查看: 4062|回復(fù): 3
單片機(jī)電子沙漏程序
ID:254193 發(fā)表于 2017-12-6 19:10 來自觸屏版 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg51.h>        //頭文件
typedef unsigned int  uint;
typedef unsigned char uchar;
sbit D1=P1^0;
sbit D2=P1^1;
sbit D3=P1^2;
sbit D4=P1^3;
sbit D5=P1^4;
sbit D6=P1^5;
sbit D7=P1^6;
sbit D8=P1^7;
sbit D9=P3^0;
sbit D10=P3^1;
sbit D11=P3^2;
sbit D12=P3^3;
sbit D13=P3^4;
sbit D14=P3^5;
sbit D15=P3^6;
sbit D16=P3^7;
sbit D17=P0^0;
sbit D18=P0^1;
sbit D19=P0^2;
sbit D20=P0^3;
sbit D21=P0^4;
sbit D22=P0^5;
sbit D23=P0^6;
sbit D24=P0^7;
sbit D25=P2^0;
sbit D26=P2^1;
sbit D27=P2^2;
sbit D28=P2^3;
sbit D29=P2^4;
sbit D30=P2^5;
sbit D31=P2^6;
sbit D32=P2^7;
void delayms(unsigned int t)
         unsigned int a,b;
        for(a=110;a>0;a--)
           for(b=t;b>0;b--);
int f=0;
void main()                        //主函數(shù)
                if(f==0)
                        st:
                        while(D32==0);
                        P1=0X00;
                        P0=0X00;
                        P2=0XFF;
                        P3=0XFF;
                        f=1;
                        delayms(1000);
                if(f==1)
                        D8=1;
                        delayms(250);
                        D31=0;
                        delayms(250);
                        if(D32==0)goto st;
                        D31=1;
                        D27=0;
                        delayms(250);
                        D27=1;
                        D11=0;
                        delayms(250);
                        if(D32==0)goto st;/@
                        D7=1;
                        delayms(250);
                        D31=0;
                        delayms(250);
                        if(D32==0)goto st;
                        D31=1;
                        D27=0;
                        delayms(250);
                        D27=1;
                        D12=0;
                        delayms(250);
                        if(D32==0)goto st; /@
                        D17=1;
                        delayms(250);
                        D31=0;
                        delayms(250);
                        if(D32==0)goto st;
                        D31=1;
                        D27=0;
                        delayms(250);
                        D27=1;
                        D10=0;
                        delayms(250);
                        D4=1;
                        delayms(250);
                        D31=0;
                        delayms(250);
                        if(D32==0)goto st;
                        D31=1;
                        D27=0;
                        delayms(250);
                        D27=1;
                        D16=0;
                        delayms(250);
                        D5=1;
                        delayms(250);
                        D31=0;
                        delayms(250);
                        if(D32==0)goto st;
                        D31=1;
                        D27=0;
                        delayms(250);
                        D27=1;
                        D15=0;
                        delayms(250);
                        D3=1;
                        delayms(200);
                        D31=0;
                        delayms(200);
                        if(D32==0)goto st;
                        D31=1;
                        D27=0;
                        delayms(200);
                        D27=1;
                        D25=0;
                        delayms(200);
                        D25=1;
                        D13=0;
                        delayms(200);
                        D6=1;
                        delayms(200);
                        D31=0;
                        delayms(200);
                        if(D32==0)goto st;
                        D31=1;
                        D27=0;
                        delayms(200);
                        D27=1;
                        D14=0;
                        delayms(200);
                        D14=1;
                        D9=0;
                        delayms(200);
                        D1=1;
                        delayms(250);
                        D31=0;
                        delayms(250);
                        if(D32==0)goto st;
                        D31=1;
                        D27=0;
                        delayms(250);
                        D27=1;
                        D25=0;
                        delayms(250);
                        D2=1;
                        delayms(250);
                        D31=0;
                        delayms(250);
                        if(D32==0)goto st;
                        D31=1;
                        D27=0;
                        delayms(250);
                        D27=1;
                        D14=0;
                        delayms(250);
                        D20=1;
                        delayms(333);
                        D31=0;
                        delayms(333);
                        if(D32==0)goto st;
                        D31=1;
                        D27=0;
                        delayms(333);
                        D18=1;
                        delayms(333);
                        D31=0;
                        delayms(333);
                        if(D32==0)goto st;
                        D31=1;
                        D28=0;
                        delayms(333);
                        D19=1;
                        delayms(333);
                        D31=0;
                        delayms(333);
                        if(D32==0)goto st;
                        D31=1;
                        D26=0;
                        delayms(333);
                        D22=1;
                        delayms(333);
                        D31=0;
                        delayms(333);
                        if(D32==0)goto st;
                        D31=1;
                        D30=0;
                        delayms(333);
                        D21=1;
                        delayms(333);
                        D31=0;
                        delayms(333);
                        if(D32==0)goto st;
                        D31=1;
                        D29=0;
                        delayms(333);
                        D23=1;
                        D31=0;
                        delayms(1000);
                        f=2;
                if(f==2)
ID:841290 發(fā)表于 2020-11-9 22:47 | 只看該作者
里面的st可以解釋一下嘛?
ID:328014 發(fā)表于 2020-11-9 23:00 | 只看該作者
ST 是goto語句  一般不建議這樣做
ID:940754 發(fā)表于 2021-6-21 12:19 來自觸屏版 | 只看該作者
51hei團(tuán)團(tuán) 發(fā)表于 2020-11-9 23:00
ST 是goto語句  一般不建議這樣做
請(qǐng)問,那應(yīng)該怎么做呀
