查看: 4612|回復(fù): 0
利用8254輸出不同頻率方波。輸入信號為2MHz,輸出信號頻率分別為:200kHz 、20kHz...
ID:258130 發(fā)表于 2017-12-6 22:55 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
這是我用C語言做的
#include "reg51.h"
#define  uchar unsigned char
#define  uint  unsigned int
sbit P10=P1^0;
sbit P11=P1^1;
sbit P12=P1^2;
uchar xdata P8254_CTL _at_ 0xF903;
uchar xdata P8254_0 _at_ 0xF900;
uchar xdata P8254_1 _at_ 0xF901;
uchar xdata P8254_2 _at_ 0xF902;
uchar xdata P374       _at_ 0xFa00;
void   delay1ms(unsigned char);
uchar flag;
void main(void)
   IE = 0x81; IT0 = 1;
    CLK_DIV=0x40;
   P8254_CTL = 0x76   ;
              if(P10==0)   //200k                  10
                    P8254_1 =0x0a ; P8254_1 =0x00;
                   if(P11==0)   //20k                  100
                    P8254_1 =0x64 ; P8254_1 =0x00;
                   if(P12==0)   //2k                  1000
                    P8254_1 =0xe8 ; P8254_1 =0x03;
void interint0() interrupt 0
void delay1ms(unsigned char time)
   uchar i; uint j;
   for (i=0;i<time;i++)
          for (j=0;j<355;j++){;}
