查看: 6204|回復(fù): 4
藍(lán)橋杯任務(wù)基于單片機(jī)的電子鐘
ID:261418 發(fā)表于 2017-12-14 10:30 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
基于單片機(jī)的電子鐘仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
藍(lán)橋杯任務(wù)單片機(jī)源程序如下:
  1. #include <regx51.h>
  2. #include <intrins.h>
  3. sfr AUXR = 0x8e;
  4. /*數(shù)碼管顯示字符轉(zhuǎn)換表*/
  5. unsigned char tab[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00,0x40,0x39};
  6. signed char num[] = {10,10,10,10,10,10,10,10};   //數(shù)碼管顯示緩沖區(qū)
  7. signed char timeclock[] = {0,0,11,0,0,11,0,0};   //鬧鐘時(shí)間
  8. unsigned char TRH0,TRL0;  //T0重載值的高字節(jié)和低字節(jié)
  9. bit clock = 0;          //鬧鐘時(shí)間到標(biāo)志位
  10. bit flag = 0;          //1s閃爍標(biāo)志位
  11. bit flag200ms = 0;         //200ms定時(shí)標(biāo)志位
  12. bit timesetup = 0;   //時(shí)間設(shè)置標(biāo)志位
  13. bit clocksetup = 0;         //鬧鐘設(shè)置標(biāo)志位
  14. unsigned position = 0;    //設(shè)置小時(shí),分鐘,秒標(biāo)志位(‘1’小時(shí),‘2’分鐘,‘3’秒)
  15. unsigned char Temp;           //溫度值
  16. unsigned char Time[5];          //時(shí)間值
  17. void key();  //按鍵判斷執(zhí)行函數(shù)
  18. void Ds1302_Display();          //時(shí)間顯示函數(shù)
  19. void Ds18b20_Display();          //溫度顯示函數(shù)
  20. extern void Ds1302_Init();          //DS1302初始化函數(shù)
  21. void Ds1302_Time(unsigned char *time);  //帶參數(shù)的向DS18B20寫時(shí)間
  22. extern void Write_Ds1302_Byte(unsigned char temp);          //向DS1302寫入數(shù)據(jù)
  23. extern unsigned char Read_Ds1302 (unsigned char address);          //從DS1302讀取數(shù)據(jù)
  24. extern unsigned char DS18B20_Temp();         //讀取DS18B20溫度值
  25. /*T0初始化函數(shù) (ms = 中斷時(shí)間)*/
  26. void Time0_Init(unsigned char ms)
  27. {
  28.         unsigned long num;                //臨時(shí)變量
  29.         num = 12000000 / 12;     //12分頻  定時(shí)器計(jì)數(shù)頻率
  30.         num = (num * ms)/1000;          //計(jì)算所需的計(jì)數(shù)值
  31.         num = 65536 - num;                  //計(jì)算定時(shí)器重載值
  32.         TRH0 = (unsigned char)(num>>8);                //定時(shí)器重載值拆分為高低字節(jié)
  33.         TRL0 = (unsigned char)num;
  34.         TH0 = TRH0;           //加載T0重載值
  35.         TL0 = TRL0;
  36.         AUXR &= 0x7F;
  37.         TMOD &= 0xf0;          //清零T0的控制位
  38.         TMOD |= 0x01;          //配置T0為模式1
  39.         EA = 1;                //使能總中斷
  40.         ET0 = 1;        //使能T0中斷
  41.         TR0 = 1;        //啟動(dòng)T0
  42. }
  43. void main()
  44. {
  45.         unsigned char i,k=0;
  46.         Time0_Init(1);         //初始化T0,定時(shí)時(shí)間為1ms
  47.         Ds1302_Init();         //初始化DS1302
  48.         while(1)
  49.         {
  50.                 key();
  51.                 for(i=0;i<8;i++)
  52.                 {
  53.                         if(num[i]==timeclock[i])
  54.                                 k++        ;
  55.                         else
  56.                                 k = 0;
  57.                 }
  58.                 if(k == 8)
  59.                         clock = 1;
  60.
  61.         }
  62. }
  63. /*DS18B20顯示函數(shù)*/
  64. void Ds18b20_Display()
  65. {
  66.         unsigned char i;
  67.         if(flag200ms != 0)
  68.         {
  69.                 flag200ms = 0;
  70.                 Temp = DS18B20_Temp();
  71.
  72.                 for(i=0;i<5;i++)
  73.                 {
  74.                         num[i] = 10;
  75.                 }
  76.
  77.                 num[5] = Temp / 10;
  78.                 num[6] = Temp % 10;
  79.                 num[7] = 12;
  80.         }
  81. }
  82. /*DS1302顯示函數(shù)*/
  83. void Ds1302_Display()
  84. {
  85.         static unsigned char i;
  86.         static unsigned char pers = 0xaa;
  87.
  88.         if(flag200ms != 0)
  89.         {
  90.                 flag200ms = 0;
  91.                 for(i=0;i<3;i++)
  92.                 {
  93.                         Time[i] = Read_Ds1302(i);  //每200ms獲取時(shí)間
  94.                 }
  95.                 if(pers != Time[0])          //判斷時(shí)間有沒有變化
  96.                 {
  97.                         num[7] = Time[0] & 0x0f;   //秒
  98.                         num[6] = Time[0] >> 4;
  99.                         num[5] = 11;
  100.                         num[4] = Time[1] & 0x0f;   //分
  101.                         num[3] = Time[1] >> 4;
  102.                         num[2] = 11;
  103.                         num[1] = Time[2] & 0x0f;   //時(shí)
  104.                         num[0] = Time[2] >> 4;
  105.                         pers = Time[0];                //將變化值重新寫入判斷值
  106.                 }
  107.         }
  108. }
  109. /*數(shù)碼管顯示函數(shù)*/
  110. void Display()
  111. {
  112.         static unsigned char we = 0;
  113.
  114.         P0 = 0x00;                //清除鬼影
  115.         P2 |= 0xff;
  116.         P2 &= ~(1<<we);          //位選擇
  117.         if(clocksetup)
  118.                 P0 = tab[timeclock[we]];
  119.         else
  120.                 P0 = tab[num[we]];          //顯示數(shù)選擇
  121.
  122.         if(flag)           //進(jìn)入設(shè)置狀態(tài)
  123.         {
  124.                 switch(position) //判斷是那個(gè)設(shè)置位
  125.                 {
  126.                         case 1:         P2 |= 0xc0; break;         //秒
  127.                         case 2:         P2 |= 0x18; break;         //分
  128.                         case 3:         P2 |= 0x03; break;         //時(shí)
  129.                         default : position = 0; timesetup = 0; clocksetup = 0; break;
  130.                 }
  131.         }
  132.
  133.         if(++we >= 8)  //八個(gè)數(shù)碼管
  134.                 we = 0;
  135. }
  136. /*T0中斷函數(shù)*/
  137. void Time0_inte() interrupt 1
  138. {
  139.         static unsigned char ms = 0;
  140.         static unsigned char flag1s = 0;
  141.         static unsigned char flag5s = 0;
  142.         TH0 = TRH0;         //加載T0重載值
  143.         TL0 = TRL0;
  144.         Display();        //數(shù)碼管顯示
  145.         if(++ms >= 200)
  146.         {
  147.                 flag200ms = 1;
  148.                 ms = 0;
  149.                 if(flag5s < 5 && clock)         //鬧鐘5秒時(shí)間判斷
  150.                 {
  151.                         P1_0 = ~P1_0;
  152.                 }
  153.                 else
  154.                 {
  155.                         clock = 0;
  156.                         P1_0 = 0;
  157.                 }
  158.                 if(++flag1s >= 5)
  159.                 {
  160.                         flag1s = 0;
  161.                         flag = ~flag;
  162.                         if(clock)
  163.                                 flag5s++;
  164.                         else
  165.                                 flag5s = 0;
  166.                 }
  167.         }
  168. }
  169. //向DS1302寫入時(shí)間
  170. void TimeWeite()
  171. {
  172.         unsigned char ti[3];
  173.         //將兩個(gè)分開的時(shí)間合成在一起
  174.         ti[0] = ((num[6]<<4) | num[7]);
  175.         ti[1] = ((num[3]<<4) | num[4]);
  176.         ti[2] = ((num[0]<<4) | num[1]);
  177.         Ds1302_Time(ti);
  178. }
  179. void key()
  180. {
  181.         if((P3_0==0||P3_1==0||P3_2==0||P3_3==0)&&clock==1)        //鬧鐘響應(yīng),進(jìn)行關(guān)閉
  182.         {
  183.                 clock = 0;
  184.                 while(!P3_0);while(!P3_1);
  185.                 while(!P3_2);while(!P3_3);
  186.         }
  187.         if(timesetup!=1 && clocksetup!=1 && P3_0==1)        //按下顯示溫度值,松開顯示時(shí)間
  188.         {
  189.                 Ds1302_Display();
  190.         }else if(timesetup!=1 && clocksetup!=1 &&P3_0 == 0)
  191.         {
  192.                 Ds18b20_Display();
  193.         }
  194.         if(clocksetup !=1 && P3_3 == 0)                //進(jìn)入時(shí)間設(shè)置
  195.         {
  196.                 timesetup = 1;
  197.                 position++;
  198.                 if(position == 4)        //向DS1302重新寫入時(shí)間
  199.                 {
  200.                         TimeWeite();
  201.                 }
  202.                 while(!P3_3);
  203.         }
  204.         if(timesetup !=1 && P3_2 == 0)           //進(jìn)入鬧鐘時(shí)間設(shè)置
  205.         {
  206.                 clocksetup = 1;
  207.                 position++;
  208.                 clock = 0;
  209.                 while(!P3_2);
  210.         }
  211.         if((timesetup==1||clocksetup==1) && P3_0 == 0)        //進(jìn)入時(shí)間設(shè)置, 時(shí)間+1
  212.         {
  213.           if(timesetup)                //實(shí)時(shí)時(shí)鐘設(shè)置
  214.           {
  215.                   if(position == 1)          //秒
  216.                 {
  217.                         if(++num[7] >= 10)
  218.                         {
  219.                                 num[7] = 0;
  220.                                 if(++num[6] >=6)
  221.                                         num[6] = 0;
  222.                         }
  223.                 }else
  224.                 if(position == 2)         //分
  225.                 {
  226.                         if(++num[4] >= 10)
  227.                         {
  228.                                 num[4] = 0;
  229.                                 if(++num[3] >=6)
  230.                                         num[3] = 0;
  231.                         }
  232.                 }else
  233.                 if(position == 3)         //時(shí)
  234.                 {
  235.                         if(num[0] == 2)
  236.                         {
  237.                                 if(++num[1] >= 5)
  238.                                 {
  239.                                         num[1] = 0;
  240.                                         num[0] = 0;
  241.                                 }
  242.                         }else
  243.                         if(++num[1] >= 10)
  244.                         {
  245.                                 num[1] = 0;
  246.                                 if(++num[0] >=3)
  247.                                         num[0] = 0;
  248.                         }
  249.                 }
  250.           }else if(clocksetup)          //鬧鐘時(shí)間設(shè)置
  251.           {
  252.                   if(position == 1)          //秒
  253.                 {
  254.                         if(++timeclock[7] >= 10)
  255.                         {
  256.                                 timeclock[7] = 0;
  257.                                 if(++timeclock[6] >=6)
  258.                                         timeclock[6] = 0;
  259.                         }
  260.                 }else
  261.                 if(position == 2)         //分
  262.                 {
  263.                         if(++timeclock[4] >= 10)
  264.                         {
  265.                                 timeclock[4] = 0;
  266.                                 if(++timeclock[3] >=6)
  267.                                         timeclock[3] = 0;
  268.                         }
  269.                 }else
  270.                 if(position == 3)         //時(shí)
  271.                 {
  272.                         if(timeclock[0] == 2)
  273.                         {
  274.                                 if(++timeclock[1] >= 4)
  275.                                 {
  276.                                         timeclock[1] = 0;
  277.                                         timeclock[0] = 0;
  278.                                 }
  279.                         }else
  280.                         if(++timeclock[1] >= 10)
  281.                         {
  282.                                 timeclock[1] = 0;
  283.                                 if(++timeclock[0] >=3)
  284.                                         timeclock[0] = 0;
  285.                         }
  286.                 }
  287.           }
  288.           while(!P3_0);
  289.         }
  290.         if((timesetup==1||clocksetup==1) && P3_1 == 0)         //進(jìn)入時(shí)間設(shè)置, 時(shí)間-1
  291.         {
  292.                 if(timesetup)           //實(shí)時(shí)時(shí)鐘設(shè)置
  293.           {
  294.                   if(position == 1)        //秒
  295.                 {
  296.                         if(--num[7] < 0)
  297.                         {
  298.                                 num[7] = 9;
  299.                                 if(--num[6] < 0)
  300.                                         num[6] = 5;
  301.                         }
  302.                 }else
  303.                 if(position == 2)        //分
  304.                 {
  305.                         if(--num[4] < 0)
  306.                         {
  307.                                 num[4] = 9;
  308.                                 if(--num[3] < 0)
  309.                                         num[3] = 5;
  310.                         }
  311.                 }else
  312.                 if(position == 3)  //時(shí)
  313.                 {
  314.                         if(--num[1] < 0)
  315.                         {
  316.                                 num[1] = 9;
  317.                                 if(--num[0] < 0)
  318.                                 {
  319.                                         num[0] = 2;
  320. ……………………
  321. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
基于單片機(jī)的電子鐘.zip (84.07 KB, 下載次數(shù): 115)
收藏收藏1 分享淘帖 頂1 踩
ID:171060 發(fā)表于 2017-12-23 22:05 來自觸屏版 | 只看該作者
感謝分享。
ID:368508 發(fā)表于 2018-7-11 14:18 | 只看該作者
感謝大佬。。!
ID:471752 發(fā)表于 2019-1-22 17:07 | 只看該作者
厲害,謝謝樓主
ID:544311 發(fā)表于 2020-11-29 16:47 | 只看該作者
謝謝大佬的分享,給了我很大幫助。
