.N);
- Send(disdata[3]) ;
- Tx=0;
- Send ('');
- if(Ax==1)
- Send('r');
- Send('a');
- Send('n');
- Send('g');
- Send('e');
- Send('=');
- Send(ASCII[disbuff[0]]) ;
- Send('.');
- Send(ASCII[disbuff[1]]) ;
- Send(ASCII[disbuff[2]]) ;
- Send('');
- Ax=0
- void Uart_INT(void)interrupt 4 //串口中斷兩數(shù)
- uchar Rev = 0:
- if(RI) //查詢接收標(biāo)志位(有數(shù)據(jù)發(fā)送過來時(shí)置為1)
- RI = 0;
- Rcv =SBUF;
- RxBuf=Rcv ;
- if(RxBuf=='8' ){ TxF1;}
- if(RxBuf==' 0' ){Ax=1; }
- #include<REG52.H>
- #include<math.h>
- #include<stdio.h>
- sbit DQ=P2^2 ;
- sbit RS=P3^5;
- sbit RW=P3^6 ;
- sbit EN=P3^4 ;
- sbit R=P2^ 7 ;
- sbit T=P2^6 ;
- bit flag =0;
- uint tvalue;//溫度值
- uchar Tx,Ax;
- unsigned int i,j;
- delaylms(1) ;
- RS=0;
- RW=0;
- EN=0;
- P0=com;
- delay1ms(1) ;
- EN=1;
- delay1ms(1);
- EN=0;
- //BLK=0 ;
- delay1ms(15) ;
- wr_com(0x38) ;
- delaylms(5)
- while(*p!='\0')
- wr_dat (*p);
- p++;
- //delaylms(1) ;
- lcd_initO ;
- wr_com(0x80)
- display(strl) ;
- while(i--);
- DQ = 1;
- delay_18B20(4);
- DQ=0;
- delay_18B20(100);
- DQ=1;
- delay_18B20(40);
- for (i=8;i>0;i--)
- dat>>=1;
- if(DQ)
- dat |=0x80;
- delay_18B20(10) ;
- return(dat);
- DQ = 0;
- DQ = wdata&0x01;
- delay_18B20(10) ;
- DQ = 1;
- wdata>>=1;
- uchar a,b;
- ds1820rst () ;
- ds1820rst () ;
- a=ds1820rd();
- b=ds1820rd();
- tvalue=b ;
- tvalue<<=8;
- tvalue=tvalue|a;
- if(tvalue<0xOfff)
- tflag=0;
- else
- tvalue=~tvalue+1;
- tflag=1;
- tvalue=tvalue-15;
- return(tvalue);
- uchar flagdat;
- time=TH0*256+TLO;
- THO=0;
- TL0=0;
- S=(time*1.7)/100;
- if(tflag==0)
- else
- wr_com (0xcO) ;
- wr_com(Oxc1) ;
- wr_com(0 x c2) ;
- wr_com(0xc3)
- wr_com(0xc4) ;
- wr_com (0xc8)
- wr_com (0xc9) ;
- wr_com (Oxca) :
- wr_com(0xcb) ;
- wr_com (0xcc) ;
- wr_com (Oxcd) ;
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- T=0;
- PCON = 0x00;
- THO =0;
- TLO =0;
- ES = 1;//開串中斷.
- ETO =1;
- TR1=1;//開總中斷。
- EA = 1;
- void main()
- UART_Init();
- while(l)
- StartModule();
- show() ;//顯示
- if(Tx==1)
- Send('t');
- Send('e');
- Send('m');
- Send('p');
- Send('=');
- Send(C.N);
- Tx=0;
- Send ('');
- if(Ax==1)
- Send('r');
- Send('a');
- Send('n');
- Send('g');
- Send('e');
- Send('=');
- Send('.');
- Send('');
- Ax=0
- uchar Rev = 0:
- RI = 0;
- Rcv =SBUF;
- RxBuf=Rcv ;
