查看: 4072|回復(fù): 8
單片機(jī)時(shí)鐘程序,第一個(gè)數(shù)碼管特別亮,按鍵按下時(shí)恢復(fù)正常亮度,松開又變亮,求助
ID:259323 發(fā)表于 2017-12-9 10:19 | 顯示全部樓層 |閱讀模式
單片機(jī)時(shí)鐘程序,第一個(gè)數(shù)碼管特別亮,按鍵按下時(shí)恢復(fù)正常,松開又變亮,這要怎么改?
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. sbit key1=P3^0;
  4. sbit key2=P3^1;
  5. sbit key3=P3^2;
  6. sbit key4=P3^3;
  7. sbit wela=P2^1;
  8. sbit dula=P2^0;
  9. unsigned char num=-1;
  10. unsigned char tabledsq[]={0,1};
  11. unsigned char code tabledu[]=
  12. {0x3F,0x06,0x5B,0x4F,
  13. 0x66,0x6D,0x7D,0x07,
  14. 0x7F,0x6F,0x77,0x7C,
  15. 0x39,0x5E,0x79,0x71,};
  16. long s=0,m=0,h=0,shi1=0,ge1=0,shi2=0,ge2=0,shi3=0,ge3=0;
  17. void timer_set();
  18. void smg_display(long a,long b,long c,long d,long e,long f);
  19. void delay(unsigned int z)
  20. {
  21.         unsigned int x,y;
  22.         for(x=z;x>0;x--)
  23.         for(y=110;y>0;y--);
  24. }
  25. void main()
  26. {
  27.     timer_set();
  28.            while(1)
  29.         {
  30.                 shi1=s/10;
  31.             ge1=s%10;
  32.             shi2=m/10;
  33.             ge2=m%10;
  34.              shi3=h/10;
  35.             ge3=h%10;
  36.             smg_display(ge1,shi1,ge2,shi2,ge3,shi3);
  37.                 if(key1==0)
  38.                 {
  39.             delay(10);
  40.             if (key1==0)
  41.             {
  42.                    num++;
  43.                    if(num==2)
  44.                    {
  45.                        num=0;
  46.                    }
  47.                    TR0=tabledsq[num];
  48.                    while(!key1)
  49.                    smg_display(ge1,shi1,ge2,shi2,ge3,shi3);
  50.                 }
  51.             }
  52.                 if(key2==0)
  53.                 {
  54.             delay(10);
  55.             if (key2==0)
  56.             {
  57.                    s++;
  58.                    if(s==60)
  59.                    {
  60.                       s=0;
  61.                    }
  62.                    while(!key2)
  63.                    smg_display(ge1,shi1,ge2,shi2,ge3,shi3);
  64.                 }
  65.             }
  66.                 if(key3==0)
  67.                 {
  68.             delay(10);
  69.             if (key3==0)
  70.             {
  71.                    m++;
  72.                    if(m==60)
  73.                    {
  74.                       m=0;
  75.                    }
  76.                    while(!key3)
  77.                    smg_display(ge1,shi1,ge2,shi2,ge3,shi3);
  78.                 }
  79.             }
  80.                 if(key4==0)
  81.                 {
  82.             delay(10);
  83.             if (key4==0)
  84.             {
  85.                    h++;
  86.                    if(h==24)
  87.                    {
  88.                       h=0;
  89.                    }
  90.                    while(!key4)
  91.                    smg_display(ge1,shi1,ge2,shi2,ge3,shi3);
  92.                 }
  93.             }
  94.         }
  95. }
  96. void timer0() interrupt 1
  97. {
  98.     static long t=0;
  99.           TH0=(65536-50000)/256;
  100.         TL0=(65536-50000)%256;
  101.         t++;
  102.         if(t==20)
  103.         {
  104.            t=0;
  105.            s++;
  106.            if(s==60)
  107.            {
  108.               s=0;
  109.                   m++;
  110.                   if(m==60)
  111.                   {
  112.                      m=0;
  113.                      h++;
  114.                          if(h==24)
  115.                          {
  116.                            h=0;
  117.                          }
  118.                   }
  119.            }
  120.         }
  121. }
  122. void timer_set()
  123. {
  124.     TMOD  |=0x01;
  125.         TH0=(65536-50000)/256;
  126.         TL0=(65536-50000)%256;
  127.         ET0=1;
  128.         TR0=1;
  129.         EA=1;
  130. }
  131. void smg_display(long a,long b,long c,long d,long e,long f)
  132. {
  133.         wela=1;
  134.                 P1=0x7F;
  135.                 wela=0;
  136.                 dula=1;
  137.                 P1=tabledu[a];
  138.                 dula=0;
  139.                 delay(2);
  140.
  141.         wela=1;
  142.                 P1=0xBF;
  143.                 wela=0;
  144.                 dula=1;
  145.                 P1=tabledu[b];
  146.                 dula=0;
  147.                 delay(2);
  148.
  149.                 wela=1;
  150.                 P1=0xDF;
  151.                 wela=0;
  152.                 dula=1;
  153.                 P1=0x40;
  154.                 dula=0;
  155.                 delay(2);
  156.
  157.                 wela=1;
  158.                 P1=0xEF;
  159.                 wela=0;
  160.                 dula=1;
  161.                 P1=tabledu[c];
  162.                 dula=0;
  163.                 delay(2);
  164.
  165.                 wela=1;
  166.                 P1=0xF7;
  167.                 wela=0;
  168.                 dula=1;
  169.                 P1=tabledu[d];
  170.                 dula=0;
  171.                 delay(2);
  172.
  173.                 wela=1;
  174.                 P1=0xFB;
  175.                 wela=0;
  176.                 dula=1;
  177.                 P1=0x40;
  178.                 dula=0;
  179.                 delay(2);
  180.
  181.                 wela=1;
  182.                 P1=0xFD;
  183.                 wela=0;
  184.                 dula=1;
  185.                 P1=tabledu[e];
  186.                 dula=0;
  187.                 delay(2);
  188.
  189.                 wela=1;
  190.                 P1=0xFE;
  191.                 wela=0;
  192.                 dula=1;
  193.                 P1=tabledu[f];
  194.                 dula=0;
  195.                 delay(2);
  196. }
ID:96682 發(fā)表于 2017-12-9 11:13 | 顯示全部樓層
看元器件哪里有什么不妥
ID:259323 發(fā)表于 2017-12-9 12:27 | 顯示全部樓層
wc86110 發(fā)表于 2017-12-9 11:13
看元器件哪里有什么不妥
這應(yīng)該沒問題
ID:258566 發(fā)表于 2017-12-9 13:21 | 顯示全部樓層
調(diào)試 邏輯分析儀 特別亮 刷新率應(yīng)該不一樣。
ID:259414 發(fā)表于 2017-12-9 14:43 | 顯示全部樓層
最好查一下電路圖,看一下電路板上這個(gè)數(shù)碼管有沒有短路的地方
ID:192235 發(fā)表于 2017-12-9 17:26 | 顯示全部樓層
數(shù)碼管動(dòng)態(tài)顯示  程序上要消隱.   就是再顯示一遍后要把數(shù)碼管滅掉,         不然在 點(diǎn)亮最后一個(gè)數(shù)碼管之后
到  下一輪循環(huán)  點(diǎn)亮第一個(gè)數(shù)碼管之前   這段時(shí)間  最后一個(gè)數(shù)碼管是一直亮著的         雖然時(shí)間很短   但最后一個(gè)數(shù)碼管  亮的時(shí)間  會(huì)比其他數(shù)碼管多    所以程序上最后一個(gè)數(shù)碼管會(huì)比其他數(shù)碼管亮
參與人數(shù) 1黑幣 +3 收起 理由
重口辣泡菜 + 3 很給力!
ID:213173 發(fā)表于 2017-12-9 20:36 | 顯示全部樓層
你這樣處理顯示程序不合理,按鍵會(huì)干擾顯示,需要分開處理,給你改了一下,你試試。
#include <reg52.h>
sbit key1=P3^0;
sbit key2=P3^1;
sbit key3=P3^2;
sbit key4=P3^3;
sbit wela=P2^1;
sbit dula=P2^0;
unsigned char s=0,m=0,h=12;
bit ZT=0;
unsigned int t=0;
void timer_set();
void smg_display();
        unsigned int x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
        timer_set();
                if(key1==0)
                        delay(10);
                        if (key1==0)
                                ZT=~ZT;
                                t=0;
                                while(!key1);
                if(key2==0)
                        delay(10);
                        if (key2==0)
                                s++;
                                if(s>=60)
                                        s=0;
                                while(!key2);
                if(key3==0)
                        delay(10);
                        if (key3==0)
                                m++;
                                if(m>=60)
                                        m=0;
                                while(!key3);
                if(key4==0)
                        delay(10);
                        if (key4==0)
                                h++;
                                if(h>=24)
                                        h=0;
                                while(!key4);
        TH0=(65536-2500)/256;
        TL0=(65536-2500)%256;
        if(ZT==0)
                t++;
                if(t>=400)//1s
                        t=0;
                        s++;
                        if(s>=60)
                                s=0;
                                m++;
                                if(m>=60)
                                        m=0;
                                        h++;
                                        if(h>=24)
                                                h=0;
        smg_display();
void timer_set()
        TMOD=0x01;
        ET0=1;
        TR0=1;
        EA=1;
void smg_display()
        static unsigned char count=0;        //計(jì)數(shù)變量
        switch(count)
                case 0:
                        wela=1;
                        P1=0x7F;
                        wela=0;
                        dula=1;
                        P1=tabledu[s%10];
                        dula=0;
                        count=1;
                break;
                case 1:
                        wela=1;
                        P1=0xBF;
                        wela=0;
                        dula=1;
                        P1=tabledu[s/10];
                        dula=0;
                        count=2;
                break;
                case 2:
                        wela=1;
                        P1=0xDF;
                        wela=0;
                        dula=1;
                        P1=0x40;
                        dula=0;
                        count=3;
                break;
                case 3:
                        wela=1;
                        P1=0xEF;
                        wela=0;
                        dula=1;
                        P1=tabledu[m%10];
                        dula=0;
                        count=4;
                break;
                case 4:
                        wela=1;
                        P1=0xF7;
                        wela=0;
                        dula=1;
                        P1=tabledu[m/10];
                        dula=0;
                        count=5;
                break;
                case 5:
                        wela=1;
                        P1=0xFB;
                        wela=0;
                        dula=1;
                        P1=0x40;
                        dula=0;
                        count=6;
                break;
                case 6:
                        wela=1;
                        P1=0xFD;
                        wela=0;
                        dula=1;
                        P1=tabledu[h%10];
                        dula=0;
                        count=7;
                break;
                case 7:
                        wela=1;
                        P1=0xFE;
                        wela=0;
                        dula=1;
                        P1=tabledu[h/10];
                        dula=0;
                        count=0;
重口辣泡菜 + 3 很給力!
ID:259323 發(fā)表于 2017-12-10 14:13 | 顯示全部樓層
軍師祭酒 發(fā)表于 2017-12-9 17:26
數(shù)碼管動(dòng)態(tài)顯示  程序上要消隱.   就是再顯示一遍后要把數(shù)碼管滅掉,         不然在 點(diǎn)亮最后一個(gè)數(shù)碼管之 ...
謝謝,解決了
ID:259323 發(fā)表于 2017-12-10 14:14 | 顯示全部樓層
wulin 發(fā)表于 2017-12-9 20:36
#include
#include  ...
嗯,謝謝
